Old 06-03-2015, 10:01 PM   #1
Devante
Crescent fresh at best.
Devante's Avatar
Drives: 2016 Scion FR-S - Asphalt
[QUESTION] Aftermarket lights and needing stock HID?
What I want to know I want to buy aftermarket lights for each part: Winjet (style?) headlights, Valenti REVO or TOM's rears, Valenti third light, Secret 86 sidemarkers, fog lights (any suggestions?) , and finally front indicators (ones above the fog lights).
But I see now and then lights mention they need you to have basically the upgraded model in order to use HID headlights, etc.
My question is can someone explain this to me a little more so I don't buy something I can't use? I plan on getting the base model FRS with no upgrades. Is there any way around this?
Thank you!
Devante is offline   Reply With Quote
Old 06-03-2015, 11:48 PM   #2
LED86
LED86's Avatar
Drives: Black 86 GTS
The Valenti headlights are only suitable for HID model cars which means it has a 8pin connector. The halogen model frs has a 6pin connector. So that's your first issue and would require custom wiring to work. The next issue is the Valenti headlights don't come with the HID bulbs or ballast, it is expected your transfer these items from your factory HID headlights. So you will need to source these parts. In theory it can be done and someone has already, but these are the things preventing you from being plug-n-play.
The new Valenti revo tail lights probably won't be released until next year.
Apart from the Valenti headlight headlights, the rest you listed shouldn't have any main challenges to install.
LED86 is offline   Reply With Quote
Old 06-04-2015, 07:59 PM   #3
Devante
Devante's Avatar
Thanks for the answer.
One thing, though: I won't be getting Valenti headlights. I'll be getting either the Winjet or the Spyder headlights.
I watched the fteightysix videos on them and I THINK they are meant to work with non-HID FRS models. Gonna write them to make sure, first.
Side note: anyone ever see those Spyder headlights without the turn signal but with the halo eyes? I've seen pictures but never can find them online without the turn signal along the bottom.
I guess basically I want the Winjet style with halo/angel eyes.
Old 06-04-2015, 11:02 PM   #4
LED86
LED86's Avatar
For the other headlights like Winjet, spyder, specD they are made for the frs and have a 6pin connector and halogen bulbs. You can fit hid kits into these types.
Old 06-05-2015, 11:04 AM   #5
Devante
Devante's Avatar
Thanks again for the answers. :>
Old 06-05-2015, 01:44 PM   #6
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Keep this in mind: just because HID bulbs fit the FR-S version, doesn't mean it's correct. HIDs in a halogen projector will blind oncoming traffic.
Old 06-05-2015, 02:44 PM   #7
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
There's no option without the turn signal for the spyder headlights but the turn signal does not have to be wired up. I have the non angel eye version of the spyders they're great.
While this is correct the projector on the spyders is great with HIDs after adjustment cut off is sharp and light out good
Needing coilover opinions Thekaylakrunkk Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 02-20-2014 11:29 AM
BRZ Stock Head Unit + Aftermarket Amp + 3-way Components question daforce007 Electronics | Audio | NAV | Infotainment 13 04-14-2013 05:42 PM
Are there any aftermarket Fog Lights for the FRS yet!?!? TheFRSChick Cosmetic Modification (Interior/Exterior/Lighting) 40 04-10-2013 04:14 PM
FS: Aftermarket tail lights, stock sway bars, etc Zangetsu Australia Classifieds 19 02-16-2013 02:34 AM
So what horsepower level are people needing to upgrade the injectors/pump? seven Forced Induction 24 01-02-2013 12:28 AM
