go_a_way1
Old 06-09-2015, 02:40 PM   #2409
fasteddy
Originally Posted by enivid View Post
I used gravity.
That worked for me too. I did it by accident though, I left the upper line loose on the SC , filled up the system and left it overnight. I would not recommend this as I lost some fluid, but if you kept an eye on it that will work just fine.
Pat
fasteddy is offline   Reply With Quote
Old 06-09-2015, 02:49 PM   #2410
fasteddy
Update after my first track day with the JRSC. Everything worked as expected, no issues whatsoever. No lost fluid, belt issues or overheating. This system appears bullet proof!
I was running 4000-7000 RPM all day without a hiccup! though I did average only 11MPG on the track, ha ha!
The power is amazing. I am back to equal lap times to my prior car (heavily track modified 2005 GTO 500 HP, I spent over five years dialing that car in at this track)
With some better tires I should be even faster. I am currently on MPSS.
Hats off to Jackson Racing for developing such a great kit!
Pat
The Following 7 Users Say Thank You to fasteddy For This Useful Post:
bear89103 (06-09-2015), CSG Mike (06-09-2015), funwheeldrive (06-26-2015), Jackson Racing (06-09-2015), JDMChris (06-09-2015), Jmonty (06-09-2015), JonAvalon (06-09-2015)
Old 06-09-2015, 03:16 PM   #2411
autograph
autograph's Avatar
Drives: 6MT Hot Lava
howdy folks. just had the JRSC installed recently. is it a typical occurence for the lower rpms (1500-2400ish) to feel sluggish? In fact the very first time I drove the car with the SC on it, I noticed that I had to give it more gas upon launch because it started to stall with my normal throttle / right foot habit. seems like something is "holding it back", and that it is not as smooth or "sensitive to input" as NA in the lower rpms. feels like i can't be as gentle with the throttle
that being said this is my second day with the SC on so lol, just my observation. mike @ moto east didn't have time to put me on the dyno, so right now I'm running his base tune I'm presuming from another JRSC customer. told me to street log it which i have to learn how to do
P.S.: i also had the dual catch can radium setup installed
autograph is offline   Reply With Quote
Old 06-09-2015, 03:25 PM   #2412
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
1500-2400 from a stop or any gear?
Mine isn't like that for either.
The Following User Says Thank You to Andrew025 For This Useful Post:
Jmonty (06-09-2015)
Old 06-09-2015, 03:51 PM   #2413
autograph
autograph's Avatar
from a stop it requires more gas and feels like its willing to stall more easily; in gear it feels like it revs less freely at those low rpms
Old 06-09-2015, 04:04 PM   #2414
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
sounds like when he does his custom tune you will get rid of it
Jmonty is offline   Reply With Quote
Old 06-09-2015, 04:28 PM   #2415
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
Yup, Sounds like it is because of the tune.
JDMChris is offline   Reply With Quote
Old 06-09-2015, 05:05 PM   #2416
CSG Mike
CSG Mike's Avatar
Not normal. If you have the opportunity, see if you can find someone local with the CARB tune. It should drive and feel stronger than stock in any condition
Jackson Racing (06-11-2015)
Old 06-09-2015, 06:36 PM   #2417
Xuningshen
Drives: Subaru BRZ
Anybody simply running Delicious Tunings's flash 'n' go tune with their 11 psi map sensor with both cats still in place? they claim about 10 more hp/tq to the wheels. how does it feel?
when i had their tune on my car NA they advanced a hell of a lot of timing or something in the torque dip and it sounded so rattly like the heads were going to explode from 3k-4k lol (to my untrained ear) still it wasn't the greatest noise.
planning on getting rid of the cats towards the end of the year as well but wanna get a different tune soon.
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
Old 06-09-2015, 07:00 PM   #2418
dj2020
I would also like to know too. Are you going flex fuel as well with the DT Flash n Go?
dj2020 is offline   Reply With Quote
Old 06-09-2015, 07:05 PM   #2419
Xuningshen
Drives: Subaru BRZ
eventually. but not at the start. i like putting one part on at a time.
2014 WRB BRZ
The Following User Says Thank You to Xuningshen For This Useful Post:
dj2020 (06-09-2015)
Old 06-09-2015, 08:14 PM   #2420
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
what about speed density tunes excites u?
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 06-10-2015, 07:37 AM   #2421
2ndgenhachi
Drives: 2013 fr-s, sr20 180sx
My oil cooler came in yesterday. Anybody that received the sc kit but no cooler it's on its way! And of course part night at work I was told I'd be working Sat. So no install this weekend.
2ndgenhachi is offline   Reply With Quote
The Following User Says Thank You to 2ndgenhachi For This Useful Post:
dkstylezz (06-10-2015)
Old 06-10-2015, 09:39 AM   #2422
autograph
autograph's Avatar
thanks all for your observations. it definitely does not feel or drive stronger than stock at low rpms, IMO. I'll do some street logs and send them off to Mike @ Motoeast and hopefully with some data we'll smooth things out.
Speaking of which Mike and his full time tech did an excellent job on the install; everything is nice and secure
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
