Old 06-02-2013, 02:21 PM   #15
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Originally Posted by frslee View Post
You need to work out son. I see that belly covering seat belt.
I'm 6'3" 175lbs 33" waist with less than 15% body fat. I had the seat belt pretty tight, that's why. LOL
Anyway after 1,000km of street driving, the front brake rotors are almost flat now. What pads do you recommend for street and ocassional track use?
HRTROB is offline   Reply With Quote
Old 06-02-2013, 06:47 PM   #16
Hanakuso
Originally Posted by HRTROB View Post
So consistent hard braking can scar/score the rotor? I was thinking that maybe a few stones got stuck in there when I spun out and went off track trying to drift Lol
Your face was priceless I'm surprised they didn't make you remove the cups and stuff. That coffee might burn your crotch off.
Hanakuso is offline   Reply With Quote
Old 06-14-2013, 02:20 PM   #17
ollepellijeff
Thule Dude
ollepellijeff's Avatar
Drives: Scion FR-S
Changed my pads to the StopTech ones and it did make a big difference. Ran Thunderhill two day event where we had 117 degrees on the Saturday. Pretty sure the stock pads would have totally died on that hot day but the Stoptech pads help up pretty fine. I think the slight fading I got was more due to the brake fluid temperature.
ollepellijeff is offline   Reply With Quote
Old 06-17-2013, 05:04 PM   #18
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Forget pads that are a compromise. Replace your OEM pads with another set of OEM pads (unless you don't like their feel and performance (on the street)). And buy yourself a set of track only pads, for the track.
Just swap them out before and after your track event.
Old 04-11-2015, 01:35 PM   #19
dchan
Drives: DGM BRZ
Sorry for the necro bump. I didn't want to create a new thread.
My rotors are in the same condition after taking them with the stock pads to the track. They don't catch a fingernail, but I can definitely feel them with my fingers. Should I replace with for next time? I'm definitely getting new pads.
dchan is offline   Reply With Quote
Old 04-14-2015, 03:04 AM   #20
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
Mine looks the same. Time to find new pads!
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 04-14-2015, 03:21 AM   #21
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Maybe, it just might be possible, that the stock pads aren't really up to the task of track day? Idk just seems like an assumption to me. Can anyone back this up?
Old 04-14-2015, 03:55 AM   #22
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Stock pads are unacceptable in track conditions for anyone with any experience. The stock pad compound (and fluid) was never designed to work in the temperature ranges that are common at the track.
Edit, as far as backing it up, I've seen the stock fluid boil way too easily and stock pads go from full to backing plate in one track day.
Decay107 is offline   Reply With Quote
Old 04-14-2015, 05:49 AM   #23
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I was being sarcastic lol
Old 04-19-2015, 12:06 PM   #24
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
^ Lol
@OP, that seems pretty normal. Even my stock brakes and pads at 12K miles have that same issue on my front brakes. I'd just make sure your pads are wearing correctly and you don't have any rocks or debris caught in there. I've seen some pretty crazy wear on the inside of rotors because the breaks weren't position correctly.
shiro is offline   Reply With Quote
Old 05-14-2015, 07:02 AM   #25
ajc209
Drives: GT86 Cosworth
I've been using Project Mu HC+ 800 pads and Dot 5.1 on my otherwise stock GT86 (unless you call an oil pressure gauge a mod). I make the front brakes smoke regularly, but no fade or soggy pedal after 20mins on track.
I get juddering due to this 'scarring' on the disc. Few 100 miles of street driving sorts it out usually.
Oh yeah, dont use 300C caliper paint either. It burns
ajc209 is offline   Reply With Quote
FS: NIB Hawk HP+ Front Brake Pads djfuller Brakes, Suspension, Chassis 4 02-22-2013 12:59 PM
Baer front and rear brake kits JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 12-04-2012 07:47 PM
Hawk HP Plus front brake pads on the track mtsound Tracking / Autocross / HPDE / Drifting 30 11-15-2012 03:24 PM
Gt to gts brake discs acro AUSTRALIA 2 11-09-2012 06:04 PM
Will the CD player play MP3 discs? Geezer Electronics | Audio | NAV | Infotainment 2 08-04-2012 09:37 AM
