Old 06-08-2015, 12:21 PM   #43
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
New Rally Season
Preparing for new rally season! This season will see two setups, racing in two different classes. New engine builds for both:
N/A S2000 class (2000cc max): new build with ported heads, cams, and tune.
F/I - Supercharged! Yes, Lucho is putting together a supercharged FA20 for rally! Full engine build with 10:1 compression. More details coming soon.
In the mean time, here are a couple of photos from a recent rally test session, testing out some new Chromoly steel front lower control arms. Big fail! Only lasted 3 minutes on rally course. Ouch!
Circuit Motorsports is offline   Reply With Quote
The Following 2 Users Say Thank You to Circuit Motorsports For This Useful Post:
CxG (08-03-2015), Kostamojen (07-10-2015)
Old 06-08-2015, 02:03 PM   #44
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Ouch!!! What brand where those?
FRSfan111 is offline   Reply With Quote
Old 06-20-2015, 06:19 AM   #45
Stumpygt86
Drives: Toyota GT86. N/A for life
What actually gave way with the LCA?
I will need to chat with you Bob regarding how best to set up the brakes for rallying. I want to remove all of the ABS system and run a bespoke set up. Will this effect the engine (limp mode) and will the Electric power steering be effected by not having speed sensor input.
Love this build and the results you are getting.
Stumpygt86 is offline   Reply With Quote
Old 07-09-2015, 11:23 PM   #46
luchoalayza
Drives: Toyota GT86 2013
Bad luck with the Racer X Fabrication Suspension kit. The ball joint is too weak, I don't know if it's the design, but it lasted 3 minutes.
I'm not using their front arms and their rear aluminium arms. The rest is ok.
luchoalayza is offline   Reply With Quote
Old 10-08-2016, 12:30 PM   #47
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by Circuit Motorsports View Post
The stock throttle body is plenty big for this motor. I believe the larger throttle body results in a reduction of throttle resolution with no power gain.
- Bob
Originally Posted by luchoalayza View Post
The engine is the same FA20, nothing different inside, but outside has:
- TODA Big Throttle Body (Bob told me it didn't do anything)
I am bringing back an old subject, because I am interested. How Bob knows that the throttle body doesn't do anything? Is it just an assumption or are they actual results? Did he had for example a tune before and after this part was installed?
I've installed some Toda parts already, but not yet the throttle body. The rest of their parts are amazing! What I know about their throttle body is that it doesn't have the high rpm issue on idle. This is a common problem on such changes. In fact, some manufacturers couldn't make an actual product because of this problem.
Old 10-12-2020, 11:27 AM   #48
luchoalayza
On 2016 we got a MoTec M1 ECU so we could tune in locally (here in Peru) and we confirmed that the big throttle body didn't do any difference, so it wasn't only Bob's opinion. I'm very sorry that he passed away last year, great guy.
Also on 2016 we changed the supercharger for a Full Blown Turbo Kit, also from Circuit Motorsports. They made the shortblock with forged and special parts, really an awesome job. We managed to boost it up to 330whp at 21psi, but we prefer not to go any higher because it is not intended for track day, but for rally use. On gravel I boost it down to 8psi (about 260whp) in order not to loose traction. You can find many pics and vids on my facebook and instagram, both @alayzarally
The Following User Says Thank You to luchoalayza For This Useful Post:
Turdinator (10-13-2020)
Old 10-12-2020, 03:32 PM   #49
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Lol. Got a reply after 4 years. Yeah I confirm that a bigger throttle body is just for better throttle response.
GT86 CS-R3 Rally Car - pics and pricing announced mav1178 Tracking / Autocross / HPDE / Drifting 16 08-25-2014 02:31 PM
My photos from WRC Rally Finland 2014 rumors Other Vehicles & General Automotive Discussions 2 08-06-2014 05:33 PM
Toyota GT86 CS-R3 rally car update mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-01-2014 11:17 PM
Toyota announces GT86 CS-R3 rally car Whitigir Scion FR-S / Toyota 86 GT86 General Forum 9 11-20-2013 10:27 AM
BEST EVER Mitsubitshi Evo Rally POV Video. LS13 Off-Topic Lounge [WARNING: NO POLITICS] 1 08-20-2013 08:43 PM
