Old 01-10-2014, 05:23 PM   #43
PantsDants
Drives: Scion FR-S A/T, Whiteout
Originally Posted by fooddude View Post
I thought I read somewhere that only JDM IS300's have the 4.56 in certain models and none of the USDM IS300s had 4.56; hence, you won't find any 4.56 pumpkins in american junkyards. I could be wrong though or may have thought incorrectly.
I don't know anything about the JDM IS (Altezza) models having a 4.56 from the factory. What I DO know is that the 4.56 ring and pinion pair was used in a JDM-only model of the Supra, the GA70. Thing is though that the carrier assembly from one of those won't work on an 86; you'd be looking at installing those gears in your existing carrier.
As it stands, I don't know of any carrier that has a 4.56 pre-installed that will just drop into an 86.
PantsDants is offline   Reply With Quote
The Following User Says Thank You to PantsDants For This Useful Post:
jcw99 (03-06-2016)
Old 01-10-2014, 06:30 PM   #44
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
This is the unknown golden-secret as it stands I guess. Probably the best bang-for-the-buck mod out there once found (as junkyards usually let them go for $300ish)
But there gots to be a 4.56 Torsen LSD pumpkin out there somewhere, that will directly bolt/swap into the 86 (axle/driveshaft flange bolt patterns and all) . And once that secret is out, the junkyards are gonna be getting a lot of phone calls hehe
More research on the usdm IS300 (and/or old Supras or other Toyota cars?) might be of use:
- Which are 4.56
- Which have Torsen LSD
- Carrier bolt/hole-mount placement
- Driveshaft flange bolt pattern, size and type (holes or studs)
- Axle flange bolt pattern, size and type (holes or studs)
fooddude is offline   Reply With Quote
Old 01-23-2014, 11:25 PM   #45
ed1117
Drives: Brz
Do you have any noise after swap from the FD?
ed1117 is offline   Reply With Quote
Old 01-24-2014, 01:17 AM   #46
fooddude
^^^ the only thing I care about is this discovery (if it exists)
Old 01-24-2014, 02:20 AM   #47
PantsDants
I don't think I do, no.
That said, the diff shop guy did tell me I could expect some, based on how these cars are shaped and how short the FD ratio is. His advice to me was if you have some whine right after install, it's probably fine. If that noise changes though, then you should be concerned.
Old 07-30-2014, 11:37 PM   #48
kodyo
Drives: Scion FR-S
Thanks for the tips! Picked up my diff today for $250 to start the project:
kodyo is offline   Reply With Quote
Old 07-31-2014, 12:55 AM   #49
Dipstik-sportech
Dipstik-sportech's Avatar
3.73 ratio works great with boost. Highway cruise is way quieter as well
Old 01-05-2015, 06:11 AM   #50
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
Would anyone be interested in buying a brand ring and pinion set for an M85 differential? I was going to swap the stock differential ring and pinion but found a good deal on an M85 diff.
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 01-05-2015, 03:51 PM   #51
M23
Drives: 86
Any recommendations for good dedicated differential shops in socal?
M23 is offline   Reply With Quote
Old 05-26-2015, 06:15 PM   #52
Top-Secret
Drives: FRS monogram
this thread seems pretty dead lately. has anyone done this 'WITHOUT' replacing the pumpkin yet?
Top-Secret is offline   Reply With Quote
Old 05-26-2015, 08:27 PM   #53
kodyo
Drives: Scion FR-S
Why would that make a difference?
Unless you have any of the following, I wouldn't recommend doing it yourself:
1) Good public transportation
2) Walking distance to work/grocery store
3) Access to carpool
4) Spare pumpkin to work on
Either buy a pumpkin and prepare for the agony of doing it yourself, or take it to a shop.
Old 05-26-2015, 11:17 PM   #54
Top-Secret
None of that is an issue, I just want to know if someone has done it in the 86 pumpkin instead of buying a spare from an IS300. That's money I'd rather save
Old 05-27-2015, 07:31 AM   #55
Dipstik-sportech
Buying new gears, bearings, seals, and having a shop install them would be probably twice what you'd pay for a whole is300 pumpkin. So I fail to see the benefit unless you want a 100% new rear end
Old 05-27-2015, 04:17 PM   #56
Top-Secret
so its just cheaper to go with the is300 then?
Final Drive Discussion JimmyMac Engine, Exhaust, Transmission 118 08-07-2017 11:18 PM
Change gear ratio? Afdad120108 Engine, Exhaust, Transmission 61 08-17-2016 11:44 AM
Final Drive Calculations wootwoot Engine, Exhaust, Transmission 34 12-19-2014 05:06 AM
Change FD ratio to 4.56 by changing only pinion peachch Engine, Exhaust, Transmission 1 08-31-2013 02:25 PM
Correcting drive ratio for accurate speed AlexTheGreek Engine, Exhaust, Transmission 25 12-05-2012 02:13 AM
