Old 05-26-2015, 10:25 PM   #1
philooo
Drives: 13' Scion FRS Track car
Oil pressure and Oil Temp sensor - where did you mount them and how
Show me where and how did you install your oil pressure sensors and/or oil temperature sensor.
I see 2 main options
- oil gallery plug next to the AC
- oil sandwich plate NPT plugs
Secondary options:
- aftermarket oil cooler plugs
I wonder what is the most accurate.
philooo is offline   Reply With Quote
Old 05-26-2015, 10:43 PM   #2
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
I used the Oil gallery for oil temp. It was simple.
crazyfrenchbiker is offline   Reply With Quote
Old 05-27-2015, 01:06 PM   #3
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
I did galley for pressure and Sandwich plate for temp. Comparing plate to OEM temp sensor, only off by a few degrees.
1Cor10:23 is offline   Reply With Quote
Old 05-28-2015, 11:17 AM   #4
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I would advise against using the oil galley for Oil Temp. I am seeing up to 45 degree difference in temperature readings at the galley vs. what my OFT is reporting from the OBD port.
Kind of hard to tell, but that is 170°F on the gauge reading from the Oil Galley, and 210°F from the stock sensor. Cruising at 70mph.
Old 05-28-2015, 11:26 AM   #5
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
Where exactly is the OBD info pulled from?
Jesse36m3 is offline   Reply With Quote
Old 05-28-2015, 11:42 AM   #6
DustinS
DustinS's Avatar
That I am not sure of^^. I have been wondering that myself, but it is where most of the track guys seem to be pulling their temps from. (or pull temp from sandwich plate/stock pressure location which report very close to stock sensor)
Old 05-28-2015, 12:22 PM   #7
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
OBD pulls from a sensor in the block just under the oil filter. I don't bother with aftermarket gauges for anything the car already monitors.
To answer the OP, an oil pressure sender can go in either the galley plug or the front of the block. The oil pressure range specified in the manual is taken from the port at the front. That being said, the oil galley will apparently give a better idea of the oil pressure as seen by bearings, and that's where I'll be mounting mine (due in large part to packaging simplicity). Pressure measured at the oil galley will be up to 10 PSI lower than pressure at the port on the front of the engine.
Decay107 is offline   Reply With Quote
The Following User Says Thank You to Decay107 For This Useful Post:
Ultramaroon (05-29-2015)
Old 05-28-2015, 03:57 PM   #8
wootwoot
Drives: FRS
Oil temp and pressure are critical to monitor.
I have my temperature sensor in my oil gallery plug. Works well.
Pressure senders can be sensitive to vibration. Most of the time manufacturers suggest remote mounting pressure sensors so engine NVH doesn't cause it to fail. I had this happen. It took many hours to clean the oil out of my engine bay.
Old 05-28-2015, 04:08 PM   #9
DustinS
DustinS's Avatar
^^ What are your temps?? My temps are not correct using the galley.
Also That is why I am glad my gauges came with a small sender
Although I replaced this with the temp sensor as it wouldn't fit the adapter for the front of the block. Pressure sensor is located in the stock location.
Old 05-29-2015, 12:34 AM   #10
wootwoot
Drives: FRS
I think your temps are correct. Oil will be different temperatures depending on where it is in your engine.
Old 05-29-2015, 12:53 AM   #11
Decay107
Decay107's Avatar
Did the install this evening, installed pressure sensor at front of engine, didn't like how it contacted the throttle body wire harness at the galley port.
Old 05-29-2015, 02:41 AM   #12
Deraj
Drives: '14 Asphalt Monogram
I have my pressure sensor in the oil galley plug and temp sensor in the OEM pressure switch location. My oil temps are reading about 20 deg higher than OBD, which I find very strange since I thought the OBD reads from nearly the same location.
Deraj is offline   Reply With Quote
Threads for Stock oil Pressure and Temp Senders @Art_Mighty Engine, Exhaust, Transmission 21 09-03-2022 02:51 PM
OpenFlash Tablet: Tire pressure/Temp display? Shiv@Openflash Software Tuning 52 03-09-2018 01:26 AM
Oil Pressure and Temp Gauge Install BokChoiTV Cosmetic Modification (Interior/Exterior/Lighting) 14 12-29-2015 06:19 PM
Installing oil pressure/temp probes xwd Engine, Exhaust, Transmission 12 03-14-2015 12:07 AM
Anyone run Tyredog pressure/temp monitors? Thorpedo Tracking / Autocross / HPDE / Drifting 11 01-23-2015 01:51 AM
