Old 06-04-2015, 08:15 PM   #1
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
Electronic Boost Controller
im getting a fullblown turbo kit soon
decided to get a electronic boost controller
im very new to turbos..
which brand do you think i should purchase
the gauges im purchasing will be
AEM FAILSAFE
and Innovate OilTemp/Pressure gauge
i noticed Perrin sells a EBC was wondering if thats any good. i havent seen anyone on this forum mentioned anything.
willing to take any recommendations!
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 06-04-2015, 10:16 PM   #2
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Don't. Judging by your post your new to forced induction. Stick with a manual boost controller until you learn the workings of your kit; or go with an EBCS (electronic boost control solenoid) which will run off the ECU. Grimspeed and Infamous make a plug'n'play one for our car (requires tuning FYI.) You may find ecutek's map switching (via the cruise control toggle) and a few different setting perfect.
A good electronic boost controller like the HKS EVC will give you tons of setting and variables that can easily be messed up if you don't know what your doing. Keeping it simple until you understand the working of a turbo setup and can troubleshoot the problems/challenges you WILL encounter would be my advice. Not to be mean or scare you but, if you accidently overboost it very will may cost you an engine.
Old 06-04-2015, 11:08 PM   #3
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
i was thinking of a simple EBC like infamous or perrinproboost controller since it looks like a simple plug and play and the tune will pretty much determine my boost am i correct?
Flex Fuel Turbo BRZ
Old 06-05-2015, 09:08 AM   #4
FRSCanuck
Drives: Scion FRS
AEM FAILSAFE
have you considered the SCG-1 from innovate?
http://www.innovatemotorsports.com/products/scg1.php
Cheers,
Kelvin
FRSCanuck is offline   Reply With Quote
Old 06-05-2015, 10:39 AM   #5
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
i was thinking more into the iinfamous now or the grimspeed
3port electronic boost control solenoid considering it seems more simple
and easier to just install and forget in a sense and have my tune adjust my boost for me.
i been searching throughout the web and cant find an exact model of the grimspeed for my vehicle. does anyone have a link or @GrimmSpeed can assist me with this?.
Flex Fuel Turbo BRZ
Old 06-05-2015, 12:15 PM   #6
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I got a moderately better boost curve with a GFB EBC versus a Grimmspeed MBC. If you aren't utilizing features like boost by gear or boost by RPM, then I would probably stick with a MBC.
Old 06-05-2015, 12:20 PM   #7
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Get the grimmspeed EBCS and a good tuner. It's really accurate and it's a joy to change boost with a flick to the cruise control stalk anytime.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
GrimmSpeed (06-05-2015)
Old 06-05-2015, 06:22 PM   #8
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
I decided to purchase the grimmspeed EBCS.
thanks for all your help and advise
Flex Fuel Turbo BRZ
The Following User Says Thank You to BRZtoni For This Useful Post:
Sportsguy83 (06-05-2015)
Old 06-08-2015, 09:38 AM   #9
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Make sure you get with your tuner and install it properly and the tuner is familiar with it.
Old 01-21-2018, 01:38 PM   #10
Dogster70
Dogster70's Avatar
Drives: 2013 Scion Frs Whiteout
Where can I purchase one?
Dogster70 is offline   Reply With Quote
AVO DBW electronic throttle controller Setup AVOturboworld DIY (Do-It-Yourself) Guides 22 03-31-2016 06:11 PM
Grimmspeed 3 port Electronic Boost Controller crazyfrenchbiker Engine, Exhaust, Bolt-Ons 12 03-19-2015 10:35 AM
Digital boost gauge w/ vent pod grim speed boost controller Meetjoeblack Engine, Exhaust, Bolt-Ons 0 03-09-2015 01:27 PM
Electronic Boost Controller Issues 1BadFA20 Forced Induction 1 06-09-2014 01:21 AM
