Old 01-12-2015, 10:12 AM   #1
jknakes
Drives: 2006 stage 2 sti and 2013 brz
rydeen mini backup cam
i've been reading through the various threads about backup cameras and the raydeen seems to be a popular choice. one thing i'm unsure about is weather it does or does not need any extra harness things to work the brz limited headunit. also i wanted to check if anyone knew if there were any differences between
[ame="http://www.amazon.com/dp/B00GQTYG3Q/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=23TYD CTFBEOBL&coliid=I5G5224BSFTDF"]Amazon.com : Rydeen RYD ZH07150B Universal Mini Camera, CMOS III NightVision Technology : Point And Shoot Digital Cameras : Camera & Photo[/ame]
and
http://www.al-eds.com/Rydeen-Mobile-...0B-p22239.html
in most threads i've seen the link to al-eds so just wanted to know it it came with any extra things that i wouldn't get from amazon.
jknakes is offline   Reply With Quote
Old 01-13-2015, 07:25 PM   #2
Simok
Drives: 2013 FRS
May want to double check but I believe you need a beatsonic harness well
Simok is offline   Reply With Quote
Old 01-13-2015, 07:48 PM   #3
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
Why not just get the Toyota FIT camera system from ebay. Comes w/ everything you need. Or get the beatsonic kit?
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 01-13-2015, 07:55 PM   #4
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
I'm running a Rydeen Duo and harness from http://autoharnesshouse.com/19867.html.
The whole setup runs for about $100 combined and is plug-and-play.
menikmati is offline   Reply With Quote
Old 01-14-2015, 09:06 AM   #5
sluflyer06
Drives: 2014 BRZ Ltd - DGM
Is the Toyota system better? This is the first I've heard of it on the forum myself.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
Old 01-14-2015, 11:07 AM   #6
aznatama
aznatama's Avatar
http://www.ft86club.com/forums/showt...ghlight=camera
FWIW, I didn't know the pinout of the stock wiring, which is the only reason I spliced the power from the other connector. The kit does come with a single black wire w/ pin to be inserted into the correct hole int he factory harness for use as power.
'14 BRZ LTD MT DGM
Old 01-19-2015, 11:28 PM   #7
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
Most cameras (including the Rydeens) do not include [an extra, car-specific] harness, since they're intended to be used with an aftermarket head unit or display unit. Connecting to a factory HU will require an additional harness (which varies with different car models). Some vendors have started offering kits with a harness for a particular car plus a camera.
For your BRZ, you can also use my rear camera harness. With the Rydeen cameras (as well as any other camera that works from 6 Volts [and there are many]), you won't need any additional harness(es) to tap into power from anywhere else, and you won't need a relay. Very easy connections. See the links on that page for more information about how your HU's camera function works, as well as the installation instructions.
SVXdc is offline   Reply With Quote
Old 01-28-2015, 08:42 AM   #8
jknakes
Thanks for the info. I have a co-worker with an frs that's interested in going the same route as me. I assume she would need the same things?
Old 01-29-2015, 02:30 PM   #9
SVXdc
SVXdc's Avatar
Yes, her FR-S will need a camera plus the same type of harness with 16-pin plug. In her case, FR-S also requires that you add a wire with the reverse gear signal to the OEM radio's 28-pin harness plug -- FR-S does not have that signal from the factory. I offer a 4-foot wire with the proper Japanese terminal that you can easily snap into the vacant slot on the car's plug. The other end you must tap into a factory wire in the driver's footwell. See my installation instructions for FR-S.
Old 03-08-2015, 03:54 PM   #10
jknakes
which of your harness versions is the one i'd need for the rydeen?
Old 03-08-2015, 06:21 PM   #11
ARTBRZ
Aloha!
ARTBRZ's Avatar
Question: I bought a camera that only has an RCA ground and an RCA that goes for the video. I also bought a Pioneer Avic X9310BT harness. Will I need to add a wire the reverse signal?
These camera that I bought is COOLINT CT-X102BL
Thanks in advance!
ARTBRZ is offline   Reply With Quote
Old 03-15-2015, 06:09 AM   #12
SVXdc
SVXdc's Avatar
All of mine will work. All versions include the 6V camera power lead, which the Rydeens can use. The "bypass" version is the most popular, and the one I recommend. See my 'camera operation' guide to decide.
Old 03-15-2015, 06:27 AM   #13
SVXdc
SVXdc's Avatar
What head unit was factory installed? Was it not one of the OEM Fujitsu Ten nav HUs like every US BRZ gets? I don't understand why you got the AVIC harness. Do you now have an AVIC HU?
All US BRZ models that I've seen already have the reverse gear signal on the factory 28-pin harness.
If your camera is like most, the HU end of its long cable will end with a male RCA plug for the video output. It should also have power and ground leads, either near the camera, near the HU, or both.
Some cameras simply have an extra red wire embedded in the long video cable (with both ends exposed and not connected). It's the same as if you had taped an extra wire down the length of the RCA cable. It's available for you to optionally send the reverse signal from the trunk to the HU. You can usually also use that wire to send power from the HU back to the camera (and skip tapping into the reverse lights to power the camera).
In the Rydeens, the embedded red wire is already connected to the camera power lead near the camera.
Old 03-15-2015, 01:06 PM   #14
ARTBRZ
Aloha!
ARTBRZ's Avatar
Yup found out the hard way. For some reason I thought the HU is a pioneer. I had to return the harness and I'm waiting for the beatsonic harness.
Rydeen Duo on BRZ Limited sure74 Electronics | Audio | NAV | Infotainment 343 01-22-2019 06:28 PM
Rydeen DUO mini backup camera Raven23 Audio/Visual, Electronics, Infotainment, NAV 9 11-06-2014 04:07 PM
How to wire up with Rydeen Duo Hyperian Electronics | Audio | NAV | Infotainment 6 05-16-2014 03:20 PM
Pioneer HU and Rydeen Duo Camera pauland Electronics | Audio | NAV | Infotainment 5 03-04-2014 05:20 PM
Rydeen Duo installed on a Preimum sparks Electronics | Audio | NAV | Infotainment 9 10-16-2012 05:39 PM
