#463 |
Drives: bmw
oem radiator?
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com |
#464 |
Yep.
#465 | |
Drives: 2013 Subaru BRZ Limited (WRB)
For those wanting a comparison for an aftermarket oil cooler on a stock power car driven very hard on track during a warm day: Jackson Racing Oil Cooler N/A BRZ (no power mods) Track: Road America Ambient Temp: 75F Highest Oil Temp: 224F Highest Coolant Temp: 210F |
#466 |
Ambient was around 20C. The track is Calabogie just outside of Ottawa.
It was the first day of the season for me, so I wasn't pushing terribly hard through all the corners but I had it to the rev limiter on the main straight pretty much every time. |
#467 | |
Drives: bmw
[ame="https://www.youtube.com/watch?v=CL5OeHDvIHc"]Subaru BRZ at Autobahn race track in joliet with mvp track time - YouTube[/ame] i'll be back out here again in 11 days for a 2 day weekend with bmw, and my first track day of the year. will be stage 2 flex fuel so maybe e85 maybe 93? also now have koyo radiator, this oil cooler, and the headers will be swaintech coated. all in maybe too many variables to really get a good feel for what just the oil cooler does, nonetheless i'll have data after that weekend.
#468 |
Drives: RX-7 / BRZ
Tried this with my turbo kit using it for cooling before getting a regular air-to-oil cooler. I did notice a difference. Warmups in the morning to 150F seemed almost 3-5min quicker. Temps in general stayed about 3-5F cooler, however when the car was pushed to an oil temp above 220-230F the OEM cooler seems to get heatsoaked and the ability to lower the temps signifigantly reduced. I should add all my testing was done on a turbo (Full Blown) car with their upgraded (bigger) radiator, and Spal 12" dual fans.
IMO it is NOT sufficient by itself for oil cooling and turbo applications on our platform. It however seems to be great for getting up to temp faster. It helps on the daily drive sure but, any sort of beating on the car or forbid a track day will make this cooler useless. I however really do like the quicker warmups (based on oil temp gauge,) and didn't want to part with it, yet still need better oil cooling... so.... I called Mishimoto who has a new oil cooler setup for their 2015 WRX that works WITH the OEM WRX/Forester oil cooler setup. They (though customer service) let me buy just the adaptor sandwhich plate and threaded center bolt/nut for $15+shipping that fits onto the OEM style oil-cooler, clearing the larger anti-spill ring around the oil filter. Here is the part numbers... or what is on my invoice for the bolt and sandwhich plate. -Mishimoto 288 Kitted in US $7.50 Extended: $7.50 -Mishimoto 1020 Kitted in USA to make MMSPA-M20. M20 x 1.5 -- M20 x 1.5 (no dashes) w/ zipper poly bag. $7.50 Extended: $7.50 Will let you guys know how it goes. Hope to have the parts by next Wednesday.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
#469 |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
You're saying that thing is only $7.50?!?!
#470 | |
Drives: RX-7 / BRZ
Right now my setup is looking like Mishimoto adaptor plate, $7.50 Mishimoto center bolt, $7.50 Setrab 19row, $180.00 Earls -10AN fittings, $49.00 Braided oil line 6', $50~ish Whole setup looks to be just under $300~
| The Following 2 Users Say Thank You to Kiske For This Useful Post: | Hyper4mance2k (05-16-2015), sroby (01-28-2019) |
#471 |
Boosted Noob
Looks like the bolt itself is $22 MSRP and you might have gotten an early version of the WRX sandwich plate that isn't on their website yet?
http://www.mishimoto.com/stainless-s...apter-m20.html |
#472 | |
Drives: RX-7 / BRZ
#473 | |
Drives: bmw
ok fellas i have a bunch of data and pics.
first up is autobahn full in august. i don't recall outdoor temps and am too lazy to look up. iirc i don't think the airaid was even in at this point. actually now i'm thinking it was. in any case, here is my data from several sessions from the day. i have oil temp (blue), coolant temp (red), and intake temp (green) all on the left axis in F - on the second axis for shits although not that interesting is first cat temp (thin purple). i'm using amsoil 0w20 signature series in these first two charts. ![]() so pretty hotsy motsy and where i rendered this data on one of my videos. [ame="https://www.youtube.com/watch?v=CL5OeHDvIHc"]Subaru BRZ at Autobahn race track in joliet with mvp track time - YouTube[/ame] i did a day at gingerman a bit later. also hot stuff. ![]() i sent in the oil for analysis to blackstone. it was freshly put in oil, after the autobahn full track day (single day) iirc. they responded with this: ![]() obd2 does not provide oil pressure. i was a bit worried. per @Dezoris's thread/vid http://www.ft86club.com/forums/showthread.php?t=76760 Quote:
based on the above, i decided to try a heavier oil. although the manual also says 5w30, i went for 10w30. no FI and i figured 30 seemed heavier enough to provide benefits. my (internet myth?) understanding is the narrower range means it can withstand more "abuse" - based on essentially nothing. some of the stats between 5w30 amsoil signature and 10w30 look close enough that i'm wondering if i bought the wrong oil, and that 5w30 would take the same heat but be better for cold starts. installed a bunch of shit since these track days - flex fuel kit, delicious stage 2 tune ceramic coated jdl el catted header - amazingly you can touch it after a session gold wrapped my intake zeek air scoop snorkel forester oil cooler koyo radiator so not apples/apples with only one element changed here. also installed sandwich plate with oil pressure and temp guages. i set the "oh noes" mark for oil at 260 and pressure at 40. now that i have all this infos, it was interesting to me to see how long it actually takes to warm up the oil. although it is now quicker to warm it up than without this kit, it still takes a few minutes - i never realized that. my putzing around town seems to sit around 180-190 degrees. being more of a bone 200-210. cruising down the highway sitting at 80-85 i hit 220, 60 psi and at 3.5k rpm. [ame]http://www.youtube.com/watch?v=zKKKnGRVXB8[/ame] no data or video for pressure on track but i appear to have more favorable results than dezoris. i will mount a camera to the left of my helmet this saturday at gingerman to get a view of them. i was concentrating more on driving and had an instructor as well, so didn't want to appear (and be) distracted looking at these things, but what i did notice - oil would get up to 240-260 but around 6000 rpm, iirc, my pressure was still looking pretty good - 60+. this seems much better than the results above. i also noticed during cool down the temps rapidly came down. certainly working great there. the first day was my first track day for the year, and the first 2 sessions were quite wet. i got braver on the next 2 as it dried out and i was becoming more familiar with the car and track and driving at my own pace again, which i consider an intermediate+ driver. the second day was cooler out but stayed dry. it might have been around the same temp in the afternoon (70s/low 80s?). these were 25 minute sessions. the data is as follows: ![]() ![]() i parked next to my buddy jeff with an e36 m3 that seems to be reliable as hell, and he appears to cruise all day long with no problems at 200. a few cars down was a guy with a gutted e46 m3 and a bigger aftermarket oil cooler who gunned for 240-260. so that being not ideal, but kind of acceptable, at least made me feel a bit better about my temps. i flirt with the idea of a twin screw sc kit some time next year, although probably better for me to get more seat time than more power (but hard to resist!) in any case i am looking for opinions on the current situation. if heat is the enemy it would seem arguable that i should simply get a regular air oil cooler. note i am in chicagoland but do not drive this in the winter (although would when it is cooler out but not snow season.) or if this is an acceptable range and my oil pressure is acceptable, perhaps i should simply happily cruise along with the state as-is until i do do something more drastic like add FI? thoughts? tagging a bunch of people from track/oil threads. @Dezoris @CSG Mike @Amadeus @rice_classic @smbrm @smbstyle @Dave-ROR @CSG David
#474 | |
I responded to your FB post. But long story short in the summer you can run 10w30 just keep a close eye on your pressures near 7400, you don't want to be running in the 40psi range. If you start running longer sessions and getting faster you can switch to 10w40 but only during summer/hot months then go back to 0w20 if you are running in the winter as heating up 10w30+ takes a lot longer here. Your coolant based oil cooler will help heat up faster but still longer. Also once your radiator heat soaks you lose your cooling efficiency from the cooler you have, since you are tuned have your tuner switch your coolant fan activation point to 200F, this will help get you anywhere from 5-10F cooler on track in terms of oil and coolant temps on average. From there your option becomes a liquid to air setup like most people run and your only option for FI along with 10w40/10w30 for track in summer months.
#475 |
Drives: Nevermorange FRS
260 oil temp is hot, but nothing to worry about, especially if it's measured in the pan.
Too little oil pressure is something to worry about. Here's my thought on that... If you double duty the car, then bump up the oil weight and make the fans come on sooner (like Dezoris said). If you find that you have to bump the oil wt so much it becomes a bad option for daily driving (like if you need a 20w-50) then you may want to consider a pressure relief valve shim. A 5w-40 might be where you end up which is fine for double duty (DD/Track) in the summer time but you'll want to go back to a 0w-20 in the winter. Finally, since your radiator is doing double duty (also heat-exchanging your oil) then you're going to want to increase it's efficiency which can be done by bringing those fans on earlier (like 180F) and installing shrouding around your radiator so no air can escape around/below/above it and thus way more air will be forced through it and your radiator efficiency will increase quite a bit which will help reduce cooling system heat soak which stands a good chance of bringing down the oil temps a bit and in doing so will also increase oil pressure (oil won't be so thin). Stay safe, have fun.
PRO86 | WTCC | STL
#476 | ||
Drives: bmw
is what i lost, my understanding to be more friction at cold temp startups now, from 40/50 degrees upwards (spring/summer/fall) meaningful? what would i lose by going 5w40?
| Tags |
| brz, fxt, oil, oil cooler |
| OEM Oil cooler from the 2.0 DIT Forester | Kostamojen | Engine, Exhaust, Transmission | 119 | 09-10-2019 05:28 AM |
| Bought a 2014 Subaru Forester | EAGLE5 | Other Vehicles & General Automotive Discussions | 10 | 10-02-2013 12:54 PM |
| 2014 Forester key fob - nicer than BRZ | Turbowned | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 04-17-2013 03:35 PM |
| BRZ 2.0L Turbo in 2014 Forester | Sleeperz | BRZ First-Gen (2012+) — General Topics | 37 | 03-21-2013 06:42 PM |
| Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… | 2013GTRNate | BRZ First-Gen (2012+) — General Topics | 12 | 02-01-2013 12:29 PM |
