Old 05-30-2015, 05:07 PM   #1
Subie_Nubie
Subie_Nubie's Avatar
Drives: 2013 Subaru BRZ Limted
'07 Sti Brakes, experience with this swap?
Found a guy on Facebook parting out his entire 2007 STI. He has brembo rotors and calipers for $900. From what I understand this is one of the harder swaps to do onto the BRZ (year 07 brakes I mean). Any experience with this? Worth trying to do the swap?
Subie_Nubie is offline   Reply With Quote
Old 05-30-2015, 05:18 PM   #2
gramicci101
Off Topic
The calipers will need the bleed valves moved to the other side. The rotors won't fit because they're drilled for 5x114.5, not 5x100. You'll need rotors from a 2004 STi or dual-drilled rotors like DBA.
Old 05-30-2015, 08:24 PM   #3
Streetthrowback
Drives: 2015 brz
It's an easy swap, not difficult at all
Streetthrowback is offline   Reply With Quote
Old 05-30-2015, 09:21 PM   #4
Fishbone
Drives: 2024 GR86
Fronts bolt directly on but you need new rotors that are 5 x 100. Nothing else is needed for the front.
Rears are a little bit more complicated. You need to buy an adapter. KNS Brake's Version II adapter is what you need. Also, you will need to trim or remove the dust shield because it interferes with the larger rotor. Again, the proper rotor is needed for the 5x100 and the P brake. The 2004 STi rotors will work Frt and Rr. Other options of redrilling 08+ (thanks streetthrowback for this correction) also. This is for P brake figment.
Read this entire thread and you will get information about the bleeder valve and plug swap.
Existing FRS break lines will fit but you need to use the STi Brembo banjo bold IIRC.
You will need to get new hardware to mount them too since the OEM FRS ones don't fit.
Make sure your rims clear. OEM ones will not work.
Good luck.
Fishbone is offline   Reply With Quote
Old 05-30-2015, 11:03 PM   #5
Streetthrowback
Drives: 2015 brz
Correction the rear needs 08+ rotors, the fronts you can use the 07 rotors, I had the 07 rotors on the rear and they weren't seating properly, 08+ do
Old 06-01-2015, 11:14 AM   #6
Subie_Nubie
Thanks everyone for your advice, im still deciding if i want to do it. I currently have no space to do the swap so its a bummer. Guy is in ATX too, so kind of out of my way and I need to do more research!
Old 06-01-2015, 12:47 PM   #7
wparsons
wparsons's Avatar
Not worth it IMO, unless you really want it for the look.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
krayzie (06-01-2015), Packofcrows (06-05-2015)
Old 06-01-2015, 03:43 PM   #8
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Not worth it as brake bias could become an issue.
I have STI Performance brake pads for the stock BRZ calipers with stock BRZ discs and ATE Typ 200 brake fluid. I find the braking already too good for occasional spirited street driving.
krayzie is offline   Reply With Quote
Old 06-01-2015, 07:45 PM   #9
Boosted
Boosted's Avatar
Drives: 13 brz, 06 STI
I would recommend doing some more reading. There is a DYI thread on what it all takes and king Tut has a thread about questions/discussion. As stated above the full swap makes the car a lot more front bias. I would only recommend doing the front brakes, our rear brake is more than capable.
If you have not tried pads, stainless steel lines and new fluid I would start there. I have the STI front brembos and it is a upgrade. However in most cases the pad, lines and fluid is a good upgrade. This will also give you time to research if you want another BBK or do Brembos. There are plenty of Brembos for sale on NASIOC and no shortage.
Hope this helps some.
-Alex
2013 BRZ Limited build: http://www.ft86club.com/forums/showt...d=1#post586737
2006 STI- lots of go fast goodies 551whp/491 Tq on 93(weekend car)
1988 CRX si- b16A1 (Sold)
RIP 2003 WRX
Boosted is offline   Reply With Quote
Old 06-01-2015, 08:49 PM   #10
gramicci101
Off Topic
For that matter, our front brakes are more than capable at everything except heat dispersion. New pads and fluid and you're good for everything except heavy track days. And you can mitigate heat by installing cooling ducts.
The Brembos do look tremendously better though.
The Following User Says Thank You to gramicci101 For This Useful Post:
wparsons (06-02-2015)
Old 06-02-2015, 11:14 PM   #11
Streetthrowback
Drives: 2015 brz
I'm not sure what's all the negativity surrounding the swap, I drive very aggressively, I bet the hell out of the car everyday and autox the car, and the brakes feel great, I'm not in it for the looks, I'm in it for the performance
Old 06-03-2015, 07:37 AM   #12
wparsons
wparsons's Avatar
There is zero performance benefit to this swap. Short of guys running wide slicks, we have plenty of braking power with the stock system. What we lack, for track use, is thermal capacity, but the STI swap doesn't help that at all.
Good pads/fluid will be all the vast majority of those autoxing or street driving their car need. You can even lap quite quickly on just upgraded pads/fluid without issue.
flickr
Sportsguy83 (06-05-2015)
Old 06-03-2015, 08:56 AM   #13
Streetthrowback
Drives: 2015 brz
I have to disagree with you, I noticed the lack of brakes once I took it out of the box, the sock brakes on my lotus makes the stock brz feel very bad, not to mentions the Lotus has a swap motor in it and it still equipped stock Brakes
Old 06-03-2015, 09:07 AM   #14
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Ok, but why go through an entire STi brembo swap with no mention of what pad compounds you are going to use? Especially when better pads and real fluid perform for many people on the stock rotors and calipers?
drewbot is offline   Reply With Quote
The Following User Says Thank You to drewbot For This Useful Post:
wparsons (06-03-2015)
Full Front and Rear 08-12 STI Brakes Swap King Tut Suspension | Chassis | Brakes -- Sponsored by 949 Racing 320 02-06-2020 01:37 AM
Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 119 12-17-2017 05:53 PM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Brakes for looks mostly ofuts Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 11-25-2014 04:52 PM
Will EVO 9 brakes fit? mike the snake Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 01-07-2014 05:13 AM
