Old 06-09-2015, 06:39 PM   #15
cjd
cjd's Avatar
Drives: 2017 BRZ
Order is the harmonic frequency over the fundamental (fundamental times order is the harmonic)
I don't know what is considered destructive in this case, but the amplitude of the harmonic peaks for each damper are similar - just at different frequencies (since the peaking is both different fundamentals and orders.)
The Following User Says Thank You to cjd For This Useful Post:
fika84 (06-10-2015)
Old 06-09-2015, 09:46 PM   #16
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
This only tells me that Toyobaru got it right from the factory. But hey, I don't know anything.
The Following 2 Users Say Thank You to boredom.is.me For This Useful Post:
Calum (06-11-2015), GT86_PRAGUE (06-11-2015)
Old 06-09-2015, 10:47 PM   #17
Turdinator
Señor Member
Turdinator's Avatar
I managed to track down this PDf about the Fluidampr pulley's development.
1974 TA22 Celica
2013 86 GT
The Following 6 Users Say Thank You to Turdinator For This Useful Post:
ATL BRZ (06-10-2015), Bonburner (10-25-2017), fika84 (06-10-2015), GhostOp86 (12-24-2015), GT86_PRAGUE (06-11-2015), MAPerformance (06-10-2015)
Old 06-10-2015, 10:24 AM   #18
fika84
fika84's Avatar
So does order relate to vibrational modes?
Sort of answered my own question - http://www.physicsclassroom.com/clas...-and-Harmonics the harmonics and the modes are the same it seems.. 1st harmonic = 1st mode.. just a matter of terminology.
fika84 is offline   Reply With Quote
Old 06-11-2015, 06:06 AM   #19
Hector
Drives: Toyota GT86 Satin-White-Pearl
What we clearly see here is OEM performing best.
Glad to see this before someone ordering these needless pulleys. I also expect the ATI pulley not performing different than Fluidampr.
Hector is offline   Reply With Quote
Old 06-11-2015, 07:32 AM   #20
churchx
churchx's Avatar
Drives: 2014 GT86
Wasn't ATI's also undersized, hence turning all the accessory pulleys at slower speeds, hence potentially more gains?
Old 02-14-2016, 07:30 PM   #21
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
Originally Posted by Hector View Post
What we clearly see here is OEM performing best..
But wait!?! What about all those people that said the OEM pulley was NOT a damper/dampener and was "just a pulley"?
Seems like the people who said that "IT IS a torsional dampener and the engineers put it on there for a reason" were right.
justatroll is offline   Reply With Quote
The Following 2 Users Say Thank You to justatroll For This Useful Post:
Cole (10-30-2016), CSG Mike (05-07-2016)
Old 02-14-2016, 08:03 PM   #22
Hawk77FT
Drives: GTS 86
Fluidampr performs slightly better as it is heavier (with a damper as well).
Hawk77FT is offline   Reply With Quote
Old 05-06-2016, 09:58 PM   #23
s0sl0w
Proud of Boxer
So if I'm reading this correctly the fluidamper is probably a good pair with a light weight flywheel or if you plan to turn rpms beyond (such as the 9k element tuning motor) but otherwise it's largely a waste over your stock damper.
s0sl0w is offline   Reply With Quote
Old 10-30-2016, 06:15 PM   #24
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Just installed mine.
The motor definitely feels smoother in high RPMs. Great peace of mine for a frequently tracked 86.
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
DM7 (10-30-2016), Strife26 (07-07-2017)
Old 10-30-2016, 07:15 PM   #25
DM7
Drives: '13 FR-S Argento
How do do the physical dimensions of the Fluidampr compare to the stock balancer? I have the Nameless header that runs up in front of the engine. If the Fluidampr is too thick (measured from the face of the timing chain cover to the face where the writing is on the Fluidampr) it would be very close to the header secondaries. Thanks.
DM7 is offline   Reply With Quote
Old 10-30-2016, 07:18 PM   #26
ATL BRZ
ATL BRZ's Avatar
I don't know. I didn't measure them. You can contact Vibratech and get an answer from them.
Old 10-30-2016, 07:34 PM   #27
Hawk77FT
Drives: GTS 86
Pretty much the same size!
The Following User Says Thank You to Hawk77FT For This Useful Post:
DM7 (10-30-2016)
Old 10-30-2016, 07:56 PM   #28
DM7
Fluidampr has the dimensions on the product page.
OD:: 5-7/8"
Bore Dia:: 0.787"
Length:: 1.62"
Weight / lbs (Rotating Weight / lbs):: 5.8 (3.8)
Fluidampr Damper Pulley 571101 Sale!! Mike@CZP Engine, Exhaust, Bolt-Ons 156 06-01-2018 12:24 PM
Brand New FRS/BRZ Tires and Rims (mounted, balanced) Hamza7 Canada Classifieds 1 05-16-2015 01:12 PM
perfect balanced wheels BRZtoni Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 05-06-2014 11:27 AM
FS: RS*R Sports-i coilover (corner balanced) RYU Brakes, Suspension, Chassis 27 01-09-2014 11:51 AM
Got Corner Balanced and Aligned track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 08-10-2012 12:35 PM
