Old 06-12-2015, 03:13 PM   #1
wootwoot
Drives: FRS
Custom interior questions..
1. I want to bond the radio/dash trim pieces together so I can wrap them as one unit. How is this done? Fiberglass? Do you glue them together in the back with something? I know its hard to get things to stick to plastic...
2. I want to fill the indentation on the center console where the heated seat switches go before I wrap it. Should I use a block of wood and bondo? Is there a epoxy I can poor in it? What's the best method there?
Old 06-14-2015, 02:15 AM   #2
wootwoot
Drives: FRS
No love?
Old 06-14-2015, 03:29 AM   #3
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
No just 2 lazy to type it out.
Clamp the 2 radio halves together, the use a torch/lighter and melt the flanges together. Use a metal spoon/knife/spreader after melting the plastic to push it together. Do this until the 2 halves are one. Then on the front side use a bit of filler/sanding to make it smooth. I personally used duraglass becuase it is a bit stonger than regular bodyfiller.
Block of balsa or pine wood cut to shape, then use fiberglass resin to fuse it to the center console. Finish with filler and wrap.
Old 06-14-2015, 06:12 AM   #4
Jake_86
Jake_86's Avatar
What are you trying to wrap the dash with? Color wise. Is it gonna looks that much better without the gap? And depending on color you might see the difference in colors when bonding it together. They have very nice plaques you can put in that center spot. Or yeah Kia get some spackle shit hah
Gold Accented GT86 Build Thread
Live Fast, Die Young.
Jake_86 is offline   Reply With Quote
Old 06-14-2015, 01:46 PM   #5
toast
Drives: 14 BSP Edelbrock BRZ
Yes
toast is offline   Reply With Quote
Old 06-14-2015, 04:37 PM   #6
xclusive_brett
xclusive_brett's Avatar
Drives: 08 scion xb
just buy my jpm coachworks dash
xclusive_brett is offline   Reply With Quote
Old 06-14-2015, 10:44 PM   #7
tiz22
tiz22's Avatar
Drives: 2013 Scion FR-S (Raven) MT
How much?
My Car Journal: Raven FR-S w/ TRD Flavour
Click for my AVIC Z150BH Head Unit DIY Install
tiz22 is offline   Reply With Quote
Old 06-15-2015, 02:11 PM   #8
xclusive_brett
Drives: 08 scion xb
http://www.ft86club.com/forums/showthread.php?t=88970
Old 06-15-2015, 06:20 PM   #9
Jake_86
Jake_86's Avatar
Originally Posted by toast View Post
Yes
any pics?
Old 06-15-2015, 10:10 PM   #10
toast
any pics?
I don't have any of my car but Jive did this with his before wrapping in alcantara.
http://www.ft86club.com/forums/showp...88&postcount=1
The Following User Says Thank You to toast For This Useful Post:
Jake_86 (06-15-2015)
Old 06-15-2015, 10:18 PM   #11
Jake_86
Jake_86's Avatar
i guess it would prevent tearing in the alcantara/vinyl during removal but idk if it makes much visual difference on the alcantara side. vinyl you might be able to see thru depednign on color.
Old 06-15-2015, 10:28 PM   #12
toast
You mean wrapping it as a single piece without bonding the two halves together? Yeah, that would not be a good idea for any kind of wrap.
GA FS: 2013 FRS, turbo, air ride, custom interior, much more!!!! cb7tuner Cars for Sale/Trade 6 08-18-2014 10:26 PM
Custom Axle back questions cdo221 Engine, Exhaust, Transmission 4 01-05-2014 02:41 PM
2 lighting questions, interior bdanisi Cosmetic Modification (Interior/Exterior/Lighting) 2 10-07-2013 07:15 PM
Custom Interior Panel Set BRZN6 Cosmetic Modification (Interior/Exterior/Lighting) 15 07-16-2013 11:44 PM
custom steering wheel questions. enjoi23 Cosmetic Modification (Interior/Exterior/Lighting) 4 08-31-2012 12:36 AM
