Old 04-10-2014, 06:49 PM   #1
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Smog & Tunes?
When smog time comes around..would a reflashed tuned ecu (ie: ecutek, etc.) be a problem?
Leave as? ...or, reflash back to stock?
(Cali smog in particular)
fooddude is offline   Reply With Quote
Old 04-10-2014, 10:05 PM   #2
arghx7
Drives: car
Remind me... when you willhave to get the car smogged, are they going to hook up a tailpipe sniffer to it? Or is it just a visual inspection and plugging in to check for OBD readiness and error codes?
If you are literally just going to have a reflashed ECU only, you can flash back to stock. If there's a tailpipe test, that will probably be ok as long as you don't get rid of all the cats. The visual inspection though, you're at the mercy of how strict the inspection station is.
arghx7 is offline   Reply With Quote
Old 04-10-2014, 10:22 PM   #3
Brick
Drives: White 2013 FRS
In CA there is the OBD check and the visual test if you have nothing that would fail the visual there shouldn't be anything in the OBD to fail. I had heard that they were collecting a database of ECU parameters to ensure you can't trick the ECU into never failing the car but that was in a magazine at the beggining of last year. You would have to ask a smog tech for a 100% answer.
Brick is offline   Reply With Quote
Old 04-11-2014, 12:27 AM   #4
fooddude
Correct me if I'm wrong ..but a lot of NA tunes currently out there, make your car run smoother, more efficient, etc., etc (hence, more horsepower)...so, theoretically, would this make the car run even cleaner than stock during sniffer tests too?
Old 04-11-2014, 10:19 AM   #5
arghx7
Drives: car
The sniffer tests I'm familiar with for California cars are iirc at idle, 20mph, 40mph. They're all steady-state warmed up operation. A tune probably isn't going to change the emissions in those conditions if all the parts on the engine are stock.
Old 04-14-2014, 04:18 AM   #6
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Side question.. If we go in with e85 would we pass smog? It is a "cleaner" fuel afterall.
l0aded is offline   Reply With Quote
Will headers cause me to not pass smog? 67corvette Engine, Exhaust, Transmission 39 11-13-2018 11:12 AM
Perrin inlet hose and smog fduboss302 Southern California 2 04-05-2014 02:50 AM
SMOG Issues SkullWorks Engine, Exhaust, Transmission 8 10-04-2012 01:23 PM
Question about smog checks/emissions showbe Scion FR-S / Toyota 86 GT86 General Forum 3 09-28-2012 12:03 AM
Speedhunters - TRD TUNES THE 86 quik1987 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 69 05-22-2012 04:26 PM
