Old 06-22-2015, 10:18 AM   #3459
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
"would you buy this kit again?"
Absolutely. The only real hangup with this kit is the belt. It's fussy. I'd rather deal with one bolt and a fussy belt than some of the issues on other FI kits. Fussing with one bolt every once and a while is worth the ridiculous amount of speed this kit adds.
industrial is offline   Reply With Quote
The Following 2 Users Say Thank You to industrial For This Useful Post:
Freeman (06-22-2015), KraftWerks (06-25-2015)
Old 06-22-2015, 10:35 AM   #3460
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
That kit came out a few years ago.
Yeah but they just did that huge group buy and no different than the BRZ/FR-S kit, packaging and making sure people get the right parts the first time is not their strong suit, so I could see them still focusing on the "somewhat new" or "newer than the original low side mount" S2k Kraftwerks kit.
Old 06-22-2015, 10:37 AM   #3461
Model Citizen
Lacking brains
Drives: frz
i'm happy
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
The Following User Says Thank You to Model Citizen For This Useful Post:
Old 06-22-2015, 10:54 AM   #3462
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by vgi View Post
yes
Glad I'm not the only one. Having had no issue other than a warranty claim on a faulty Supercharger unit I'd say yes i would buy it again.
Freeman is offline   Reply With Quote
The Following 2 Users Say Thank You to Freeman For This Useful Post:
KraftWerks (06-25-2015), Scracho (06-23-2015)
Old 06-22-2015, 12:49 PM   #3463
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Same here.
BTW: Anyone experience that the air in-tube becoming noisy like a high pitch whistle. I'm pretty sure it's the in-take tube, because it was able to trace it the when I cleaned my air filter. The pitch is coming from the in-take tube with or without the filter.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
The Following 2 Users Say Thank You to zoth For This Useful Post:
Old 06-22-2015, 12:57 PM   #3464
Rulin
WRX -> BRZ. (TX)
Rulin's Avatar
Drives: 2015 Series.Blue WRB
Absolutely would buy this kit again
KraftWerks c3094 SC Kit
ARK GRiP w/ test pipe
KW V3
OEM Audio + Reference 400CF
Rulin is offline   Reply With Quote
The Following 3 Users Say Thank You to Rulin For This Useful Post:
DAN_BRZ (06-25-2015), KraftWerks (06-25-2015), Scracho (06-23-2015)
Old 06-22-2015, 08:45 PM   #3465
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
I helped a little bit on "testing" some pulley setups, running pulleys daily that they didnt put out for the regular customers, like the 19psi pulley i was running, In the beginning i went through 2 belts, the first i didnt have tight enough and it had belt slap on the lower mount, the second broke because of the smaller old pulley set up, we found out gates didnt recommend that small of a pulley, once we got the new pulleys, i went 12k with zero issues and over 450hp. i updated some pulleys, smooth to toothed pulleys and when we did the belt was over tightened and snapped. my friend did it while i was installing a kit. I knew it was to tight but it was late and i figured it loosen it the next day. it had a very loud whine, the next day didnt come and the belt snapped. he tighten it like a serpentine belt and made it way to tight. my laziness caused that breakage, if i would've loosened it it would still be here today
So ive been asked locally what i think of the kit. I tell them all i would buy it again. i have no regrets. For me the kit works, it was the power delivery i wanted, more power then i ever thought id get. And while i love sitting and playing around with some high powered Turbo cars around here. i know for sure no doubt id get this kit all over again. maybe not the 19psi pulley i had, but i dont have no issue with this kit. I am 1000% happy with my purchase. Ive been trying to get the owner to pick one up for the shop FRS.
-Thomas
86SPEED is offline   Reply With Quote
The Following 3 Users Say Thank You to 86SPEED For This Useful Post:
Billion (06-23-2015), KraftWerks (06-25-2015), Scracho (06-23-2015)
Old 06-23-2015, 04:24 PM   #3466
Scracho
Drives: 2018 Subaru BRZ
A Key question to ask in any owners thread should be "would you buy this kit again?"
I would buy this kit again, and again, and again.
As far as F/I is concerned this is my only experience on this car in particular. Having many other projects in the past I would say that this kit is one of the best I have had to install and the power delivery is exactly what I was looking for. My only gripe thus far would be the finicky belt tension issue, which I'm pleased to say I have finally found the "sweet spot" and thus far no issues.
On my fourth 86... and everything in between
Scracho is offline   Reply With Quote
The Following User Says Thank You to Scracho For This Useful Post:
Old 06-23-2015, 06:51 PM   #3467
CSG Mike
CSG Mike's Avatar
-Thomas
Then why are you selling your kit?
Old 06-23-2015, 07:13 PM   #3468
86SPEED
86SPEED's Avatar
Because i ordered a Mercedes Benz CLA250.. you know this why come on here and start trash, you follow me on Facebook.
The car is 100% stock, as of this past weekend.
-Thomas
The Following User Says Thank You to 86SPEED For This Useful Post:
DriftinFRS (06-27-2015)
Old 06-23-2015, 07:15 PM   #3469
Freeman
Freeman's Avatar
I would assume a part out will net you more return on your money than selling a modified car as a whole. Never been through it myself
Old 06-23-2015, 07:20 PM   #3470
86SPEED
86SPEED's Avatar
Correct. parting out my car gets me the 17-18k Mercedes is giving me, and then the 13k or so for all the parts. or i can trade it in and mercedes just gives me the 17-18k with all the parts and i lose all that money. Mercedes asked me to return it to as close to stock as possible. for me its easy as i kept ever part. even the scion badges when i replaced them with toyota badges
-Thomas
Triumphrider (06-23-2015)
Old 06-24-2015, 06:11 PM   #3471
wahsaihin
Drives: 2013 Subaru BRZ Sport-Tech
I would buy my kit again on the account that I've had 0 issues for over 10,000km on this kit. No broken belts, no warranty claims, nothing. I am happy with the power right now and can't wait to get a custom tune done after my Tomei EL header, over pipe and 80R exhaust get put on.
If I had a clean slate I might consider a turbo kit, but for superchargers I can't say anything bad about KW in my experience.
This is my first time doing an aftermarket FI modification, and the KW kit definitely hasn't done anything to turn me off from doing it again for future projects, if any. CARB approval doesn't apply to me, so this has been a plug and play project with no stress at all.
wahsaihin is offline   Reply With Quote
The Following 2 Users Say Thank You to wahsaihin For This Useful Post:
John92 (06-24-2015), KraftWerks (06-25-2015)
Old 06-24-2015, 08:37 PM   #3472
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
Seems to me that there are a few individuals here trolling and giving out some false information.
We have not abandoned this community nor do we neglect the customers looking to purchase or who are asking for support on an existing purchase.
Each inquiry, so long as it is placed through the proper channel, is answered in a timely manner.
To help clear up the lines of communication, the following are ways to get into contact with our company:
Phone:
General Customer Service + Sales → 951-808-9888
Warranty / Technical Assistance → 951-808-9888; Ext. 208 (CJ)
Email:
General Sales → Sales@KraftWerksUSA.com
General Support → Support@KraftWerksUSA.com
Warranty / Technical → CJWeidl@Group-A-Eng.com
You also can PM us here as we receive notifications for this and will respond in a timely manner. Simply tagging us will not always show the proper notification on our end via email and may get over-looked.
If you have any questions regarding the product, sales, where to buy, installation assistance, warranty, etc. please reach out to us by phone or email so we can assist in a timely manner and get whatever may be going on, resolved.
General product information and methods of ordering are available directly on our website: KraftWerksUSA Website
Should you have questions about stock, product upgrades, revisions, etc. reach out to us using one of the channels mentioned above.
With that said... one of the most notable discussion topics is that of the C.A.R.B. approval on the kit. Simply put, it has taken far longer than we ever thought or hoped the process would take. It has been quite some time since we've attempted to have any product approved for California use and although we supply mainly to customers outside of the state, we have decided to invest the time and money into achieving the approval for this particular kit as well as others in the future. As of today, June 24th, 2015, the information from the testing has been submitted to C.A.R.B. and we are awaiting their approval. We anticipate having an EO number within 6-8 weeks. It is only then we can formally announce that we are approved publicly.
Communication and CARB aside, there is another topic that is surfacing lately being that Rotrex does not approve of a cogged pulley option. In response to that, we leave you all with these:
Jeff
you can run cog belt or chain as long as the very critical dimensions mentioned in our guidelines are kept.
Kind regards, Anders
Dear Mr. Giovino
Our superchargers do not necessarily have to be driven by a poly-V rib belt, but this is our standard as it accommodates most modern engines original belts. An advantage of the poly-V belt is that it can slip, compensating for engine rattle and rapid transients. All our internal tests are done with poly-V rib belts, but we do have costumers that uses cog drive belts with good results.
Best regards,
Søren Schmidt
Lead Engineer, Support & Quality Assurance
These are emails directly between ourselves and Rotrex prior to the design the FRS/BRZ kit and the re-design of the S2000 kit in which both representatives approve the use of the cogged pulley and even mention other companies were using cog with good results.
If there are other matters that need addressing or if you have existing, unresolved inquiries, please reach out to me directly so that I may assist you.
CJ
KraftWerks is offline   Reply With Quote
The Following 10 Users Say Thank You to KraftWerks For This Useful Post:
Billion (06-25-2015), DAN_BRZ (06-25-2015), DriftinFRS (06-27-2015), Freeman (06-24-2015), FRSTRM (06-25-2015), glamcem (06-26-2015), industrial (06-25-2015), mit_peid (06-24-2015), Rulin (06-24-2015), Scracho (06-25-2015)
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
