Old 05-20-2015, 12:28 PM   #421
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Originally Posted by yomny View Post
This looks very nice..compared to that plastic piece of.. we have sitting on our engine. Sort of what the e92 m3 has, without the obvious ITB's. In for testing results.. and someone running these on their cars, NA or FI!
It looks like I'll be doing some testing on my car which is as near stock as I could keep it. The car has a mid-pipe back aluminum exhaust that likely does nothing for power, I just wanted some noise. Once I complete the testing here on the NA platform, FT-86 SpeedFactory will be doing FI testing on their time attack car .
VerusEric is offline
The Following 5 Users Say Thank You to VerusEric For This Useful Post:
IBill4You (05-21-2015), R2RO (05-22-2015), raven1231 (05-20-2015), SkAsphalt (05-20-2015), yomny (05-20-2015)
Old 05-20-2015, 12:55 PM   #422
nastynate88
nastynate88's Avatar
Drives: 2014 BRZ
Very excited to see what kind of power you can get NA!
nastynate88 is offline
Old 05-20-2015, 12:59 PM   #423
gramicci101
Off Topic
Would it be beneficial for the inside of the horn to be polished smooth, or is it not a big deal? Or do the slight ridges perform some function that I am unaware of?
gramicci101 is offline
Old 05-20-2015, 01:05 PM   #424
VerusEric
VerusEric's Avatar
Likewise. This was designed to benefit FI more so we are very curious to see how NA will react.
It is not a big deal. That is just how this machinist decided to finish the bell horns. The ridges are very small and more aesthetic than actual ridges (probably 10 thou max between peak and valley).
Old 05-20-2015, 01:05 PM   #425
HUNTERANGEL121
HUNTERANGEL121's Avatar
Drives: Red Toaster(Dodge Nitro)
As far as I'm aware. The ridges are from the manufacturing of the horns. Polishing it would mean less resistance and turbulence I guess.
Sent from my toaster
I mostly lurk, still don't own an 86...
HUNTERANGEL121 is offline
Old 05-21-2015, 12:53 PM   #426
fika84
fika84's Avatar
@NotEric6.. is this thing installed on your car yet or what??? This suspense is killing me!
fika84 is offline
Old 05-21-2015, 03:03 PM   #427
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Make the manifold slighty higher and add a throttle body to each veolcity stack so you can have debris-less ITB's ;D
cdrazic93 is offline
Old 05-21-2015, 06:56 PM   #428
burdickjp
Drives: 2013 ultramarine Scion FR-S
If that is the case then their CNC programmer has gotten so bored he's doing some very strange things with tool paths.
burdickjp is offline
Old 05-21-2015, 07:43 PM   #429
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
I don't want to hijack your thread, but your aluminum exhaust has piqued my curiosity - can you tell us a little about it and post some pictures? If not here, then maybe on another thread?
RJasonKlein is offline
Old 05-21-2015, 07:48 PM   #430
VerusEric
VerusEric's Avatar
I'm hoping this weekend .
Space is an issue.
It was milled, not turned. So realistically the cut time was the same regardless. If we take this exact design to production (which is very much unsure right now), it will be a turned part.
PM'd
Old 05-21-2015, 08:06 PM   #431
2much
I wanna go fast
Drives: 2013 FR-S 6MT
what aluminum exhaust??
2much is offline
Old 05-21-2015, 09:40 PM   #432
burdickjp
It'd be impossible to do that on a lathe which doesn't have live tooling!
Of course it's milled. It's still a funky toolpath. Maybe they had difficulty getting a conventional path to work and this was the best way they could minimize tooling marks? I'd argue that's what post processing is for. Of course customers would rather see a sexy milled part than something which has been finished by sanding. I'm more of a form follows function kinda guy.
Are you going to finish these prototypes out to a smooth interior surface?
Old 05-21-2015, 10:02 PM   #433
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Space is an issue.
The Following 3 Users Say Thank You to cdrazic93 For This Useful Post:
civicdrivr (05-21-2015), gramicci101 (05-21-2015), HUNTERANGEL121 (05-21-2015)
Old 05-22-2015, 06:21 AM   #434
Calum
That Guy
Drives: 2013 asphalt FRS MT
Why would it be impossible to turn a bell mouth on a lathe?
Calum is offline
FT-86 SpeedFactory LCA by Verus - Lightest LCA for the Twins - Development Thread FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 236 06-20-2019 01:42 PM
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 01:43 PM
Intake manifold viking Engine, Exhaust, Transmission 6 09-23-2014 11:08 PM
Oil on/around Intake Manifold Wepeel Issues | Warranty | Recalls / TSB 2 05-12-2014 11:40 PM
WTB: intake manifold carlitosway6891 Engine, Exhaust, Bolt-Ons 0 06-22-2013 02:24 PM
