#85 |
Drives: DGM BRZ 6MT
I finally got a multimeter and tapped it into the ESC, but the controller isn't working... Not sure what to check..
#86 |
Drives: Firestorm FR-S AT
How do you have the multimeter wired in?
Phantom Electric Supercharger with Procede controller, GReddy SP Elite, CA-FI Dashlinq4
#87 |
Drives: DGM BRZ 6MT
Haha, I meant I tapped the procede controller to the ESC
#88 |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Did you check which wire you were tapping? Sent from my iPhone using Tapatalk
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#89 |
Drives: DGM BRZ 6MT
Good news, I removed all of the taps and retapped the wires. It turns the power wire and the ESC wire weren't tapped properly. These taps are HORRIBLE. I manually stripped out the plastic so reveal the bare wires before retapping them. Now my laptop can connect to the procede controller via the software. I also checked to make sure the two green wires were tapped correctly.
Now for the bad news. It still isn't working. The software now reads the live RPM and the blue cell moves up/down left/right when I drive. But when I tap on the throttle, the yellow cell doesn't move left/right. This means the throttle sensor wasn't tapped correctly? Does anyone know which colored wire is the throttle sensor wire (the green wire in the first connector or the white wire in the third connector)? It's a PITA to go down there and pull out the ECM wires again, but I think I'll need to do it for the third time... Is there anything else that would cause the yellow cell to not move? Honestly, I'm kind of frustrated at this whole process. I wish I haven't bought the procede controller and stuck with the WOT switch.
#90 | |
PROcede ESC User Software!
TM the yellow square doesn't move. As long as the blue square is moving you are good. The yellow square is for editing cells. Also the installing the procede on the v2 kits is a lot easier than the old kits. Sent from my iPhone using Tapatalk
#91 | ||
Drives: DGM BRZ 6MT
Anywho, the blue cell moves up and down, and also left and right, but my ESC still doesn't engage. The voltage on my voltmeter never drops and the OFT logged 0psi boost.
#92 | |
Shiv made a mistake on the color. Its supposed to be the blue that moves and you manually move the yellow to edit cells. As for the engagement I think you may have tapped the wrong wire for the esc. Sent from my iPhone using Tapatalk
| The Following User Says Thank You to Sojhinn For This Useful Post: | TM (06-04-2015) |
#93 | |
Drives: DGM BRZ 6MT
Thanks. I'll just the ESC wire again tomorrow when the sun rises (street parking nowadays). At least that wire more accessible. My multimeter read 5.xx volts for it, though. On a side note, it's been 2 weeks since I brought my car to San Francisco and someone already stole my antenna. Why would anyone steal a stock antenna... Sent from my iPhone using Tapatalk
| The Following User Says Thank You to TM For This Useful Post: | Sojhinn (06-04-2015) |
#94 |
Drives: DGM BRZ 6MT
I just spliced the wires together and I think it's working.
I had my friend sit in the car while I was driving with the procede software and he said the blue cell moves into the green areas. But my OFT only shows about 0.7psi max. Is that normal?
#95 | |
Not on my car. Load my tune to be sure? Sent from my iPhone using Tapatalk
#96 | |
Drives: DGM BRZ 6MT
Maybe I'm using my multimeter wrong. Rob said I need to set my meter to 20v or 5v and measure the two leads from the ESC wire. I can't set that on my multimeter and just turned it on to the mode that says "10 MegOhm input, DC V". Is this correct? Anywho, I'll strip some more of the ESC wire and try splicing in the other lead instead to see if that'll make it work.
#97 | |
Yeah you should be only using 1 wire. (An assumption) also on the voltmeter you should be setting it to dc voltage (20v or something similar). You are measuring resistance I believe with the settings you have. Sent from my iPhone using Tapatalk
#98 |
Drives: DGM BRZ 6MT
IT WORKS! THAT TORQUE IS FINALLY BACK!
I tapped it into the copper lead instead of the insulated one and I could instantly feel the power. Woohoo!! Thank you car lords ![]() There aren't any good open roads near me to test this yet, but I could feel that wheelspin turning corners in these city blocks (sports map). For future reference, what should I have set my voltmeter to? (I'm pointing to the mode I used that displayed 5v for the wrong ESC lead):
| What does your user name mean? | Midship Runabout | Off-Topic Lounge [WARNING: NO POLITICS] | 355 | 05-01-2016 08:52 AM |
| OFT: New firmware and new user software | Shiv@Openflash | Software Tuning | 9 | 10-15-2014 02:45 PM |
| EcuTek End User/Retail Tuning Software Release! | Dustin@Dynosty | Forced Induction | 27 | 12-19-2013 09:17 AM |
| user tags | scottmcphee | Site Announcements / Questions / Issues | 3 | 04-11-2013 03:15 PM |
| User name | trueno86power | Site Announcements / Questions / Issues | 7 | 11-28-2012 12:48 AM |
