#30 |
Drives: 2014 BRZ Limited
| The Following User Says Thank You to extrashaky For This Useful Post: | Ultramaroon (06-02-2015) |
#31 |
I do to. I was just poking you about having to use YT when how to turn it on is right in the manual.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | MaudDib (06-03-2015), Ultramaroon (06-02-2015) |
#32 |
Drives: RAVEN
I find that the fun/mile ratio is inverse to the miles/gallon ratio. There might be a squared factor in there also.
| The Following 2 Users Say Thank You to NOHOME For This Useful Post: | Tcoat (06-02-2015), Ultramaroon (06-02-2015) |
#33 |
#34 |
Best I've done is a little over 36MPG over about 350 miles but that was with an average speed over 70MPH.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#35 |
Drives: 13 Subaru BRZ, 02 Audi TTQ
I agree, I get around 25-26 in the BRZ and I could barely get 35 mpg out of a Golf TDI. I have fun as often as I can.
#36 | |
Drives: 2013 FR-S 6MT Whiteout
My previously daily driver was a Nissan Xterra 4X4 (which I still own and is an excellent vehicle). MPG for that vehicle averages 14-17 MPG. By comparison, the MPG of my 6MT FR-S is averaging 32 MPG, and I do a lot of short-distance commuting. So I'm pretty happy about decision to buy a sports car for the good gas mileage. Of course, that's just one of the reasons I bought it, but still a major one. |
| The Following 3 Users Say Thank You to Fishbed77 For This Useful Post: |
#38 |
☑ rekt ☐ not rekt
#39 | |
If you were driving an older car with a carburetor, it would have been the other way around. |
| The Following User Says Thank You to extrashaky For This Useful Post: | Tcoat (06-02-2015) |
#40 |
Drives: '06 AM V8V Coupe
lol you guys are funny, I bought a used car with 28k on it -_-
Also, if you calculate fuel burn per unit energy saved by not engine braking, you'll find that coasting downhill is more fuel efficient if you are not slowing down afterward. DCTs these days have an auto-coast function that does that to save fuel. That's why it's called engine braking. Nice try though. |
#41 | |
You are not using fuel when engine braking you are using compression. Extra already explained it perfectly.
#42 | |
Imagine if you were travelling down a slight hill, steep enough to maintain whatever target speed. If you were engine braking, the car would slow down, and you'd have to keep on applying gas over and over to recover speed. If you coast down the hill, you only burn what fuel it takes to idle. If you barely feed it enough throttle to maintain speed, you're essentially idling the engine at a higher rpm, since it's not doing work, which takes more fuel. Apply gas -> engine brake -> apply gas -> engine brake is generally even less efficient. Nevermind theory, you can try this pretty easily. Reset the average mpg meter on a flat road and turn on the cruise control, note the number. Then reset it, accelerate slowly then clutch in, rinse and repeat, maintaining the same average speed with a bit of fluctuation. The mpg meter will read a little higher if you do it right. The fuel wasted idling is offset by the drag saved by not spinning the engine as quickly and operating the engine at higher efficiency when accelerating. |
| The Following User Says Thank You to serialk11r For This Useful Post: | Cal3000 (09-26-2015) |
| Tags |
| efficiency, gas, mpg |
