Old 06-03-2015, 09:10 AM   #15
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Originally Posted by wparsons View Post
There is zero performance benefit to this swap. Short of guys running wide slicks, we have plenty of braking power with the stock system. What we lack, for track use, is thermal capacity, but the STI swap doesn't help that at all.
Good pads/fluid will be all the vast majority of those autoxing or street driving their car need. You can even lap quite quickly on just upgraded pads/fluid without issue.
You should also point out that many track rats are only using a front BBK!!!!
Look at @ImperiousRex and his insanely capable BRZ. Front AP Racing Sprint Kit with OEM rears, all 4 corners on good pads
drewbot is offline   Reply With Quote
Old 06-03-2015, 09:12 AM   #16
Streetthrowback
Drives: 2015 brz
Originally Posted by drewbot View Post
Ok, but why go through an entire STi brembo swap with no mention of what pad compounds you are going to use? Especially when better pads and real fluid perform for many people on the stock rotors and calipers?
this is the beauty of life, everyone enjoys different setup, I just talk with experience on the things I been through
Streetthrowback is offline   Reply With Quote
Old 06-03-2015, 10:46 AM   #17
Streetthrowback
Drives: 2015 brz
better breaking doesn't shed time off around the track?
Old 06-03-2015, 10:57 AM   #18
wparsons
wparsons's Avatar
Originally Posted by Streetthrowback View Post
I have to disagree with you, I noticed the lack of brakes once I took it out of the box, the sock brakes on my lotus makes the stock brz feel very bad, not to mentions the Lotus has a swap motor in it and it still equipped stock Brakes
Did you try better pads first? What pads are you running on the STI brembos? I'm willing to bet every bit of difference you're feeling is because you're running different pads, and you could've done that way easier on the stock calipers/rotors.
If you're able to engage ABS, your brakes are strong enough already. On stock pads with cold tires (dunlop ZII's) I could still engage ABS, once the tires were up to temp I couldn't. I added new pads and fluid and I could easily engage ABS again.
See above... plus, tires are generally the limiting factor in how fast you can stop, not the calipers.
flickr
Old 06-03-2015, 11:04 AM   #19
gramicci101
Off Topic
The OEM brakes can already engage the ABS. Since you can only brake as well as the tires can hold onto the ground, there's no real benefit to a brake system that can engage the ABS sooner.
People who go with the Sprint kit, which is designed to work with the OEM rear brakes to maintain brake bias, do so because it has better thermal capacity and heat management, and for a track-driven car replacement parts are cheaper over time. The STI Brembos, which were not designed with the BRZ rear brakes in mind, push the bias forward. This overworks the front brakes and causes them to overheat faster, which then overworks the rear brakes because the front brakes are no longer effective. The rear Brembos actually have less braking power than our OEM rear brakes do, so doing a full swap just exacerbates that effect. 95% of users will never notice, because they aren't putting that kind of strain on their brakes. The 5% that do will notice very quickly.
I would do the Brembo swap because it looks cool. If I wanted straight up performance, I would buy a kit that was designed for this car. Probably the AP Sprint or Endurance kit, since I don't live anywhere that sees snow or road salt.
The Following 4 Users Say Thank You to gramicci101 For This Useful Post:
CSG Mike (06-05-2015), drewbot (06-04-2015), The Racers Line (06-05-2015), wparsons (06-03-2015)
Old 06-04-2015, 11:35 PM   #20
jflogerzi
jflogerzi's Avatar
Echo what everyone has said. Better pads,steel lines, and fluid is all you need. I am getting ready to try some new pads and new front rotors(Stoptech slotted) as recommend by the manufacture. On stock power, no need for BBK.
Old 06-05-2015, 01:37 AM   #21
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
not worth it.
Old 06-05-2015, 12:40 PM   #22
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
You will die in a fire, as seen here: http://www.ft86club.com/forums/showthread.php?t=86917
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 06-05-2015, 02:19 PM   #23
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Most owners that did this swap are dead. I barely survived. Install at your own risk.
The Following 4 Users Say Thank You to King Tut For This Useful Post:
akyp (06-06-2015), gramicci101 (06-05-2015), Jive Turkey (06-06-2015), wparsons (06-05-2015)
Old 06-05-2015, 02:34 PM   #24
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
They died in a fireball explosion. While drinking fireball.
The Following User Says Thank You to cdrazic93 For This Useful Post:
Old 06-06-2015, 12:03 AM   #25
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
don't do it. everyone that read somewhere and never actually personally experienced it said its sucks and does nothing but ruin your car.
also, you'll end up locking up and dying in huge ball of fire as stated above by the prior poor restless souls. hell i'm lucky to be a live right now.
Jive Turkey is offline   Reply With Quote
Old 06-06-2015, 06:29 AM   #26
wparsons
wparsons's Avatar
I don't think it's unsafe or will kill you, but it it's not going to improve braking performance compared to better pads. If you're doing it for looks, sure, but if you're after better braking performance there are much cheaper options that work better.
flickr
Full Front and Rear 08-12 STI Brakes Swap King Tut Suspension | Chassis | Brakes -- Sponsored by 949 Racing 320 02-06-2020 01:37 AM
Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 119 12-17-2017 05:53 PM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Brakes for looks mostly ofuts Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 11-25-2014 04:52 PM
Will EVO 9 brakes fit? mike the snake Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 01-07-2014 05:13 AM
