Old 05-22-2015, 01:50 PM   #2521
ZionsWrath
Thanks
ZionsWrath's Avatar
Originally Posted by gramicci101 View Post
If you take the top nut off and compress the strut with a jack does it still clunk? Does the top bolt stick through the plate the same amount on both sides? Are the threads trashed at all? Did the strut spin when you were tightening the top nut?
I can't reproduce the clunk stationary. On the ground or on jack stands. The top bolt hardly sticks out but its the same on both sides, less than OEM stuck out.
Threads were good when I last had nut off and added blue loctite.
Strut didn't spin, I used allen key and pass through socket.
I tracked it for 3 days without issue, half way home started clunking...
Old 05-22-2015, 01:56 PM   #2522
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
@BigFatFlip
I wouldn't use the tires to raise the car toooo much...it could start feeling sloppy.
Just a set of Koni Yellow adjustable dampers would be one way to start. You get a pretty decent shock with some rebound adjustability. Add the FRS rear springs for a little more rear rate without a drop. Add some bushings.
If you really wanted to, you could get coilovers (some will be okay with a 10mm drop) and then add some spacers to the top to get you back up to stock height without the risk of topping out the shock by running it out of it's intended range (and still have some droop). But I'm not sure that's the route I would take.
- Andy
Now that's an unusual request; most coilovers will force you to drop a bit to get full droop travel. If it's due to rough roads, keep in mind that better dampers will also absorb the road better, so unless you're flying over potholes, you shouldn't have any issues. If it's tough driveways... well... there's not really a fix for that
You can also get a 235/45/17 in some tires to get even MORE height.
So I ended up getting the Ohlins and planning to install next week. Since I'm planning on being as close to stock ride height as possible, do either of you guys know the max "shock absorber length" per the manual? Spec is 238mm/381.5mm F/R +/- 10mm adjustment range, so I'm guessing 248mm/391.5mm?
http://www.roadandtrackbyohlins.com/...MI_SUSMP20.pdf
Also, any recommendations on alignment settings? Are these settings tire dependent, ie stock vs 225/45-17? Just wondering since I'm currently on stock wheels+tires and if I need to switch back to my RE11As before getting an alignment.
Sorry for the super specific questions.
Thanks!
-Bryan
Old 05-22-2015, 02:03 PM   #2523
gramicci101
Off Topic
In that case, I'm out of ideas. I doubt the bottom bolts on the strut are loose. Have you had the plate off to play with it and see if anything seems wrong?
edit: Or, as an easy way to determine if it's a strut or plate issue, put the original top hats back on and see what happens.
Old 05-22-2015, 02:15 PM   #2524
ZionsWrath
Thanks
ZionsWrath's Avatar
I didnt want to i just paid an alignment a week ago
Old 05-22-2015, 09:35 PM   #2525
CSG Mike
CSG Mike's Avatar
Maybe they didn't properly tighten something?
CSG Mike is online now   Reply With Quote
Old 05-22-2015, 09:35 PM   #2526
CSG Mike
CSG Mike's Avatar
Thanks!
-Bryan
I'm not sure what exactly you're asking...
What are you going to be doing with the car?
Old 05-23-2015, 12:09 AM   #2527
BigFatFlip
BigFatFlip's Avatar
Basically what's the max ride height I can get with the ohlins. The manual says with the recommended settings, I can expect about a 20mm drop, so I'm guessing the highest I'm gonna get is a 10mm drop?
I'm mostly going to be doing street/canyon driving, with maybe 3-4 track days and a few autox a year.
Old 05-23-2015, 02:14 AM   #2528
CSG Mike
CSG Mike's Avatar
Unless you have some crazy driveways or bumps, I recommend you do a 15-20mm drop.
Old 05-23-2015, 02:08 PM   #2529
Check strut brace fasteners. I read someone reported going crazy looking for a clunk. Loose strut brace. Just an idea.
Old 05-26-2015, 12:17 PM   #2530
Rabbit of Caerbonnog
Run Away!
Rabbit of Caerbonnog's Avatar
Drives: 2015 Subaru BRZ Limited
Hi guys I have several noob suspension questions:
I've recently bought some ST Coilovers. I've bought these coilovers so that I can run most 17x9 wheels without the issue of rubbing against the suspension. I am planning on lowering the car modestly, an inch max. Note, the BRZ is my DD and I don't track it by any means but I do the occasional spirited driving. And I am still on the current 17x7 rims and stock Primacy (car is only 5 months old with about 4k miles). Now with the background out of the way...
Question 1: I know I need to get rear LCAs for proper alignment, I am planning to purchase the RacerX rear LCA's. With the RacerX LCA's they're asking for the rear camber either +2 to -1 degrees and -1 to -4 degrees. Which one do I need?
Question 2: Since the BRZ is a pure DD car, urethane bushings are better than rod ends correct?
Question 3: What other rear suspension mods do I need to get the proper geometry back after lowering the car? IS it needed even with a modest one inch drop?
Question 4: Raceseng makes a top hat specifically for the ST Coilovers, do I need that to have a proper front geometry?
Thank you for your time.
Rabbit of Caerbonnog is offline   Reply With Quote
Old 05-26-2015, 12:31 PM   #2531
1. You want the -1 to -4 degree range (because you'll want somewhere around -1.5 to -2 degrees rear camber).
2. Generally yes. Just make sure they're nice and lubed.
3. The Whiteline roll center kit would be a nice bonus, but you'll be fine with a 1 inch drop.
4. I'm not sure you need camber plates for your uses (you can get the camber you need with the slotted lower mounts). The Raceseng plates are good though and will help if you want a lot of negative camber.
- Andy
Rabbit of Caerbonnog (05-26-2015)
Old 05-26-2015, 01:06 PM   #2532
Run Away!
Thank you Andy!
3. What are slotted lower mounts?
4. I'm not planning on running crazy camber. I'm aiming for stock camber. I was asking for camber plates since I have a tendency to over think and over do things and my thinking was that with camber plates I have more options, even if I am aiming for stock camber.
Old 05-26-2015, 01:14 PM   #2533
Thank you Andy!
The lower mount of the front ST (and KW and RCE) coilovers has one of the bolt holes slotted, so you can adjust camber from down there. You can't get as much as you would from camber plates, but you can get a decent amount.
I wouldn't bother with stock camber, just keep it around -1 to -1.5 up front and you'll have a nice handling street car without excessive tire wear. Lots of toe kills tires, but you can get away with a little negative camber without a problem.
- Andy
Old 05-28-2015, 08:02 AM   #2534
Run Away!
So would your camber recommendation change if I were to switch from 17x7 to 17x9? Or does it not matter?
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
