Drives: Subaru
Oil Cooler Set Up DIY?
I stumbled across this parts website and was wondering which parts are needed to assemble to a complete BRZ/FRS Oil Cooler Kit for a NA Car?
Im interested in the 19 Row Setrab Core and the Mocal Sandwich plate. Where I need help is figuring out is how many feet of hose I might need and which fittings are suggested if I am considering upgrading the intake in the future. http://www.racerpartswholesale.com/p...b_Oil_Coolers2 http://www.racerpartswholesale.com/p...b_Oil_Coolers2 http://www.racerpartswholesale.com/p...Sandwich_Plate http://www.racerpartswholesale.com/p...ht_Racing_Hose http://www.racerpartswholesale.com/c...usableFittings It looks like a decent kit could be assembled for around $525 in parts. I have looked at the other kits and I think I have most of the parts covered above. Am I missing anything and which parts should I use for this DIY set up? |
#3 | |
Drives: Subaru
First, 19 vs 13 cooler. Second, still waiting on the track data feedback from your kit. I'd rather buy once and get it right for my needs. |
#4 |
We could send you any core you choose
#5 |
Drives: Dodge Stealth
Where do you plan on mounting the cooler? Do you mind using push-on hose?
Let me know and I can get you a price with the 19 row cooler in a DIY setup. I should be able to beat the prices above. |
#6 |
Drives: 2014 Toyota 86
Wish i knew that, yesterday was about to piece together my own kit and i just pulled the trigger on the mishimoto cooler instead..
#7 |
Drives: Subaru
#8 | |
As for the push on hose they're much easier to make than typical steel braided AN lines. You simply lube up the end of the AN fitting and slide the hose over the barbs. They're impossible to get off once they're on (trust me, I've tried) but some people argue they're not as secure as regular hose. I'll shoot you a PM over with pricing now and we can work out the specifics there. |
#9 | ||
Drives: 2013 Subaru BRZ
As a hose length comparison, we include a 36 and 50 stainless steel braided hose to route oil to the passenger side of the grille. If you locate the cooler on the drivers side, you may be able to use slightly short lines. If you would prefer the challenge of fabricating a bracket (sometimes a Saturday morning of welding/cutting can be therapeutic) and putting lines together, then a DIY setup may be the way to go, but you will likely end up around the same cost, if not more compared to our kit. Whichever you select, I believe you will find great results in oil temperatures with a 19-row oil cooler. Let me know if we can help out any further! -John Quote:
Thanks -John |
#10 |
Drives: FRS
We came to the same conclusion (especially at our new exchange rate here in commie land).
The hassle of saving a few pennies wasn't worth the convenience of the kit. The kit is a jewel, was installed by BRZWORLD, works wonderfully - HOWEVER, the last 2 kits sent to BRZWORLD were incomplete, missing necessary parts and had several extra unnecessary promo material (one yes but 6 identical plastic bags of promo material instead of necessary parts) ? Some assembly line flunky was in a hurry to go home - BUT - to be fair, MISHIMOTO quickly couriered the missing parts to BRZWORLD. Impressed with the product, and service . ![]()
#11 | |
#12 |
Drives: 2015 Subaru BRZ
I love the friendly differentiation from competitors in this. It really helps to decide which product will best fit our needs. I was thinking about doing the OEM Forrester setup, but after going FI, I am finding that I am spending too much time working on the car to save a few bucks and not much time driving the damn thing.
#13 |
What size core would you consider verges on being excessive; one which could be partially covered to adjust the desired capacity?
#14 |
StreetKart
Drives: 2014 Scion FR-S Monogram
whats the difference in the 6 and 9 series cores?
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
| Oil Cooler | wootwoot | Engine, Exhaust, Transmission | 92 | 12-27-2014 08:10 PM |
| ARC Oil Cooler | ill86 | Engine, Exhaust, Transmission | 19 | 10-18-2014 04:30 PM |
| Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. | mike the snake | Engine, Exhaust, Bolt-Ons | 1 | 01-31-2014 05:46 PM |
| Best oil cooler | whitefrs | Engine, Exhaust, Transmission | 4 | 02-21-2013 11:36 PM |
