Old 05-30-2015, 11:31 AM   #533
churchx
churchx's Avatar
Drives: 2014 GT86
Laminar flow usually flows better & with less resistance, then turbulent one. Though i don't know if that's the case here, who knows, maybe more turbulent air in intake might somehow help fuel dissipation in air, or not that applicable here with on-off pulsating flow depending on cylinder cycles and cams open/closed. Only experiments may tell, but my bet that mirror finish might be slightly better .. but will that be enough for extra work/costs?
churchx is offline
Old 05-30-2015, 01:36 PM   #534
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Originally Posted by lamawithonel View Post
No, I haven't been following that closely.
But I was thinking more like this.
Shark-skin surfaces for fluid-drag reduction in turbulent flow
DOI: 10.1098/rsta.2010.0201
Of course, there are no scales here-- no trailing edges, so I'm not sure if it would work. @eric6 and @NotEric6, have you run any simulations?
We have not as it is a manufacturing surface finish. We are not concerned with the effects it may (likely doesn't) have on the airflow.
Originally Posted by DocWalt View Post
Bingo... Since I'm sure most of us drooling here drive our cars on the street too... We do need to take that into consideration
And yep, tooling costs are the issue. I think it's fairly easy to tweak your design for plastic upper plenum bits, but meh.
We are concerned with WOT air temps though, cruising air temps may be slightly warmer but WOT air temps should be roughly the same manifold to manifold. Warmer air during cruising sounds like a MPG gain to me .
In all seriousness though, we will do our best to bring a great product to production once proven in prototype form.
VerusEric is offline
The Following User Says Thank You to VerusEric For This Useful Post:
DocWalt (05-31-2015)
Old 05-30-2015, 04:54 PM   #535
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Healthy discussions are healthy.
As for tooling, that's the benefit of CNC machines. Individual changes can be made without having to completely throw out everything you have. Injection molding is a nightmare though.
In the case of plastic plenums, aren't people already pushing 20+ psi? I @Reaper was pushing 19 on the stock everything. If anything, some prefer aluminum for aesthetics, but I do believe that all of the plastic-gonna-blow-up people just don't want to accept the truth. Material is only part of the equation. You have to understand how to properly implement it. I'm really only prodding you guys for what it's worth. Like I said, healthy discussion...
boredom.is.me is offline
Old 05-30-2015, 06:05 PM   #536
Sammakko
Bilge monkey
Sammakko's Avatar
Drives: '13 BRZ, 82 starlet
Originally Posted by Hyper4mance2k View Post
The right way to make a velocity stack.
he's a brave man, wearing gloves around a running lathe.
Sammakko is offline
The Following User Says Thank You to Sammakko For This Useful Post:
Hyper4mance2k (05-30-2015)
Old 05-30-2015, 10:33 PM   #537
nelsmar
@NotEric6 @nelsmar
Will you be in a position to tell me/us if this manifold will be ok to run without a tune?
I appreciate it would not be optimal but for myself organising a tune takes time*.
*It gets fitted locally then book a tune 350 kms away,
organise the wallet, organise time off from my work, the wife's work, stay 2 or 3 nights, yadda yadda.
Honestly with the stock rom and how this ecu handles knock and trims... Just about any NA mod "could" work. But you may and could be losing power at every possible rpm due to knock correction being aggressive and non optimal vvt maps. It would be a waste to not get it done all at once.
My flickr - Canibeat
Local magazine scout
nelsmar is offline
The Following 2 Users Say Thank You to nelsmar For This Useful Post:
Captain Snooze (05-30-2015), Valentino (06-02-2015)
Old 05-30-2015, 10:35 PM   #538
nelsmar
I was running 22-24psi for a while on my manifold without issues. So yes... It holds just fine. But the plastic vs metal debate is really a little excessive. Yes plastic is typically better but due to small market of this unit it would cost probably the same and look less pretty. Remember most cars used to run metal manifolds without issues... lol
nelsmar is offline
The Following User Says Thank You to nelsmar For This Useful Post:
boredom.is.me (05-31-2015)
Old 05-31-2015, 12:11 AM   #539
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
if thermal conductivity is an issue with metal, then why not just coat the outside with some form of insulation? Hell you could probably spray it with rubberized undercoating or something similar.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline
Old 05-31-2015, 12:21 AM   #540
Shady195
Drives: '13 10 Series FRS #1203
The minute I saw him put his hand near the chuck I thought the same damn thing. I had a friend get a finger torn off due to his glove getting grabbed by the piece he was working on and wrapped around it.
Shady195 is offline
Old 05-31-2015, 12:51 AM   #541
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by gramicci101 View Post
I would expect that the velocity of the air inside the manifold pretty much negates any potential for heat soak. The air isn't in contact with the manifold long enough to transfer a significant amount of heat from the metal.
It does. For instant burts of "heated air" no the measurable temp of the Al doesnt increase. Over longer periods of throttle response the longer the air is flowing through he engine the longer the ambient temp of the air is in contact with the intake mani. Hence why aluminum (with its Q heat properties) was chosen. Cost vs heat dispursion.
cdrazic93 is offline
Old 05-31-2015, 09:27 AM   #542
Sammakko
Bilge monkey
Sammakko's Avatar
3D print it... out of unobtanium?
Sammakko is offline
The Following 3 Users Say Thank You to Sammakko For This Useful Post:
Blu-by-U (05-31-2015), chaoskaze (06-01-2015), IBill4You (05-31-2015)
Old 05-31-2015, 09:34 AM   #543
plucas
plucas's Avatar
Drives: Subaru
The issue with plastic is the initial cost, not strength. We know we can have it injection molded and handle the abuse. Injection molds cost a lot of money. For this manifold, it would be north of $75,000 in the USA. That is honestly not feasible in the aftermarket.
plucas is offline
The Following User Says Thank You to plucas For This Useful Post:
Old 05-31-2015, 11:20 AM   #544
boredom.is.me
Custom User Title
You missed my point completely.
That's exactly what I said.
Old 05-31-2015, 07:05 PM   #545
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
Drives: wanting an Acabian
Better than using "Upsadasium", the front end is light enough at speed.
She said it was her or the car. Longest she had ever seen.
Blu-by-U is offline
Old 05-31-2015, 09:41 PM   #546
abraxis
Drives: many
If the grooves are just an aesthetic choice, can you ask the machinist to swap the radial machining on the outside for the interior vertical piping? I know you think it won't matter much, but my inner child's flow bench experience would feel more relieved to actually have a proper laminar orientation.
abraxis is offline
FT-86 SpeedFactory LCA by Verus - Lightest LCA for the Twins - Development Thread FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 236 06-20-2019 01:42 PM
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 01:43 PM
Intake manifold viking Engine, Exhaust, Transmission 6 09-23-2014 11:08 PM
Oil on/around Intake Manifold Wepeel Issues | Warranty | Recalls / TSB 2 05-12-2014 11:40 PM
WTB: intake manifold carlitosway6891 Engine, Exhaust, Bolt-Ons 0 06-22-2013 02:24 PM
