Old 05-20-2015, 12:06 PM   #1
Ms. FR-S
Drives: 2013 Scion FR-S, 1993 Mazda RX-7
Trunk opens randomly?
Hey all! I've done a search but can't seem to find any other threads on my problem. The trunk on my 2013 (purchased in August 2012) FR-S has started opening at random times. I first noticed it a few days ago when I was leaving a gas station. As I was leaving, I noticed that my trunk light was on so I pulled over and shut the trunk. I assumed I had pressed it accidentally. I noticed it the next day as I was leaving a friend's house, and again later that day as I was driving home. It popped on while I was driving! I pulled over and checked, and sure enough my trunk was open again. As I was leaving work this morning it popped open again.
Anyone have any thoughts or ideas? I did check to make sure nothing was caught on the trunk release latch, but I think I may empty my trunk completely just to be totally sure nothing is somehow snagging it.
Ms. FR-S is offline   Reply With Quote
Old 05-20-2015, 12:17 PM   #2
swarb
try locking it from the button in the trunk and see if it happens again. I don't have any other ideas except wonky/stuck key fob button.
The Following User Says Thank You to swarb For This Useful Post:
Ms. FR-S (05-22-2015)
Old 05-20-2015, 01:04 PM   #3
kch
Senior Misanthrope
kch's Avatar
Is the button getting pressed while in your pocket? I've had that happen a couple times when wearing tighter pants.
The Following User Says Thank You to kch For This Useful Post:
Old 05-20-2015, 01:07 PM   #4
HunterGreene
Hail Magnet
HunterGreene's Avatar
^This will help you isolate if its a faulty latch (it will still pop open), or if you are accidentally pushing the button or have a faulty key fob (won't pop open)
Are you not hearing the latch pop open? When i use the key fob or the button in the car, it is a very noticeable *chunk* noise when it opens.
Third option is that someone has been putting tiny invisible people in your trunk, and they keep trying to escape.
It has priests in it?
The Following User Says Thank You to HunterGreene For This Useful Post:
Old 05-20-2015, 01:18 PM   #5
[QUOTE=HunterGreene;2256054
Third option is that someone has been putting tiny invisible people in your trunk, and they keep trying to escape.[/QUOTE]
Or tiny visible ones that succeeded!
Eski (05-20-2015), Ms. FR-S (05-22-2015)
Old 05-20-2015, 01:32 PM   #6
SubaruLifer
Drives: 2015 ISM BRZ Premium
It could be that the latch is getting stuck. If none of the above works for you, try spraying the latch with some WD-40.
I had something similar happen with the hood on my '02 Impreza.
SubaruLifer is offline   Reply With Quote
The Following User Says Thank You to SubaruLifer For This Useful Post:
Old 05-20-2015, 02:09 PM   #7
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
I had a bowling bag in my trunk that snagged the emergency release handle as it rolled over a couple of times and popped open the trunk. Got anything like that rolling around back there?
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
The Following 2 Users Say Thank You to jeffchap For This Useful Post:
Ms. FR-S (05-22-2015), strat61caster (05-20-2015)
Old 05-20-2015, 03:05 PM   #8
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
buy a big spoiler to push down and keep it closed?
The Following 2 Users Say Thank You to continuecrushing For This Useful Post:
Kevinn (05-22-2015), Ms. FR-S (05-22-2015)
Old 05-20-2015, 03:36 PM   #9
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Seconded, had a laundry basket catch it and pull the emergency handle from inside during a freeway off-ramp.
ineedyourdiddly
Old 05-20-2015, 05:04 PM   #10
Ddreder
Ddreder's Avatar
Drives: 2013 FR-S, 1990 Miata
I had this happen while I had stuff in my trunk. I went around a corner too fast and as usual I heard a thud. When I got to where I was going I noticed the door open light was on. Turns out my stuff slammed into that lock button thing in the trunk and it opened somehow? Either that or the strap from my bag wrapped around the emergency release strap on the latch and it opened it as a turned and slid and hit the lock button on the wall! anyways I wish there was a cargo net or something that came with the car. I keep beating up my trunk by corning to hard.. I guess I need to start practicing with the water cup in my cup holder
Ddreder is offline   Reply With Quote
The Following User Says Thank You to Ddreder For This Useful Post:
Old 05-20-2015, 07:55 PM   #11
Maybe the trunk monkey is just messen with you, by yanking on the emergency opener handle ......
Ms. FR-S (05-22-2015), roddy (05-22-2015)
Old 05-20-2015, 10:17 PM   #12
BRZnut
Drives: BRZ DGM Limited
LOL..haven't though about the Trunk monkey for years...For those that never saw it:
[ame="https://www.youtube.com/watch?v=Rx6WB5YJia8"]The offficial Trunk Monkey Trilogy. - YouTube[/ame]
The Following 2 Users Say Thank You to BRZnut For This Useful Post:
humfrz (05-20-2015), Ms. FR-S (05-22-2015)
Old 05-22-2015, 11:20 AM   #13
Ms. FR-S
Thanks for all of the suggestions! I've tried resetting the trunk release button and removing my (large) autocross box from the trunk, and I haven't noticed it in the last couple of days. However, I've only had to drive a short distance to work these last few days, so I hope that one of those was it and it doesn't come back. Thanks for all of the tips!
The Following 2 Users Say Thank You to Ms. FR-S For This Useful Post:
humfrz (05-22-2015), Tcoat (05-22-2015)
Old 05-22-2015, 12:40 PM   #14
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
The trunk liner that Subaru makes does a good job of keeping stuff from sliding around.
Scenic Driver is offline   Reply With Quote
Used car from dealership randomly dies, what to do? mike the snake Off-Topic Lounge [WARNING: NO POLITICS] 11 08-20-2014 07:41 PM
Randomly getting CEL w/ code P0193 YMAA Issues | Warranty | Recalls / TSB 18 07-31-2014 04:18 PM
That Big Announcement Is Here! ECUTEK Opens Up! Pure Automotive Mid-Atlantic 3 12-19-2013 04:42 AM
Driver side window clicks everytime it opens umpadupa Issues | Warranty | Recalls / TSB 10 10-25-2013 10:20 AM
Car Alarm Randomly Triggers nathanR Electronics | Audio | NAV | Infotainment 2 09-03-2013 10:41 AM
