Old 04-25-2015, 10:22 PM   #29
Chaetagnath
Drives: Whiteout FRS
Originally Posted by mikeTee View Post
@Guillaume, will the trunk button LED dim with the dimmer wheel?
As long as the illumination is tapped into the purple wire of the dimmer switch.
edit: Also, you must tap the black and white wire right next to the purple for your ground point. It technically controls the dimming.
Chaetagnath is offline   Reply With Quote
The Following 2 Users Say Thank You to Chaetagnath For This Useful Post:
Guillaume (04-28-2015), mikeTee (04-25-2015)
Old 04-25-2015, 11:20 PM   #30
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Originally Posted by Chad86 View Post
@ZOMFGAARON!
After purchasing through www.amayama.com I can say, from experience, this is definitely the best site to purchase OEM parts.
Good prices, international shipping and the parts arrived in less than a week with zero customs charges.
I highly recommend to anyone looking for OEM parts.
Glad to hear it post up pictures once you finish up the install!!!
Old 04-27-2015, 09:33 PM   #31
jazztennor
jazztennor's Avatar
Drives: Scion FR-s
where can i buy the wires here in the us???
Upgrades
EVO 3 Exhaust,Emblem swap,Full Carbon Interior,Greddy intake
jazztennor is offline   Reply With Quote
Old 04-28-2015, 09:45 PM   #32
jazztennor
jazztennor's Avatar
Drives: Scion FR-s
anyone??????
Upgrades
Old 04-28-2015, 10:26 PM   #33
mikeTee
Yup.
mikeTee's Avatar
Drives: MT Subaru BRZ '13
Originally Posted by jazztennor View Post
anyone??????
http://toyotaparts.bochtoyotasouth.c...ota/8299812750
mikeTee is offline   Reply With Quote
Old 05-03-2015, 01:05 AM   #34
Chaetagnath
Actually I think I was wrong. It's technically controlled through the ground wire, not the 12V+. So, you have to make sure you tap the black and white wire (pin 3) right next to the purple wire (pin 2) coming from the dimmer as your ground (as opposed to just grounding it on a bolt somewhere). The purple wire makes a convenient + wire to tap though since it's right there.
Old 05-03-2015, 02:56 AM   #35
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Nope. It does dim.
Guillaume is offline   Reply With Quote
The Following User Says Thank You to Guillaume For This Useful Post:
Chad86 (05-03-2015)
Old 05-03-2015, 11:13 AM   #36
Chaetagnath
Originally Posted by Guillaume View Post
Nope. It does dim.
What did you use as the ground?
The Following User Says Thank You to Chaetagnath For This Useful Post:
Chad86 (05-03-2015)
Old 05-03-2015, 11:30 AM   #37
Guillaume
Guillaume's Avatar
Drives: Exige S 240
The black and white wire.
Chad86 (05-03-2015)
Old 05-18-2015, 04:52 PM   #38
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
In Europe we have on GT86 this part no. SU00305478 from late 2014 (illuminated).
Trap63 is offline   Reply With Quote
Old 05-19-2015, 12:35 AM   #39
Guillaume
Guillaume's Avatar
Drives: Exige S 240
It is the same part number I give in the original post. It is not plug and play with pre-2015 cars, as explained.
Trap63 (05-19-2015)
Old 05-24-2015, 04:56 AM   #40
banane63
banane63's Avatar
Drives: BRZ Club blanc perle
Merci Guillaume ! T'as plus qu'à le mettre sur le site français !
Just a thing : if you remove the copper part, the moving part of the knob can be removed and then it is easier to remove the transparent top part from it.
Collecteur et frontpipe Supersprint full décat - Catback Remus
Admission directe Greddy - Kit Flexfuel et map Ecutek Visconti Tuning - Tein Street Advance EDFC Pro - NED modine - OZ Alleggerita 18 Michelin PS4 - Wilwood 6 pistons
banane63 is offline   Reply With Quote
Old 05-24-2015, 05:25 AM   #41
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Déjà fait
And thanks for the tip!
Old 10-14-2015, 02:52 PM   #42
mister.bond
Drives: BRZ Subaru
i was so sad about the situation that the Switch is not lighted !
i always had trouble to find it !
have done the Lighted Switch to my BRZ today,
Big Thanks from Germany for the Wonderful DIY !!!!!!
mister.bond is offline   Reply With Quote
The Following User Says Thank You to mister.bond For This Useful Post:
Guillaume (10-14-2015)
Trunk opener button fitcious Scion FR-S / Toyota 86 GT86 General Forum 13 05-13-2014 01:24 AM
Trunk remote or button won't pop open? 914_WHITE_FRS Issues | Warranty | Recalls / TSB 6 07-05-2013 10:08 AM
Trunk button not working Jahdai42 Issues | Warranty | Recalls / TSB 4 02-19-2013 08:03 AM
Trim removal - boot release button panel StuAU Cosmetic Modification (Interior/Exterior/Lighting) 2 02-04-2013 12:48 AM
Question for owners - Boot release button proficience AUSTRALIA 7 07-27-2012 11:12 AM
