Old 05-23-2015, 10:21 PM   #1
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
brake bleeding, air in abs?
So i have just changed my pads and while i was at it i vacuum bled my brakes, I did my best to keep the res full but it seems something has gone wrong. My pedal goes to the floor but applies a slight pressure to the pads. There are no leaky bleeders so im thinking some air got into the abs block in which there is no bleeder equipped. how do i fix this?
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 05-23-2015, 10:36 PM   #2
D_Thissen
D_Thissen's Avatar
Bring it to the dealership might be the easiest thing to do.
Old 05-23-2015, 10:58 PM   #3
Grip Ronin
The Mechanic
Grip Ronin's Avatar
i work right next to a subaru dealer thats part of my chain lol but i have the toyota program at home so i dont see something that they can do that i cant, except pressure bleed i dont have the adapter for this car
IG-Joey_Soul
Old 05-23-2015, 11:14 PM   #4
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Re-bleed the system. That's what they would do anyways.
N1rve
Old 05-23-2015, 11:20 PM   #5
wparsons
wparsons's Avatar
You probably need to bench bleed the master cylinder, sounds like you sucked in air into the master cylinder.
flickr
Old 05-24-2015, 08:26 AM   #6
Grip Ronin
The Mechanic
Grip Ronin's Avatar
ya im seeing in the service manual it says to pull the two main lines and bleed it by pumping and blocking the holes with your fingers, you think a master cyl would let the air rise up and out from pumping it
IG-Joey_Soul
Old 05-24-2015, 09:49 AM   #7
ZionsWrath
Thanks
ZionsWrath's Avatar
Try to bleed old fashion way first. Or buy a motiv bleeder, its only $50.
I'd rather do that first than bleed the master.
I haven't heard many good things about vacuum bleeding. I have used a tube from the bleeder into a container when the end is submerged in brake fluid and pumped the pedal. This worked fine as well.
I use a motiv bleeder on my BRZ and have a firm pedal every time.
Old 05-24-2015, 06:45 PM   #8
Grip Ronin
The Mechanic
Grip Ronin's Avatar
i think i used the old pump and hold style when i did steel lines and the 4 pot calipers. Had no issue the first time. im going to go try it now
IG-Joey_Soul
Old 05-25-2015, 10:50 AM   #9
kosoku
Drives: 2013 fr-s
Gravity bleed it. Time consuming but very effective.
kosoku is offline   Reply With Quote
Old 05-25-2015, 12:27 PM   #10
cjd
cjd's Avatar
Drives: 2017 BRZ
Pressure bleeding is this, but faster (or so) - wasn't sure about the Motiv but glad I got it.
That said, I was surprised how long the train of almost invisible bubbles took to clear out. I think I still have a little air in the system, but no issues getting lots of brake when I need it.
Old 05-25-2015, 08:47 PM   #11
Grip Ronin
The Mechanic
Grip Ronin's Avatar
managed to get the air out but cycling the abs motor and solenoids and pump bleeding, it was trapped in the rears. Still feels like im hitting abs early but i have good pressure. ill have to figure that out. It might be the new pads
IG-Joey_Soul
Old 05-26-2015, 08:51 PM   #12
kosoku
Drives: 2013 fr-s
i'm aware its the same. in my experience slower is better when it comes to bleeding.
Not to say pressure bleeding doesn't work!
Old 11-21-2018, 05:02 PM   #13
Kev951
Drives: 2016 Oceanic 6 speed manual FR-S
@Grip Ronin, what scan tool did you use to cyle the abs motor / solonoids?
Kev951 is offline   Reply With Quote
Old 11-22-2018, 07:34 PM   #14
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I have this power bleeder.
https://www.summitracing.com/parts/m...yABEgLS-PD_BwE
And I have speed bleeders too.
http://www.russellperformance.com/mc/speed-bleeders/
If you put the car on a lift then you can activate the ABS to try to purge the system by running the car in gear. Just don't fall off if you use jack stands.
What brake fluid do you use when bleeding/flushing the clutch? MINOCIN Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 08-24-2020 12:07 PM
Bleeding Air through TPMS GarStar Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-05-2015 02:14 PM
My Car is bleeding! Ec1990 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 04-01-2014 10:31 AM
Anyone doing brake bleeding with the "Gravity Method"? Hanakuso Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 03-03-2013 02:53 PM
Brake bleeding order? ubersoph Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-10-2012 07:13 AM
