Old 06-19-2015, 09:39 AM   #1
jetrex
jetrex's Avatar
Royal Purple for Manual Transmission
Anyone running Royal Purple 75w90 Maxgear in there manual transmission. Just wondering if anyone has had issues with this brand.
Thanks.
jetrex is offline   Reply With Quote
Old 06-20-2015, 10:59 AM   #2
slyphen
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
i'm an idiot. deleted.
slyphen is offline   Reply With Quote
Old 06-20-2015, 12:32 PM   #3
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
Originally Posted by slyphen View Post
uh, not sure about 75w90, but i use 0w20 royal purple and so far its been great.
He's referencing gear oil, not engine oil.
menikmati is offline   Reply With Quote
Old 06-20-2015, 12:35 PM   #4
slyphen
Drives: Man
Drrr i'm an idiot. thanks for correcting.
Old 06-21-2015, 11:37 AM   #5
jetrex
jetrex's Avatar
Thanks. I actually run Valvoline Synthetic 0w20 in my car. I was wondering what everyone was using in there transmissions. I see most run Redline or Mogul. Just Wondering if anyone is running royal purple maxgear and how good the quality was.
Thanks.
Old 06-21-2015, 11:39 AM   #6
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I ran Motul 300 in my last transmission. Shifted smoothly once the car got warm. Didn't get rid of the odd rattle though, I needed a new tranny to fix that.
Bobblehead is offline   Reply With Quote
Old 06-21-2015, 03:01 PM   #7
jetrex
jetrex's Avatar
Thanks for the information. My FRS had 17400 when I picked it up and now has just shy of 18500 miles and I'm looking to replace both the diff and transmission fluids(no idea what the previous owner did to it). I've used Royal Purple in my manual transmission in my last car, 09' corolla xrs with no issues so Im thinking of giving it a try in my new car.
Old 06-21-2015, 11:37 PM   #8
Poodles
Drives: 2015 Series.Blue
RP is a GL5, factory fill is a GL3/4
Why are you changing the fluid anyway?
Old 06-23-2015, 10:55 PM   #9
mhughett
Drives: 2015 Crystal White BRZ Limited
MaxGear is a GL4/5, just like Motul. It can be used either in manual transmissions or differentials. Besides, you can't buy GL3 fluid anyway. All qualified oils are either GL4 or GL5.
mhughett is offline   Reply With Quote
Old 06-27-2015, 02:05 AM   #10
Poodles
There's a large difference between GL4 and GL5. Mainly that GL5 is designed for hypoid gears and contains friction modifier for limited slip differentials. This additive pack historically doesn't like to play well with Aisin transmissions as a general rule, causing hard shifting because the syncro isn't allowed to work correctly.
GL fluids don't supersede, no matter how hard the dealer tells you otherwise...
Any Issues with Royal Purple? akuhei Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 46 08-03-2015 04:06 PM
If I use royal purple oil will it void warranty? brzadrian Issues | Warranty | Recalls / TSB 13 03-04-2014 01:59 PM
FS: Royal Purple API-licensed SAE 0W-20 Synthetic Motor Oil Sportsguy83 Mechanical Maintenance and Tools 7 12-21-2012 08:10 PM
Royal Purple Oil - Possible GB (Vic Only) fuddbutter Australia Classifieds 0 11-14-2012 07:48 PM
Oil Change - Perhaps Royal Purple? RowTarEEE Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 47 11-01-2012 05:47 PM
