Southern California SoCal
Old 05-11-2015, 08:13 AM   #15
SoCalArgento
Drives: 2014 Argento FRS
Originally Posted by PradiG View Post
stock toe arms are adjustable. You should be fine with them unless you plan to run over -5 camber in the rear. If you run over -5 in the rear, you will need new adjustable aftermarket toe arms.
I ran -4.3 camber and used the stock toe arms just fine. Hope that helps
Awesome, I should be good then.
SoCalArgento is offline   Reply With Quote
Old 05-11-2015, 10:46 AM   #16
scottxnizzle
scottxnizzle's Avatar
Drives: WRB BRZ
i got my alignment and corner balance done here. awesome guys! this is the only place ill be getting them done from now on.
scottxnizzle is offline   Reply With Quote
Old 05-11-2015, 11:17 AM   #17
SoCalArgento
Do you remember the cost for alignment and corner balance? I haven't had time to call them yet
I know there's a 1-2wk wait and it's best to call Monday
Old 05-11-2015, 11:59 AM   #18
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
Just called them and yes confirmed, they do prefer the SPL LCAs. I talked to Chris and the 4 Wheel Alignment and Corner balance is $280 Lifetime Warranty.
DuMa is offline   Reply With Quote
Old 05-11-2015, 12:01 PM   #19
scottxnizzle
Drives: WRB BRZ
I paid $250. I think just an alignment cost $90. Pretty pricey but I'm all about quality. They really take the time to work on your car which I like. I actually got lucky when I called them for an appointment, I got in the next day because someone cancelled.
The Following User Says Thank You to scottxnizzle For This Useful Post:
SoCalArgento (05-11-2015)
Old 05-11-2015, 12:04 PM   #20
SoCalArgento
Awesome info here! I think I will just get a simple alignment since im only on coilovers and stock wheels/tires. Probly will due the works when I finally get proper wheels and tires.
Old 05-14-2015, 03:26 AM   #21
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
I love this shop, they really care about the work they do and are very meticulous with how they do it. just don't ask about the "West End Gurlz" though....
[ame="https://www.youtube.com/watch?v=p3j2NYZ8FKs"]Pet Shop Boys - West End Girls - YouTube[/ame]
SuperDave is offline   Reply With Quote
Old 05-18-2015, 08:48 PM   #22
996garage
996garage's Avatar
Drives: 03' NSX & 13' BRZ 6spd Ltd white
FYI - here is a very informative video from the man himself...(Darin)
[ame="https://www.youtube.com/watch?v=QGC1IlRtoMw"]West End Alignment - Alignment Interview with Darin Nishimura about Subaru alignments - YouTube[/ame]
996garage is offline   Reply With Quote
West End Alignment Lunatic Scion FR-S / Toyota 86 GT86 General Forum 18 03-02-2015 06:58 PM
DIY alignment - quick way to set alignment while new suspension settles? 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-11-2014 09:53 PM
West LA supercroc Southern California 58 11-12-2013 01:17 PM
shop in west Houston for performance wheel alignment hankster Southwest 0 08-21-2012 06:08 PM
C-West BRZ ! Sylvain44 Cosmetic Modification (Interior/Exterior/Lighting) 12 08-11-2012 09:22 AM
