Old 06-16-2015, 10:09 AM   #43
Papi
Drives: Crystal White Silica BRZ Limited
Aznatama did you ever move your camera to the drivers side?
Papi is offline   Reply With Quote
Old 06-16-2015, 10:19 AM   #44
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
? My car is lhd, camera is mounted on the left, so it's already on the driver side.
Sent from my D6503 using Tapatalk
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 06-16-2015, 11:28 AM   #45
Papi
So your saying that with the camera installed on the drivers side. I should not trust the lines because they are not centered to the car
Old 06-16-2015, 11:34 AM   #46
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
I would never trust the lines unless the camera came with the car (OEM).
B-R-Z is offline   Reply With Quote
Old 06-16-2015, 01:41 PM   #47
Papi
I've read somewhere that you can turn the line feature off
Old 06-16-2015, 02:54 PM   #48
B-R-Z
B-R-Z's Avatar
It's built into some of the aftermarket cams. I think I read somewhere that you can snip a wire in the cam housing but I haven't tried. I have an aftermarket Android radio that does not add lines.
Old 06-16-2015, 08:35 PM   #49
sdwagonjp
sdwagonjp's Avatar
Drives: 2015 Fr-s Firestorm
Little confused on the head unit knows your backing up if you're just plugging in a camera.
sdwagonjp is offline   Reply With Quote
Old 06-16-2015, 09:28 PM   #50
B-R-Z
B-R-Z's Avatar
There is a wire that tells the radio you're in reverse. This wire also powers the camera.
Old 07-06-2015, 03:10 PM   #51
czechm8
520
czechm8's Avatar
Drives: Series 10 Fr-s #520
So, I installed the Toyota FIT camera in my 10 series FR-S this weekend. I have the Bespoke unit with NAV. Everything went pretty smooth. I installed the jumper wire from the reverse signal at the driver's foot-well to pin two on the 28 pin harness. The 16 pin harness that comes with the kit is used for the video signal and ground, as well as the camera power and ground. The kit comes with the 16 pin pass-through harness and already has the video wires connected to pins 8 and 16. However, they suggest that you use a 12 volt source to power the camera. I noticed that the camera had a voltage choke/regulator on the line, and I suspected that it was to reduce the voltage down to 6 volt.
So I tested the camera with a 6 volt source and it worked perfectly. So, I then utilized the 6 volt power and ground on the 16 pin harness (pins 7 and 15). Made the install a lot easier!
The testing was a little tricky since the HU checks for a video signal on startup, and if it doesn't find one, it disables the 6 volt output and the camera function. Once I had everything hooked up, it worked perfectly. I was initially stumped because I new I had a 12 volt signal on the reverse wire trigger, but I couldn't figure out why the head unit wouldn't switch to the camera input when I put the tranny in reverse.
Anyway, I was wondering, for those that have installed cameras..........where did you run your wiring from the rear trim piece through the trunk lid to get down to the factory wiring grommet at the hinge? My 10 series has the trunk badge wiring and the touch-to-open button all running through a separate hole in the trunk lid, and the keyed release has it's own hole on the right. I mounted my camera on the left side to mirror the location of the keyed release on the right.
I ended up using the supplied hole saw to drill a new hole through the trunk lid as well as the hole for the camera location. I couldn't see any other way to run the wiring through the trunk lid.
This then created the problem of how to seal that wiring connection through the new trunk lid hole, and to keep the wires from chafing on the metal. I improvised and found a rubber cap in my pile of left over parts from other projects that was just larger than the hole. ran my wire through the cap, and then pressure-fit the cap in the hole and sealed it up with some silicon adhesive caulk to seal it up.
By the way, it was a SOB to fish all that wiring through the factory rubber grommet near the trunk hinge. There are a couple connectors on the camera harness, including the voltage regulator that are rather large in diameter and they were a tight fit. I used some WD-40 to aid in pulling them through the grommet.
Also, the FIT camera has the Parking Lines and Reverse Image wires labeled near the camera end of the harness. I simply connected the green (parking lines) wires together to disable the parking lines from showing up on your screen.
Cheers to those who have yet to install their cameras. Hopefully this is helpful.
czechm8 is offline   Reply With Quote
Old 07-08-2015, 09:32 PM   #52
iJeff
iJeff's Avatar
Drives: 2016 Raven FR-S
I really wish there were a thorough install video for this. As someone who has never done anything of the sort before, I'm really lost. The instructions that came with my camera are for the Camry.
iJeff is offline   Reply With Quote
Old 07-08-2015, 11:15 PM   #53
czechm8
520
czechm8's Avatar
That would be nice. You just have to do a little research. There are a couple of threads on this forum. This was a good resource for me as well
http://ae64.com/Rear-camera-16p-operation.htm
Sent from my Nexus 9 using Tapatalk
Old 07-08-2015, 11:17 PM   #54
czechm8
520
czechm8's Avatar
http://www.ft86club.com/forums/showthread.php?t=80555
rydeen mini backup cam
Old 07-09-2015, 12:31 AM   #55
iJeff
iJeff's Avatar
Thanks for that. I'm still not sure about how to do it though. I can build a PC and repair a smartphone but I can't wrap my head around this. If only the camera I got didn't come with Camry instructions.
Old 07-09-2015, 01:52 AM   #56
a_dee
a_dee's Avatar
Drives: '14 BRZ CBS
This was the best guide which helped me install my camera last weekend: http://www.ft86club.com/forums/showp...8&postcount=85
I got the harness from autoharness.com in order to get the 12v supply via relay, and ran the RCA/power wire down the driver's side sill all the way back through the trunk passthrough, then through the trunk release grommet.
'14 BRZ CBS
>>Pretty Stock
a_dee is offline   Reply With Quote
Stock Rear View Camera for Fujitsu Ten? Foobar Electronics | Audio | NAV | Infotainment 151 08-19-2021 11:24 AM
stock brz jdm rear view camera SuperDave Electronics | Audio | NAV | Infotainment 0 04-03-2014 09:53 AM
Rear-view camera/reverse cam. What do you have? joergasm Audio/Visual, Electronics, Infotainment, NAV 0 05-24-2013 12:25 PM
be spoke with rear view camera harness fs xpicer Audio/Visual, Electronics, Infotainment, NAV 1 11-25-2012 02:35 PM
be spoke w rear view camera xpicer Electronics | Audio | NAV | Infotainment 17 10-14-2012 09:26 AM
