Old 05-27-2012, 09:45 AM   #15
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
If you want to go super low and mess with your ride height they yeah, BCs or similar will definitely make it happen.
Coilivers are just starting to come out though. For those not in a big rush you might want to wait for Fortune Autos, or Tein Monoflexes, or Stance GRs or who knows what else.
Personally I'm not planning on top shelf coilivers either (not planning on competing for titles with this car) but whatever I do get will need to be a proven setup. Am keeping an eye on the TRD dampers, RCE coils & whatever Whiteline will be doing to correct geometry.
YMMV and all that. Best of luck!
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 05-27-2012, 12:24 PM   #16
fatoni
Originally Posted by Scooby South View Post
I just secured the most AWESOME Coilovers ...Top Shelf Stuff...KONI 2812's Adjustable Rebound and compression. inverted front Struts...and Custom Valving....Vorshlag Camber plates and 4 sets of Springs... They were Used...but are Freshly rebuilt with new technology seals and oil... these should fill my bill nicely for National Level Autocross that I have planned for my BRZ... Pic for Reference only...BTW^^^^ I too am a Suspension Snob..
Bill
used frs coilovers?
Old 05-27-2012, 12:47 PM   #17
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Originally Posted by fatoni View Post
used frs coilovers?
Used Subaru Legacy Coilovers..... Brian at AST made them...for Phoenix Racing and Spec B Leggy in 2009/10... same mounting points as the BRZ/FRS...just have to get the sway bar bracket fabricated for the front...and make sure the valving/spring rates do what I need them to..
Bill
Scooby South is offline   Reply With Quote
Old 05-27-2012, 12:51 PM   #18
Scooby South
Conedancer
You guys will learn...Subaru is pretty much like Tinker toys...theres ALWAYS some crossover from one model to the next......Ie: Rear Suspension is GR/Leggy... sooo theres always some options..the aftermarket will figure out that they can fabricate a sway bar bracket on some of the same model stuff they have already to avoid HUGE redesign costs...which isn't necessary..
Bill
Old 05-27-2012, 01:13 PM   #19
Scooby South
Conedancer
the sway bars are another piece that can be interchanged... the Stock BRZ/FRS rear sway is 14mm...a Stock WRX rear Sway is 16mm..and a Stock STi 08-10 rear sway is 18mm and 19mm for 11 and up STi...these are all for the rear.. ..
so you see what I mean..
Bill
The Following 2 Users Say Thank You to Scooby South For This Useful Post:
civicdrivr (05-27-2012), Matt Andrews (05-27-2012)
Old 05-27-2012, 01:13 PM   #20
ultra
Curious cat.
ultra's Avatar
Economies of scale FTW!
The Following User Says Thank You to ultra For This Useful Post:
Old 05-27-2012, 01:39 PM   #21
Matt Andrews
Matt Andrews's Avatar
Drives: race cars
great info scooby South. I am not a subaru guy, but I figured this data would be out there. I am wondering if the camber curve correction and bump steer kits available on previous subarus will work here to correct lowered suspension geometry. Is there a central repository for this data yet?
Thanks for the data on the sway bars btw. I'd like to get a pile of parts together and spend a day at the track getting a setup that works. Maybe a couple other socal members here will want to help out trackside for the testing and interchanges?
Matt Andrews is offline   Reply With Quote
Old 05-27-2012, 01:54 PM   #22
Racecomp Engineering
2008 to 2010 STI rear bars are 18mm too, so that's another option.
- drew
Scooby South (05-27-2012), ultra (05-28-2012)
Old 05-27-2012, 05:09 PM   #23
fatoni
Bill
so do you think the shock travel is going to be the same? also what spring rates do you have in mind?
Old 05-27-2012, 05:17 PM   #24
Scooby South
Conedancer
Yes I do actually... AST and Vorshlag has indicated that the stroke and dynamic travel is within tolerable levels.. Words from Brian, "They are almost identical..."... soo..if a Professional tell me that ...its good enough for me....
Spring rates I am looking at ...5.5k Squared, 5k front/5.5k rear...6k front/6.5k rear...they should be close to what a Miata is running...lots of testing to do for sure..
Bill
Old 05-27-2012, 05:22 PM   #25
Scooby South
Conedancer
Its going to be completely different for Bump steer on this car...as it is a Rear Steer Vehicle...meaning it will toe-in on the camber curve..used to be it toed out because all Subaru up to this point were Front Steer cars...so you would get Toe out...makeing turn-in kinda hinky...thus the bumpsteer kits kinda controlled that..
Bill
Old 05-27-2012, 06:39 PM   #26
fatoni
Bill
good to know and i guess since the fronts are struts running something squared like that would probably put you in the ballpark despite the fact that ast is using slightly higher than 7kg/mm in the rear for their miata shocks
Old 05-27-2012, 06:49 PM   #27
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Not necessarily, the Subaru engineers had the option of giving the bumpsteer curve whatever shape they wanted, regardless of where the steering arm is. If the wheels are toed-in in bump, it isn't because of the steering arm location.
old greg is offline   Reply With Quote
Old 05-27-2012, 06:51 PM   #28
Scooby South
Conedancer
hmmm interesting...now that I think of it...with the flipped lower Control Arms...that minimizes that effect....Good Call
Bill
Tein Street Advance BRZ/GT-86/FR-S Coilovers Released in Japan JSC Speed Suspension | Chassis | Brakes -- Sponsored by 949 Racing 76 08-13-2014 08:50 AM
KW V3 Coilovers Released for FR-S / BRZ kanundrum Suspension | Chassis | Brakes -- Sponsored by 949 Racing 116 03-16-2013 07:36 PM
>>>> KW Variant 3 Coilovers ~ Now Available for FR-S and BRZ !!!! Circuit Motorsports Brakes, Suspension, Chassis 56 10-25-2012 02:55 PM
Enjuku Racing - KW Variant 3 Coilovers - * ON THE SHELF * Enjuku Racing Brakes, Suspension, Chassis 0 05-25-2012 03:25 PM
coilovers or springs? koyv90 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 04-01-2012 08:49 PM
