Old 05-15-2015, 04:44 PM   #15
wparsons
wparsons's Avatar
Amazing! I might be stopping by the race at some point, if it's looking like that's the case I'll shoot you a PM to see if I can get in touch to say hi (if he's not too busy).
flickr
Old 05-15-2015, 04:45 PM   #16
Racecomp Engineering
Sounds good!
- andrew
Old 05-15-2015, 11:39 PM   #17
OkieSnuffBox
Drives: '23 BRZ Limited
Racecomp, figure it out. Those KW3 rates are way too low for HPDE/AutoX people on wide sticky tires!
OkieSnuffBox is online now   Reply With Quote
Old 05-16-2015, 12:59 PM   #18
Calum
That Guy
Drives: 2013 asphalt FRS MT
What advantage does this product have over buying the same pieces individually.
Old 05-16-2015, 01:02 PM   #19
Calum
That Guy
Are you suggesting that Racecomp should fix the issue?
The Following User Says Thank You to Calum For This Useful Post:
wparsons (05-16-2015)
Old 05-16-2015, 01:18 PM   #20
churchx
churchx's Avatar
Drives: 2014 GT86
OkieSnuffBox: Different kits are made for different purposes/customers. I haven't seen any rules set in stone that each and every aftermarket coilover kit should be designed/made/optimized/sold for track racing. Especially if daily driving crowd may outnumber racers by a lot.
Old 05-16-2015, 02:55 PM   #21
x1UP
One & Done (AOZORA)
x1UP's Avatar
Drives: '15 Series.Blue BRZ (WRB)
If I weren't getting Ohlins, I would most definitely have gotten these because.. @Raceseng.
"I have the need....the need for speed! - Maverick (Top Gun)
x1UP is offline   Reply With Quote
The Following User Says Thank You to x1UP For This Useful Post:
Raceseng (05-18-2015)
Old 05-16-2015, 04:00 PM   #22
rlpaul
Drives: point A to point C. Screw point B!
Agreed. Wish Ohlins came without plates, as I'd like to get them with the Raceseng plates instead.
rlpaul is offline   Reply With Quote
The Following User Says Thank You to rlpaul For This Useful Post:
Old 05-16-2015, 06:18 PM   #23
wparsons
wparsons's Avatar
One payment, one shipment.
flickr
Calum (05-16-2015)
Old 05-16-2015, 06:19 PM   #24
Calum
That Guy
FT86speedfactory can provide that.
Old 05-18-2015, 11:20 AM   #25
Raceseng
Raceseng's Avatar
This package is the same as buying them individually. We simply wanted to offer our potential top mount customers an integrated solution.
Raceseng is offline   Reply With Quote
The Following 2 Users Say Thank You to Raceseng For This Useful Post:
bumppinKota (05-18-2015), Calum (05-18-2015)
Old 05-18-2015, 02:21 PM   #26
CSG David
CSG David's Avatar
The plates have been great for us and our clients. No reported failures on our end and you already know how many got sold through us.
Hope we can work on some projects for you in the future.
The Following 2 Users Say Thank You to CSG David For This Useful Post:
Raceseng (05-18-2015), whataboutbob (05-24-2015)
Old 05-23-2015, 12:08 AM   #27
h3opama
You need to double check the spring rates on your KWs. They have not sold V3s with 343/400 lbs/in spring rates in a while.
The correct spring rates are 230/285 and judging from the pics on your website, that's what you have. I can see the marking on the rear spring.
Most shops are still advertising the wrong spring rates and that bothers me since it misleads customers, but you just need to look at the springs...
- Andrew
How can you tell that the rates are 230/285 instead of 343/400 in the picture?
h3opama is offline   Reply With Quote
Old 05-23-2015, 11:26 PM   #28
I could see the writing on the springs on the pics in their website.
- Andrew
FS: New Raceseng Cam Plate FT86POWER Engine, Exhaust, Bolt-Ons 2 08-13-2014 03:42 PM
Raceseng cam plate grostoine Engine, Exhaust, Transmission 5 12-09-2013 05:28 PM
Raceseng | Go Pro Tow Hook Raceseng Cosmetic Modification (Interior/Exterior/Lighting) 18 11-23-2013 04:25 AM
Raceseng | Tug Tow Hook Raceseng Cosmetic Modification (Interior/Exterior/Lighting) 3 09-24-2013 11:21 AM
Raceseng | Tug Tow Hook Raceseng Tracking / Autocross / HPDE / Drifting 9 08-21-2013 10:19 AM
