#29 | |
Drives: Raven FR-S 6M
Changing spark plugs
The proper plugs have 3 prongs and should come gapped correctly. I didn't see any specs in the manual so I assumed this was not required. I'm not even sure how I would gap a plug like this.
“The World is Flat”
[||•]=(86)=[•||] |
#30 |
Drives: Whiteout FR-S
Anyone over 70k just replace their plugs? Curious what they look like compared to OP post.
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
#31 |
Drives: 2014 BRZ SCCA STU endurance car
The key I've found for these is to have the perfect combo of extensions, mix and match a few super short stubby extensions until you have the ratchet right where you want it.
#32 | |
Reverse Burnouts
Drives: 2013 Argento FRS
i havn't had any problem with my spark plugs yet. also im doing new injectors \o/ yay
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#33 |
When In Doubt...
Drives: Slowww
Mine were pulled below 50k miles and they looked pretty awful, made me wish I had that taken care of a bit earlier. I probably won't go more than 30k on the current set. I'd rather pull them too early than late to understand a good range of when to change them going forward.
I have them around somewhere for future comparison. And pictures if I remember.
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
#34 |
Changed them today actually.66k
What a pain in the ass.
2013 Ford Focus St
#35 |
Drives: MDX, Camry
What is the best spark plugs for the twins? OEM?
#36 |
Drives: '13 Ultramarine
They don't look bad, actually. A bit of carbon closer to the threads, but the firing surface is clean and the electrodes are a nice tan color...thanks for posting that pic.
| The Following User Says Thank You to roddy For This Useful Post: | NyC Zn6 (12-23-2015) |
#37 |
Yea not too bad, those look 'normal' for 66k.
On another note, I stopped by the Subie dealership for some OEM oil filters.. asked the serviceman about changing the spark plugs, he said they won't need to jack up the engine when changing the spark plugs. Not sure if that was just a sales pitch, but I'm sure they're not the only mechanics to take "short cuts" when doing maintenance/repairs. |
#38 |
@Black Tire
In the 355s defense, that's because it was one of the last ferrari's to have an interference engine with a timing belt, so if the belt failed you'd have a piston smash the valves. Most of the modern stuff like the Califronia T, 458 and 488 go much longer between those engine out services. The 458 for example only needs a major 5-6 year service regardless of mileage and only a 20 hour job vs the 50 hour job the F430 had.
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | chaoskaze (08-07-2016) |
#39 | |
Mentat
Drives: 2013 Scion FRS 6MT
#40 |
Drives: Scion FR-S
#41 |
[insert cool phrase here]
Drives: BRZ Premium
So far OEM. It's not cheap though. $22-25 per plug.
The plus side they last a long time.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#42 |
Drives: 2013 FR-S Ultramarine 6MT
Will have to rethink this 60,000 mi service thing! Just got a call from the dealership and it was going to be $750 for this service
. At least they were nice enough to call! Needless to say I said thanks but no thanks! Will have to see about the plug change when it gets a little warmer here. Cheers. |
| The Following User Says Thank You to rick s For This Useful Post: | ddevl_86 (02-26-2021) |
| Spark plugs for turbo | whitefrs | Forced Induction | 88 | 05-05-2018 09:18 PM |
| boosted spark plugs? | 350matt | Forced Induction | 9 | 08-09-2014 03:54 PM |
| Spark plugs | Triumphrider | Engine, Exhaust, Transmission | 12 | 06-19-2014 10:47 AM |
| spark plugs | subaruferrucci | Engine, Exhaust, Transmission | 22 | 04-10-2013 11:24 AM |
