Old 12-08-2013, 04:03 PM   #1
grostoine
Drives: Subaru BRZ
Raceseng cam plate
Does anyone have ever tried this plate?
I redid the gasket with permatex grey gasket maker and after one year, there is still oil dripping on the overpipe. I wante to know if it corrected the problem?
http://www.raceseng.com/cam-plate-20...r-s-subaru-brz
I wanted to know if we have to put some permatex on these too..?
grostoine is offline   Reply With Quote
Old 12-09-2013, 12:06 AM   #2
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Yes you do. I did not have the oil leak problem but got this at a very cheap price when they first released so I figured why not.
SubaSteve is offline   Reply With Quote
Old 12-09-2013, 08:43 AM   #3
jamesm
doesn't that thing exist to solve an oil leaking problem? did it leak with the stock piece?
Old 12-09-2013, 08:54 AM   #4
cnk
Drives: '13 DGM BRZ Limited
You just have to use 2 dabs of sealant where the 2 halves of the casting meet up on the engine. If you look at the circular opening you'll see a gap at the top and bottom. The o-ring on the Raceseng plate will seal around the opening, but the sealant is used to fill in those 2 gaps. I put mine on a few months ago and have no further issues.
cnk is offline   Reply With Quote
Old 12-09-2013, 03:50 PM   #5
grostoine
Drives: Subaru BRZ
So you are saying I will need to put some gasket maker on top and at the bottom even with the raceseng cam plate?
Old 12-09-2013, 04:28 PM   #6
cnk
Yes, it's in the directions that are included when you get the plate.
Oil leak solved - Raceseng billet aluminum cam plate Clipdat Issues | Warranty | Recalls / TSB 156 06-17-2020 11:29 PM
Raceseng | CasCam - Caster + Camber Plate Black Friday Sale Raceseng Brakes, Suspension, Chassis 0 11-30-2013 11:09 AM
Raceseng | Cam Plate - Stop your oil leak! Raceseng Groupbuys 63 10-18-2013 03:31 PM
Raceseng | Cam Plate - Stop your oil leak! Raceseng Engine, Exhaust, Transmission 2 09-21-2013 07:47 PM
[For Sale] Rho-plate Tow Hook Mounted License Plate rack pizzahead20 Canada Classifieds 0 08-23-2012 12:06 AM
