Old 05-12-2015, 05:54 PM   #29
poorsche
poorsche's Avatar
Drives: 13 BRZ Limited, 2000 Impreza Sport
Originally Posted by tato.valverde View Post
This looks awesome!! I'm thinking of doing this, but spraying the housing with a matte black (plastidip maybe?). I love the edge you did, and the reflective parts painted with niteshades.
Also, you seem to really recommend that tape you used, but the link is dead... can you update the link or tell me what kind of tape that was?
Thanks!
It's 3m vinyl tape, 1/4 wide
Innovate powered- Corn fed- FBM tuned
poorsche is offline   Reply With Quote
The Following User Says Thank You to poorsche For This Useful Post:
tato.valverde (05-14-2015)
Old 05-13-2015, 12:27 PM   #30
Griffon
Drives: Subaru BRZ
Originally Posted by amaciose View Post
No effect on the brake light if you paint it like @poorsche did. This was one of the main reasons I wanted to paint the inside rather than paint the lens. The turn signal is noticeably dimmer though, I might consider switching to LEDs. I'll try and post a picture in the next few days.
Thanks for the info
Griffon is offline   Reply With Quote
Old 05-14-2015, 11:05 AM   #31
tato.valverde
tato.valverde's Avatar
Drives: Scion FRS RS1.0,Mazda MX-6 2.5i 4WS
Oh well, I bought the 1/8 inch already, let's see how it goes!
tato.valverde is offline   Reply With Quote
Old 05-15-2015, 01:26 PM   #32
Mil_Gates
@poorsche, couldn't you just warm the lights up a little bit to separate the lens from the rest of the housing instead of cutting the housing?
Mil_Gates is offline   Reply With Quote
Old 05-15-2015, 02:35 PM   #33
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
no unfortunately if that was the case everyone would be doing there tails lol
The Following User Says Thank You to NyC Zn6 For This Useful Post:
Mil_Gates (05-15-2015)
Old 05-15-2015, 10:32 PM   #34
Mil_Gates
Ok, i wasn't sure if they were sealed the same way as the headlights. Thanks!
Old 05-16-2015, 09:00 AM   #35
914_WHITE_FRS
914_WHITE_FRS's Avatar
Drives: White 2013 Scion FR-S
holy shit...! this looks really good!
914_WHITE_FRS is offline   Reply With Quote
Old 05-21-2015, 05:50 PM   #36
kseipel
Drives: FRS 2014 Asphalt
Can you please do this for me just with different stuff to be done? How would you like to be in contact? Email? Txt?
kseipel is offline   Reply With Quote
Old 05-22-2015, 06:48 PM   #37
kseipel
How do I contact you to do this!!!!!!??????
Old 08-19-2015, 08:03 PM   #38
tato.valverde
Thanks for the tutorial!!!
I'm extremely happy with the look!
I didn't paint the turn signal reflector for legal reasons, but the rest is pretty much what you suggested.
However, I used a soldering iron and don't recommend it at all, get a dremel and do it right, people
The Following 2 Users Say Thank You to tato.valverde For This Useful Post:
poorsche (08-29-2015), shifter907 (08-20-2015)
Old 08-20-2015, 02:08 PM   #39
Bamsterman
Drives: 13' Scion FRS
I've been looking at buying some aftermarket tails, but I'd much rather do this! I'll buy a used set and do the work on those. Looks amazing!
Bamsterman is offline   Reply With Quote
Old 08-20-2015, 07:10 PM   #40
olsonpg
olsonpg's Avatar
Drives: BRZ. R34 GT-T
Are you still doing this OP? I would definitely be willing to pay the 150.00.
Thanks!
olsonpg is offline   Reply With Quote
Old 08-20-2015, 08:30 PM   #41
olsonpg
olsonpg's Avatar
You said you used Nite Shade for the reflective bits, does that include the turn signal chrome housing??
THanks in advance.
Old 08-22-2015, 10:51 AM   #42
waltco
waltco's Avatar
Drives: 2013 Subaru BRZ
I wish I knew about the tape when I did this, I had absolutely no patience for the RTV method and within hours I had condensation. Also, Dremel is quick but cuts are messy, definitely going to try the heat method!
Edit: Could you go into detail on the sealing process?
waltco is offline   Reply With Quote
housing, lights, oem, retrofit, tails
Trade: Black Spyder V1 Tails for Tom's Tails Cross Exterior Parts (Aero, Lighting, Etc.) 3 07-05-2014 04:19 PM
Painting tails red. Is it worth wet-sanding/clear coating? nodeal Cosmetic Modification (Interior/Exterior/Lighting) 25 04-01-2014 05:17 PM
Autobody Shop/Painting Near Me ? Issue with Painting Carbon Fiber Hood? ScionFR-S Cosmetic Modification (Interior/Exterior/Lighting) 20 11-08-2013 01:51 PM
Painting the inside of the FR-S DealerFR-S Cosmetic Modification (Interior/Exterior/Lighting) 21 07-10-2013 11:29 PM
WTT: MY USDM Tails for your JDM/ADM/UKDM Tails ZC6BRZ Exterior Parts (Aero, Lighting, Etc.) 2 01-16-2013 11:24 AM
