Old 06-04-2015, 02:21 PM   #1
denso
Drives: 86
detecting knock on stock ecu
Hi, I'm daniel from germany and I have a few questions. I'm going do FI my GT86 to about 8psi and I want to tune the ECU on myself. I got a external AFR-gauge and EGT-gauge and display them via the Zeitronix LCD. I'm editing ROM-files via RomRaider/ECUflash and my question is, how can I log/show the knock detection? I want to tune the ignition timings but I dont know how to see if the engine is knocking.
greetings
denso is offline   Reply With Quote
Old 06-04-2015, 02:36 PM   #2
Illuminaughty
Drives: 2013 Subaru BRZ Limited 6MT
Welcome bud. If you're already editing ROM-files and pulling logs, this should help immensely.
http://www.romraider.com/forum/topic1840.html
Edit: Keep in mind this is older and we're on a 32-bit ECU, so our IAM is 1 if there's no rough knock compensation and any lower than 1 means timing is being retarded. So instead of 0(bad) - 16(good) our scale is simply 0(bad)-1(good).
Illuminaughty is offline   Reply With Quote
The Following User Says Thank You to Illuminaughty For This Useful Post:
aagun (06-04-2015)
Old 06-05-2015, 12:34 AM   #3
steve99
Drives: FT86
greetings
you can log knock parameters to the memory car in Tactrix see the Tactrix link below for the required logcfg.txt file for G series rom assume your using A01G rom.
If you want to see knock realtime then that is a problem.
you can use "Techstream" via Tactrix adapter and it will show some knock parameters realtime.
you might also want to talk to @ztan he has tuned his own turbo 86 using Taxtrix/ecuflash opensource.
see also the links on knock below
Old 06-05-2015, 03:38 AM   #4
denso
Drives: 86
Thanks for your help guys. I want to see knock in realtime but actually I can only log and thats not the way how I want to tune my ECU
I forgot the techstream.... I have a Toyota-Notebook with techstream on it..... Thanks.
It would be great if @ztan could share his experience. (boost, timings, fuel...)
I'm on 102 Octane Gas (Aral Ultimate 102).
Greetings
via D5503
Old 06-05-2015, 05:11 AM   #5
steve99
Drives: FT86
Greetings
via D5503
I am sure ztan will help you
he has also written some hybrid speed density code for A01G rom
http://www.ft86club.com/forums/showthread.php?p=2214586
see also the roms here for sbd turbo kits running 7-9 psi on USA 93 petrol, very similar to gready kit aparantly
you could compare tables your 102 ron is probably close to usa 93 aki ( r+m)\2 fuel
http://www.ft86club.com/forums/showthread.php?t=70073
Old 06-05-2015, 02:15 PM   #6
denso
Drives: 86
Thanks for your help @steve99
I totally forgot TechStream.....
Is it possible to convert the ROMs to .cuw File?
Old 06-05-2015, 05:56 PM   #7
steve99
Drives: FT86
Not sure what .cuw file is is that techstream flashing format ?? , but i have no info on converting, best to use tactrix ecuflash.
Knock Control Learned is not knock it is value in Knock Correction max A table multiplied by IAM and FLKC.
for knock you want
IAM IgnitioncAdvance Multiplier
Feedback knock control FBKC
Fine Learning Knock control FLKC
Old 06-05-2015, 10:21 PM   #8
ztan
Drives: Toyota 86
Greetings
via D5503
pm me with your contact and I'll send you what I've got.
T518Z at 0.65 bar to redline on 98RON (poor). Minimal knock correction in closed loop part throttle areas, no knock WOT up to redline. A01G base ROM
I'd put it to you that our ECU reacts so quickly that even if you had a knock indicator on the dash, timing would be pulled many revs before you could react to lift your foot. Human reaction time from visual cue to foot lifting would be 0.4s at best (40 revs at 6000RPM) assuming optimal conditions where you were watching for it and not watching the road - in reality probably much longer.
Merp (search merpmod) had some code for getting knock indicated via the CEL in other Subaru models - may be helpful for what you want.
I am quite happy using logging and MatLab analysis to tune. Techstream too slow (0.200s for more than a few parameters). I'm using Tactrix - 0.075s sampling interval with a lot of parameters, 0.050s interval with less.
http://www.ft86club.com/forums/showthread.php?t=76777
ztan is offline   Reply With Quote
Old 06-05-2015, 10:24 PM   #9
ztan
Drives: Toyota 86
ps: What is your FI setup?
Old 06-06-2015, 07:50 AM   #10
denso
Drives: 86
Thanks man!
I will running a custom kit by my own.
Wich version of ECUflash do you guys use?
via D5503
Old 06-07-2015, 07:08 PM   #11
ztan
Drives: Toyota 86
Thanks man!
via D5503
Which turbo? Are you on A01G ROM stock?
Running EcuFlash 1.44.4018
Old 06-08-2015, 02:43 PM   #12
denso
Drives: 86
I'll go with a RB25DET Hybrid Turbo with Garrett GT2860 internals.
Yes, I'm on A01G stock and I'll go with A01G with FI @ztan
via D5503
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 10:09 PM
FR-S Rod knock pozer Issues | Warranty | Recalls / TSB 95 11-03-2015 09:39 AM
OBD2 not detecting but vent gauge working Howardwei Software Tuning 1 05-26-2014 02:24 PM
ECUTek detecting car Deadspool Software Tuning 10 12-18-2013 12:25 PM
As all our cars are pretty much brand new!! Motion Detecting Dash Cams!! eddieEndo Scion FR-S / Toyota 86 GT86 General Forum 22 02-28-2013 03:42 PM
