| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 13' Scion FRS
What size tire should I run?
I'm sure there is a thread about this but I'm pretty new to the forums and needed some advice. last week I purchased a set of Avid 1 AV20's for my FRS. I went with a 18x8/9.5 setup. Anyway, I'm pretty knew to stretching tires so I needed some advice. I had a extra pair of Nexen N5000 tires that are 225/40 that I planned on putting on the back but I didnt know what tire to run up front. The smallest I could find was 205/40 but I wasnt sure if those would look the same up front on the 18x8's as the 225's on the back. Any advice would be greatly appreciated. thankyou.
#2 |
Custom User Title
Drives: Asphalt FR-S MT
Why would you want to stretch your tires? (That's one of the stupidest automotive 'styles' ever.). 225/40 is good on an 8" width. 255/35 would be good on a 9.5" width. Keep in mind that tires are not all made the same though.
#3 |
Drives: FRS
are you going to slam your car? are you going to be putting on spacers? are you going to dial in a lot of negative camber all around? those wheels have pretty conservative offsets and combined with anything other than dumping the car, stretched tires would look ridiculous and unnecessary. stretching tires came about to get the wheels fit, not just for the sake of stretching.
#4 |
Señor Member
Size 6.... /thread
#5 |
okay so if i put the 225/40 on the front what difference would putting 255/40's on the back make instead of 225/35's?
#6 | |
Drives: 2013 Firestorm FRS
More importantly, what is your suspension setup? You might be rubbing fenders/springs/struts. We need to know suspension setup, and offset of your wheels before we can try and tell you which tire may/may not work. |
| The Following User Says Thank You to continuecrushing For This Useful Post: | tyrantcf (06-18-2015) |
#7 |
I just ordered tein coilovers & the offest of the wheels are +35 front and +38 rear
#8 |
Off Topic
Do 225/40 front and 255/35 rear. Those two sizes have very similar outside diameters and are pretty close to the OEM outside diameter.
| Tire compound vs Tire size | Dihudaxia | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 06-22-2015 10:55 AM |
| what tire size? | Boofneenee | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 02-21-2015 11:40 AM |
| Tire size help | sharris721 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 06-19-2014 12:03 AM |
| Tire size | TofuAE86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 04-10-2014 12:03 AM |
| Help with Tire Size | Sivtec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-12-2013 12:40 AM |
