Old 06-11-2015, 02:27 PM   #1
OpteronO3
Drives: 2013 Scion FRS
AT Slipping Issues
I'm a new owner of a 2013 Scion FR-S just recently purchased with roughly 24k miles. Recently I've come across a strange issue figured I would share to see if anyone else is experiencing this. (I looked up a couple of threads in the forum and I didn't come across a similar issue.)
Anyways, I'm cruising at 40mph on 6th gear. I downshift to 4th in regular mode and it'll "not catch" as if it’s having slipping issues in 4th gear until I let go of the throttle. Not until I let go of the throttle, it'll shift aggressively into 4th gear. If I don't let go of the throttle long enough it'll just keep revving.
Is anyone having the same issue?
Originally Posted by FRSBRZGT86FAN View Post
....yours sounds like a serious slip, it could still be a TCM issue
OpteronO3 is offline   Reply With Quote
Old 06-12-2015, 08:12 AM   #2
Shinobu's Smile
Drives: 2010 Tacoma, 2015 BRZ AT Limited
I dont know if it helps, but sometimes i get an issue where ill give it a lot of throttle, the transmission downshifts, the engines revs and then after about 2 seconds it seems to "catch" and accelerate. This is in regular mode (not manual) and scared me a couple of times where traffic was coming up behind me a little fast. Its not exactly the same issue as yours but...
2015 AT BRZ
Shinobu's Smile is offline   Reply With Quote
Old 06-12-2015, 09:19 AM   #3
OpteronO3
Actually that is exactly whats happening. You just explained it better lol. Do you experience this alot?
Old 06-12-2015, 02:53 PM   #4
Shinobu's Smile
Not a lot. It usually only occurs when im about to change lanes to get from behind someone slow and once im in a new lane i have to go almost full throttle to keep from slowing down traffic behind me. I don't do this often, but when i do, it doesn't occur all the time (Maybe 3 times ever, 5000mi total on the odometer). Maybe because it happens in some gears and not in others. I really don't know if its a a mechanical issue or the transmission ECU programming issue but it sometimes scares me when i need it to accelerate and it doesnt. Sorry i cant be of any help.
Come to think of it. My 2010 tacoma (auto) would do something similar i guess. When i slowed down to take a left across traffic, i would give it a lot of throttle and sometimes it would rev the engine and not accelerate for about 1-2 seconds before it finally downshifted and "catched". Turns out, it was a common issue that they had an TSB for. I took it in, they reflashed the trans. ECU and it completely went away.
Old 06-12-2015, 04:09 PM   #5
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
Easy fix, downshift with the paddles then nail the throttle......yes it has happened to me and that's my fix
IceFyre13th is offline   Reply With Quote
Old 06-15-2015, 12:28 PM   #6
Shinobu's Smile
Thanks. Ill try that.
So more issues. bdanisi Issues | Warranty | Recalls / TSB 40 12-03-2014 03:30 PM
FR-S and the clutch is slipping. Where can I get it fixed in Cincinnati? rinnamon Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 24 08-08-2014 09:56 AM
Slipping to left from start when taking off =( HillCountryGuru Issues | Warranty | Recalls / TSB 5 04-19-2014 07:07 AM
Auto Trans Feels like it is slipping... Fett4Real Issues | Warranty | Recalls / TSB 19 01-16-2014 10:02 PM
AT Second Gear Slipping EK_Golfer Issues | Warranty | Recalls / TSB 13 12-23-2013 11:40 AM
