Southern California SoCal
Old 06-05-2015, 11:00 AM   #1
JG
JG's Avatar
Drives: Whiteout FRS
CA Smog Check??
I've been living in San Diego for 2 years now with my 86 and I currently have Invidia N1 catback w/ midpipe. I am at the point where I want Aftermarket header (MXP to be exact). Would i run into problems getting a smog check and when do i have to get one?
JG is offline   Reply With Quote
Old 06-05-2015, 11:03 AM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
You should be fine unless you throw a CEL with the header. They don't drive the car anymore, they just plug it into the OBD 2 port.
N1rve
Old 06-05-2015, 11:09 AM   #3
JG
JG's Avatar
I was going to tune it with the headers. So i guess i'll run into a problem huh.
Old 06-05-2015, 11:22 AM   #4
8R6
8R6's Avatar
Drives: FRS
depends on the smog shop, but chances are most shops will still fail you on the visual test even if the OBD2 test passes. the BAR has been cracking down hard on smog stations, so it's harder and harder to find a shop that will bend the rules even a little bit since their licenses are on the line.
8R6 is offline   Reply With Quote
Old 06-05-2015, 12:12 PM   #5
86_Insider
86_Insider's Avatar
^they will check any aftermarket parts on the car for CARB stickers and then run the # on it to be sure it is for that exact veh. It is rough in California
86_Insider is offline   Reply With Quote
The Following 2 Users Say Thank You to 86_Insider For This Useful Post:
8R6 (06-05-2015), Hyper4mance2k (06-05-2015)
Old 06-05-2015, 12:31 PM   #6
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
You will not be fine. Almost every smog shop in CA does a thorough visual inspection looking for aftermarket parts and SMOG exempt stickers.
You have 5 years from build date before the vehicle has to be smogged.
Your best bet is to keep the stock manifold to swap back in when it's time for inspection.
You however can be cited for driving with a modified header or removed cat.
Risk v. reward.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 06-05-2015, 01:11 PM   #7
86_Insider
86_Insider's Avatar
Risk v. reward.
Yeah this citation isn't fun. It is called a REF ticket it is usually $800-$1000 and requires you to go to the BAR to have the car smogged and certified. You can't go to just any smog shop for this one. I have had 2...so I would know....
EAGLE5 (06-05-2015), Hyper4mance2k (06-05-2015)
Old 06-05-2015, 01:18 PM   #8
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
I had one -for a modified intake manifold- in my Rx7 that was registered out of state. I went in for an inspection just for the hell of it, & the car was labeled a gross polluter and is not allowed to be registered in this state(one of my life's greatest accomplishments). In the end the ticket cost me just under $900. Also why I know that it doesn't matter what state your car is registered in, if it is operating on CA highways it needs to meet CA laws.
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
Lav (07-09-2024)
Old 06-05-2015, 01:31 PM   #9
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Can't you swap back to stock prior to it being inspected?
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 06-05-2015, 01:39 PM   #10
8R6
8R6's Avatar
Drives: FRS
yes and that is recommended. if not, the above advices is more of a warning to others of the high chance (almost guarantee. lol) of failing.
Old 06-05-2015, 01:52 PM   #11
Phantobe
Phantobe's Avatar
Kinda off topic-ish.
But I wish someone would design a heat shield (similar to OEM) for aftermarket UEL headers. With that I think you would pass a visual inspection.
The Following User Says Thank You to Phantobe For This Useful Post:
Lav (07-09-2024)
Old 06-05-2015, 01:58 PM   #12
86_Insider
86_Insider's Avatar
Yes you can swap back and you should. Just want to make it clear a smog shop will not cit you for a ref ticket only fail your smog test that time. All that means is you would need to do something to correct the issue and come back and pay another $50 to test again. ONLY A POLICE OFFICER CAN CIT YOU A REF TICKET
The Following User Says Thank You to 86_Insider For This Useful Post:
Lav (07-09-2024)
Old 06-05-2015, 02:02 PM   #13
Phantobe
Phantobe's Avatar
Ok, so if you were cited a ref ticket...
You have to immediately go get your car inspected? Thus failing if you're aftermarket? Is there no time buffer lol?
Old 06-05-2015, 02:06 PM   #14
86_Insider
86_Insider's Avatar
Car is illegal to drive if you are cited. It would be impounded if pulled over again without fixing everything
Will headers cause me to not pass smog? 67corvette Engine, Exhaust, Transmission 39 11-13-2018 11:12 AM
WARNING!!!! Monday 1/26 CHP SMOG check in Orange County-Cross streets-Lambert/Idaho continuecrushing Southern California 13 01-26-2015 11:19 PM
Smog check and visual inspection help Corradooo Northern California 24 05-19-2014 11:57 PM
Smog & Tunes? fooddude Software Tuning 5 04-14-2014 04:18 AM
SMOG Issues SkullWorks Engine, Exhaust, Transmission 8 10-04-2012 01:23 PM
