Old 05-03-2015, 06:46 AM   #2479
Brzerker
Brzerker's Avatar
Drives: World Rally Blue BRZ
Don't want to start a new topic for this, I hope this is an appropriate place to ask this.
What's the length of the stock front endlink?
Thanks
Brzerker is offline   Reply With Quote
Old 05-05-2015, 01:59 PM   #2480
ja1217
Drives: 2004 Toyota RAV-4 5M
So I'm looking into taking a serious run at NASA East Coast Nationals in TTD either this year or next, and in order to fully optimize my car to the rules I've come to realize that I will need the 3 extra points that my Ohlins R&T setup is costing me (shaft diameter > 40mm and inverted front shocks). The Ohlins were great on both the street and track (especially after getting them custom revalved and sprung for the track), but those 3 points +1 more point for going back to stock intake gets me back onto Hoosier R7s.
E. SUSPENSION:
1) Non-BTM shocks/struts/dampers with an external reservoir or more than two ranges of
adjustment—must still take points for springs below +8 (example: compression (bump)
and both high & low rebound adjustments).
2) Non-BTM shocks/struts/dampers with a “Piggy Back” external reservoir (fixed reservoir
without a connecting hose) OR with shaft diameter 40mm or greater—must still take
additional points for the springs below +5
3) Non-BTM or modified/re-valved shocks/struts/dampers +3 (all others)(springs not included)
4) Changing the mounting orientation/design of the BTM shock and/or spring perch in order to
invert the front shocks/struts (includes non-BTM inverted shocks/struts) +1
So basically I'm trying to figure out what my best options are for what would be a high quality, track focused 3 point damper according to these rules. In my quick searching it seems that the majority of high end coilovers either have piggy back/external reservoir, are inverted and have shafts greater than 40mm, or both. A couple of ones that I've seen that might be options are KWv3 2 way adjustable clubsports and JRZ RS1's. These are rather on the high side for what I'd like to spend, but I am still open to these if they truly are worth the money.
Spring rates and valving will most likely end up being custom. Car will be run with stock sway bars and stock control arms and the primary tire will be 225/40R17 Hoosier R7.
ja1217 is offline   Reply With Quote
Old 05-05-2015, 02:33 PM   #2481
Racecomp Engineering
That inverted shock + shaft rule is so ridiculous. The actual shock shaft is NOT 40mm but NASA won't listen. Anyway...
JRZ if you can fit them in the budget.
Our RCE T2 clubsports would work well too at a lower cost (built by KW, starting from KW Clubsports but at a lower cost). Our T3 Clubsports would be great but have a piggyback canister.
Give us a call if you'd like to talk. We're in MD as well and have run many set-ups on our BRZ. We also helped JRZ with some development work and testing with their coilovers for BRZ early on. Myles will have their newer RS line on his 2015 WRX very soon if you want a ride.
- Andy
Racecomp Engineering is online now   Reply With Quote
Old 05-05-2015, 02:34 PM   #2482
Thanks
Haven't had my hand on a stock endlink in a while.
Best would be to just get under your car and check it out.
- Andy
Old 05-05-2015, 03:15 PM   #2483
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Wow, I can't believe I just read through all 113 pages (took me a couple weeks). Thank you @CSG Mike and @Racecomp Engineering for fielding everybody's questions! I have learned alot.
Now, I belong to the very small group of wanting/needing stock ride height (maybe even higher) thanks to the area I live in. I've been very happy with the stock suspension but have been trying to find more adjustable options. I don't claim to know what I'm doing so I've been leaning towards a single adjustable set-up, particularly the Ohlins R&T and the Bilstein B16's. Any other recommendations? If it ain't broke don't fix it (ie stay stock)?
Now for the pertinent info everyone seems to ask:
90% street (including canyon/twisties) 10% track day
I'm currently on 225/45-17 RE11A's (to eek out a few mm of additional height)
Only other suspension mod is a WRX rear sway bar (16mm) and front camber bolts
cheers!
-Bryan
The Following 2 Users Say Thank You to BigFatFlip For This Useful Post:
CSG Mike (05-05-2015), Racecomp Engineering (05-05-2015)
Old 05-05-2015, 03:20 PM   #2484
cheers!
-Bryan
Hey Bryan,
Glad to hear that people are reading through this full thread.
Why the desire to stay stock height or higher?
What type of improvement are you looking for specifically?
- Andrew
Old 05-05-2015, 03:26 PM   #2485
CSG Mike
CSG Mike's Avatar
Any top shelf custom valved 1 way would get the job. Do you have a local dealer that can do something like that for you? Have you considered downsizing the tires to a 215 or even a 205 to get some more points?
Old 05-05-2015, 03:28 PM   #2486
CSG Mike
CSG Mike's Avatar
cheers!
-Bryan
Now that's an unusual request; most coilovers will force you to drop a bit to get full droop travel. If it's due to rough roads, keep in mind that better dampers will also absorb the road better, so unless you're flying over potholes, you shouldn't have any issues. If it's tough driveways... well... there's not really a fix for that
You can also get a 235/45/17 in some tires to get even MORE height.
BigFatFlip (05-05-2015)
Old 05-05-2015, 03:43 PM   #2487
SimplePortal
Drives: Hot Lava
Is there any significant difference between the OEM crash bolt and the SPC Camber Bolt Kit? Does one add more camber than the other? Or is one safer to use than the other?
SimplePortal is offline   Reply With Quote
Old 05-05-2015, 03:51 PM   #2488
D_Thissen
D_Thissen's Avatar
The OEM bolts are just a 14mm bolt. The SPC camber bolts have a cam lobe (see picture)that can be used to dial in how much camber you want. I have the SPC (or whiteline) bolts on my FRS and have had zero problems.
The Following 2 Users Say Thank You to D_Thissen For This Useful Post:
Racecomp Engineering (05-05-2015), SimplePortal (05-05-2015)
Old 05-05-2015, 03:55 PM   #2489
ja1217
I've considered it, but I think the 225 R7 is the tire to run. Also, right now Hoosier doesn't offer anything smaller than a 225 in a 17 inch tire. I'm not sure anything else would really be worth the points either.
My theoretical setup with 3 point dampers:
+5 Exhaust (header/overpipe/frontpipe)
+3 Dampers
+2 Springs
+6 Tires (225 Hoosier R7)
+2 BBK (I know everyone says that BBK isn't worth the points in TT, but I think my AP Sprint Kit might still be my favorite mod to the car)
+1 LSD (Cusco RS)
+0 E85 tune
19 points total (max in class) and I would probably be bumping right up against the max power to weight ratio for TTD as well.
Old 05-05-2015, 04:02 PM   #2490
ja1217
- Andy
Totally agree about the inverted strut/40mm rule and a tried to plead my case on the NASA forums, but no luck. Your T3 Clubsports were actually what I looked at first, but they I saw the piggyback canisters
I think I might have to give you guys a call when I'm ready to make the jump. JRZ RS1's are looking like it might be the one to go for, but still want to look around a bit more and I would need to sell my Ohlins first.
The Following User Says Thank You to ja1217 For This Useful Post:
Old 05-05-2015, 04:02 PM   #2491
+3 Dampers
+2 Springs
+1 LSD (Cusco RS)
+0 E85 tune
That sounds pretty good to me. Are bushings free?
- Andy
Old 05-05-2015, 04:10 PM   #2492
ja1217
- Andy
Some bushings are. I've already done engine mounts, whiteline rear crossmember inserts, shift bushing and diff cradle. Other free mods include DSS CF driveshaft, ACT Prolite clutch/flywheel. I'm probably forgetting some others too.
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
