#3403 |
Drives: 2022 BRZ Limited
for those who might be interested.
this is my friends' Kraftwerks powered NC Miata vs my KW BRZ, on the same dyno... both tuned by mike from moto-east notice the early torque advantage of the NC motor
#3404 | |
WRX -> BRZ. (TX)
Drives: 2015 Series.Blue WRB
Started at 55hz. After 2 weeks, it was at 37hz. Just tightened it to 61hz. All according to the gates app. Just as others mentioned, I'm not too shocked. I'll report back when I check in another 2 weeks if anything has changed.
KraftWerks c3094 SC Kit ARK GRiP w/ test pipe KW V3 OEM Audio + Reference 400CF |
#3405 | |
Drives: 2013 FR-S Matte Orange
#3406 |
Drives: 1996 ST204, Series 10 FR-S
Has anyone successfully tried the 90mm pulley on the C30 besides Kraftwerks themselves?
#3408 |
Drives: 4-Runner Sport - 13' BRZ SportTech
I'm helping a buddy of Mine with his kraftwerks Kit... He ordered a 90mm pulley upgrade but when he went to install it, the existing Sc pulley is 75mm. He's confused as hell, and I don't have any experience with the KW kit. Any suggestions? Did they send him the wrong pulley?
Top Tier Imports - Check out my build journal HERE
#3409 | |
Drives: 2013 Ultramarine FR-S
#3410 |
I'm assuming they're using a larger crank pulley too?
#3411 |
#3412 |
Drives: White scion frs
#3413 |
Drives: '13 FRS
Are those for the c30 or the c38?
Sent from my SM-N900P using Tapatalk |
#3415 |
@John92
have you ever felt the difference between the two pulleys? I am hoping to get a little more omph in the 2000+ rpm range. I have the updated pulleys and might consider the 90mm one. Does the high boost require fueling upgrades? Already have a moto-east tune. I'd probably have to get a tune again unless it has higher boost built into the map. |
#3416 |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I think if you superimpose the dynos from the normal pulley to the "high-boost" setup, most if not all the gains will be in the top-end, not down at 2000rpm. I recall the power above the stock pulley started around ~6000hp and peaked with a +25hp peak bump.
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
