Old 06-03-2015, 11:08 PM   #1
LikeMike86
Drives: 96 Ek Hatch, 2015 Scion FRS
FRS - Front Camber Issue HELP
Hello there
I bought a 2015 FRS about 3 months ago. I was omw home 2 weeks ago and hit a curb going at about 30 mph. My whole lower control arm and stabilizer link got messed up, the car was not drivable. I took matters into my own hands, which might of not been wise and flat bed the car home. I ordered the parts straight from the dealer and had my mechanic install them. Didnt want to get insurance involved. The car drives fine, but the steering is a bit off . So i went to go get the car aligned today at the dealer and the mechanic told me it wasn't possible due to the car having camber on the front passenger wheel. What should i do. Any help is appreciated.
LikeMike86 is offline   Reply With Quote
Old 06-03-2015, 11:14 PM   #2
F3RGY68
F3RGY68's Avatar
Drives: FR-S 10 Series MT, Honda 919
Another part needs replacement or adjustment. You can try to get by as is by tightening the tie rod, and loosening the strut bolts, pushing the bottom of the tire in, and tighten. Ideally you should take a closer look at the entire strut assembly, and check torque specs.
F3RGY68 is offline   Reply With Quote
Old 06-03-2015, 11:14 PM   #3
gramicci101
Off Topic
You may have tweaked the frame where the lower control arm attaches.
What were his measurements for that wheel? Camber, caster, and toe.
Old 06-03-2015, 11:20 PM   #4
LikeMike86
I didn't get the measurements, but I will be taking it to my mechanics shop to have it looked at closer. Thanks tho for the help.
Old 06-04-2015, 12:46 PM   #5
8R6
8R6's Avatar
Drives: FRS
did you check to see if the strut's lower mount got tweaked too?
8R6 is offline   Reply With Quote
SPC Camber Bolt Issue breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 54 02-20-2021 10:22 AM
Issue with camber plate ZionsWrath Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 08-02-2015 06:04 PM
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 02:10 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
