Old 06-17-2015, 02:24 PM   #15
gramicci101
Off Topic
If you're installing underbody bracing such as the Cusco Power Braces, here's a DIY with torque values for the Agency Power braces. The torque values should still be the same, even if you aren't using the same brand. And it's written in English, which can sometimes be a positive.
http://www.agency-power.com/blog/tec...hassis-braces/
The Following User Says Thank You to gramicci101 For This Useful Post:
mokinbird87 (06-17-2015)
Old 06-17-2015, 02:54 PM   #16
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
sometimes the rigid collars are sort of a brace but not quite...
mokinbird87 is offline   Reply With Quote
Eibach Sportline Lowering Spring front and rear camber bolts WallsAndFoundations Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 08-20-2014 10:09 AM
Torque specs for rear toe arm Malt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 06-02-2014 07:24 PM
REVIEW | DC Sports rear subframe brace / rear subframe lateral brace mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 04-10-2014 08:59 PM
Eibach sportline, SPC rear LCAs, Whiteline front camber bolts Shad0ez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 11-17-2013 11:52 PM
Does anyone know the front and rear track specs? spiller Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-21-2012 08:25 AM
