Old 01-21-2015, 08:22 PM   #15
phrosty
Will the thermostat work well at -20 degrees? Looking for a mod that'll keep me cool in the summer and not blow up in frigid winter.
phrosty is offline   Reply With Quote
Old 01-21-2015, 09:12 PM   #16
Stark Performance
Drives: 2014 FR-S
Man, that's cold. The thermostat will work at low temperatures. Since some of the fluid does flow out to the cooler, however, it will take a while to come up to temperature in really cold weather. Then again, the rest of the fluids in the car will take longer as well.
Stark Performance is offline   Reply With Quote
Old 01-23-2015, 02:14 PM   #17
phrosty
It's pretty rare but last winter Chicago got down around there and FR-S kept ticking
Old 02-18-2015, 01:57 AM   #18
Stark Performance
Drives: 2014 FR-S
The thermostats are now available and in stock. They are modified with new high temperature wax motors with the fittings installed and pressure tested to ensure a leak free installation.
Old 05-21-2015, 02:37 PM   #19
RFB
RFB's Avatar
Drives: FRS
Install Review-First Impressions
BRZWORLD did the install, of a nice piece of kit. Went in simply and quickly.
Driving sensation, marvelous shifting, paddles are faster, better than when the car was new !
BUT - I did a complete flush of partial ENEOS tranny fluid as well, to a complete fill of new ENEOS.
For an exhaust grate remove the plastic grate (removable access plate) on the bottom right of the bumper bottom plastic plate, orient the slots for water runoff and rivet it into the wheel well. The new hole on the bottom of the car adds more airflow in, or u can order a new plate from stealership.
Cutting out the fog light space invaders plastic is a must.
The new thermostat is not, but then you would have to block off the intake grate in the winter.
I'm ordering the thermostat, in case I ever have to drive it in winter.
All in all very happy with the kit and install.
Will post more after I track it hard.
RFB is offline   Reply With Quote
The Following 3 Users Say Thank You to RFB For This Useful Post:
drewbot (05-22-2015), Lonewolf (05-23-2015), Stark Performance (05-23-2015)
Old 05-22-2015, 12:17 PM   #20
Alott53
Drives: Whiteout 2014 FRS AT
This is great! Price is also amazing. Wish the paddle shifter extensions were cheaper and more reasonable like this!
Alott53 is offline   Reply With Quote
Old 05-23-2015, 01:36 PM   #21
Stark Performance
Drives: 2014 FR-S
I'm glad to hear that the install went smoothly and it made a positive improvement in overall driving experience. I look forward to hearing about your track experience with it installed. Do you have a way of monitoring transmission fluid temperature? I know that the Torque app for Android devices can do it with an OBDII dongle.
Old 05-24-2015, 09:25 AM   #22
RFB
RFB's Avatar
Drives: FRS
Unfortunately OBD used by OFT to monitor engine oil.
The auto tranny in manual mode, will revert to auto while in manual when the fluid is overheated as on a Gran Prix track, in high summer, as self protection.
Won't happen with a large 19 row -
The Following User Says Thank You to RFB For This Useful Post:
Stark Performance (05-24-2015)
Old 05-24-2015, 12:47 PM   #23
Stark Performance
Drives: 2014 FR-S
That certainly won't be an issue with the cooler installed.
Torque can also display engine oil temp along with many other parameters. I have a Samsung Galaxy Tab 3 mounted with the GT86Mounts setup that works quite well.
Old 06-15-2015, 03:17 PM   #24
Campo
Campo's Avatar
Drives:
I'd like to pair this with the Jackson Racing oil cooler that also uses a Setrab core.
Is there any reason for me to NOT install them side by side in front of the radiator instead of outboard in the area by the wheel well like your current install?
I have no plans for FI due to competition classification.
"Fuck, you've gone completely sideways, man."
~Raoul Duke
Gas is pretty cheap considering you're buying liquid explosive dinosaurs.
Campo is offline   Reply With Quote
Old 06-15-2015, 05:26 PM   #25
RFB
RFB's Avatar
Drives: FRS
It can be done, but I fear excessive rad space will be blocked, and the coolant will be overly hot.
With only my oil cooler in front of the rad, I noticed NO increase in coolant temps.
It was stoopid simple to install in front of the rt. wheel, and with Eneos tranny fluid, now with the hot weather, it still shifts faster smoother than new !
Stark Performance (06-15-2015)
Old 06-15-2015, 05:32 PM   #26
Campo
Campo's Avatar
Drives:
Good call on the radiator space. I'm also considering a rad change to something more efficient plus changing the tstat setting.
What is hot weather where you're at? I live in Phoenix and it was 91*F at 7 this morning.
~Raoul Duke
Old 06-15-2015, 06:39 PM   #27
Stark Performance
Drives: 2014 FR-S
As RFB mentioned, it would block some additional radiator area, but I don't think it is going to be a huge deal on an NA car. The main reason we mounted the cooler kit where we did was to have a shot of it being compatible with some of the forced induction systems on the market.
Old 06-15-2015, 06:47 PM   #28
Campo
Campo's Avatar
Drives:
It makes sense for you to put it there so the front can be jammed with other stuff.
I need to take some measurements, but could I use a Setrab Series 9 15 row cooler instead of the Series 6 19 row? Then the tranny and the oil cooler cores would be the same. The btu/hr is about the same between the two cores, but the psi delta is different.
Now I'm getting all aesthetic and stuff, trying to keep it even.
~Raoul Duke
Automatic Transmission Fluid Cooler. ?? connor_lol Engine, Exhaust, Transmission 177 01-02-2023 09:02 AM
10% Off All SSP Automatic Transmission Upgrades! // DSG Performance Jason@DSG Transmission and Driveline 13 07-29-2014 01:19 PM
Automatic Transmission Cooler RYU Engine, Exhaust, Transmission 9 11-14-2013 02:15 PM
Automatic Transmission Cooler KGFRS86 Engine, Exhaust, Transmission 14 08-26-2013 08:55 PM
Automatic Transmission Cooler, necessary for autoX and Track? BRZPDX Engine, Exhaust, Transmission 4 07-11-2013 07:13 PM
