#15 |
Drives: 2013 Scion FRS 6 Speed Raven Black
I bought the TWM short shifter and guess what. It started rattling to! FML. How in the hell do you produce a vehicle that you can't even get rid of a shifter rattle!? A $300 short shifter even rattles, check mate, you are still f+%ked.
| The Following User Says Thank You to ohnoitsthefuzz For This Useful Post: | XtremeMaC (10-12-2016) |
#16 | |
Drives: 2014 Whiteout FRS
I had some time this weekend to mess around with the shifter and I believe I have found a definitive solution (at least for me). The reverse lockout plate was bolted too closely to the reverse lockout lever, so when the car was in 1st or 2nd the reverse lockout would still be in contact with the plate that prevents it from going into reverse. I moved the plate out further and now it only rattles for a moment once I hit redline. I plan to put some rubber mat in between a few of the pieces to completely eliminate the issue. |
| Audible shifter rattle | Hanzo | Issues | Warranty | Recalls / TSB | 134 | 08-17-2022 03:34 AM |
| Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? | soulstice | Cosmetic Modification (Interior/Exterior/Lighting) | 52 | 01-24-2016 09:20 PM |
| Shifter Rattle and Replacement | boredom.is.me | Issues | Warranty | Recalls / TSB | 19 | 04-27-2015 05:29 PM |
| 2014 Shifter Rattle | becauseracecar1 | Issues | Warranty | Recalls / TSB | 1 | 05-24-2014 07:06 PM |
| BRZ Shifter Rattle TSB | sc0urge | BRZ First-Gen (2012+) — General Topics | 2 | 08-26-2013 09:53 PM |
