Canada Eh!
Drives: '13 FRS
225/45 or 235/40 on 17x7.5
Anyone here have any experience with a 235/40/17 tire on a 17x7.5" wheel?
I've seen plenty of examples where a 235/40 has been stuffed onto a 7.5" wide wheel, but I'm more concerned with performance. Does the pinched tire negate the added width of a 235? Is the shorter sidewall of a 235/40 better than a 225/45? Assuming we're comparing the same tire for the purpose of autoslalom... Is it better to just stick to a 225/45? Looking to upgrade the tires before the next event, not quite sure what size to order.
#2 |
Alexandrino_Auto
Drives: series.Blue
There is no blanket answer to this question. Every tire is different. I ran a 225 A5 Hoosier on a 13x6" wheel, but would I run a 225 MPSS on a 17x7" wheel, no. You need to figure out what tire you want to run, then pick a wheel choice. It's not as simple as picking X size tire and fitting a wheel.
The common trend is to stretch a side wall for "faster turn in and more steering response." In many cases doing this couldn't be further from the truth. The A5 I ran was designed to be a cantlevered tire. The sidewalls hung 1/2" over the wheel.
The Shadetree Project: I turn wrenches
| The Following User Says Thank You to Hyper4mance2k For This Useful Post: | Joe-G (05-19-2015) |
#3 | |
Canada Eh!
Drives: '13 FRS
I'm stuck with a 17x7.5 wheel, and I would like to run either a Dunlop Direzza ZII/ZII* or the Hankook RS3 V2. Was hoping someone here would have a bit of experience with this similar setup so I can make a better decision. |
#4 |
The Stig's German cousin
General internet wisdom says the RS3 doesn't take well to pinching. Go 225 RS3 or 235 star spec.
FYI I run a 245 Rival S on a 7" wheel. The "feel" is a little mushy compared to 225 but otherwise it's making plenty of grip. |
| The Following 2 Users Say Thank You to renfield90 For This Useful Post: | Hyper4mance2k (05-19-2015), Joe-G (05-19-2015) |
#5 | |
Alexandrino_Auto
Drives: series.Blue
The taller the sidewall the larger range of wheel widths it will fit. Dunlup recommends the ZIISS 234/45 on a minimum of a 7.5 the 225/45 fits on a 7. The 225 will give you better turn in on a 7.5 at the expense of overall grip. That's a decision you have to make based on how you like the car to drive. Personally I'd go with the 235/45. The same applies to the RS3V2. You can look up the manufacturers recommended wheel widths per tire.
#6 | |
Canada Eh!
Drives: '13 FRS
| 245/40 on 17x7? | 艾洛 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 05-06-2015 03:13 PM |
| 17x7 +25 Or Less | Snake | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 02-05-2013 06:46 AM |
| 17x7.0 vs 7.5 | G4mb17 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 06-14-2012 01:32 AM |
| Volk Racing GT-C 17x7 and Gram Lights 57 Optomise 17x7 | xravexboix | Wheels and Tires | 0 | 05-24-2012 08:04 PM |
