Old 05-03-2015, 01:50 AM   #1
predator800
Drives: 2015 Scion FRS
17x9 245/40 question
Why isn't all my tire on the ground. The inside isn't as bad. Is it camber adjustment or 32lbs of air too much air for this size tire on this light of a car? Sorry if this seems like a dumb question to most. I'm a truck guy that just bought this car and I don,t much about putting biggar tires on little cars.
Thank you
or is it because the tire is slightly stretched
predator800 is offline   Reply With Quote
Old 05-03-2015, 01:53 AM   #2
08stiguy
08stiguy's Avatar
Drives:
Over inflation?
08stiguy is offline   Reply With Quote
Old 05-03-2015, 01:55 AM   #3
veck
veck's Avatar
Drives: 2014 Subaru BRZ
Camber. 32 psi isnt that much. Factory specs is 36psi.
veck is offline   Reply With Quote
The Following User Says Thank You to veck For This Useful Post:
predator800 (05-03-2015)
Old 05-03-2015, 01:59 AM   #4
ryoma
ryoma's Avatar
245 won't be stretched on 9" (roughly 225mm) wide wheels. what's your camber settings at?
The Following User Says Thank You to ryoma For This Useful Post:
Old 05-03-2015, 02:20 AM   #5
predator800
Camber is at factory setting. Car as 2000kms on it
Old 05-03-2015, 02:47 AM   #6
Digitalanalog
Drives: '13 BRZ Limited, '95 BMW M3
If this really is an issue you buy some aftermarket Lucas and set rear camber to zero. You'll be ok in a straight line but turning will be hell
Digitalanalog is offline   Reply With Quote
The Following User Says Thank You to Digitalanalog For This Useful Post:
Old 05-03-2015, 02:58 AM   #7
ryoma
ryoma's Avatar
it might be the angle of the picture, but are you sure that tire is 245/40? it doesn't look like it.
Old 05-03-2015, 03:10 AM   #8
predator800
Size:  262.4 KBName:  ImageUploadedByTapatalk1430637034.208571.jpg
Old 05-03-2015, 03:14 AM   #9
predator800
Not really an issue if this is normal for this size tire on this car. I'm just trying to make sure I'm running the car properly. This is the back tire. The front seem ok with 32lbs.
Old 05-03-2015, 03:29 AM   #10
ryoma
ryoma's Avatar
I would assume this is normal since you bought a wider tire than the rim itself so it's not effectively using the entire surface area. I would guess under loads like cornering, it would flex a little and use more of the side area. I'm not an expert in this though so take it with a grain of salt.
Old 05-03-2015, 10:21 AM   #11
Digitalanalog
It's normal and fine.
Old 05-03-2015, 01:34 PM   #12
AlexWood
Drives:
As long as the other side shows the same wear patterns, you have no issue.
AlexWood is offline   Reply With Quote
The Following User Says Thank You to AlexWood For This Useful Post:
Old 05-03-2015, 02:16 PM   #13
predator800
Yes both sides are the same.
Should I pump them back up to the suggest 35 pounds that marked in the door post or leaving them at 32 is ok.
Thanks for everyone's reply.
Old 05-03-2015, 02:58 PM   #14
cjd
cjd's Avatar
Drives: 2017 BRZ
As you corner more aggressively you'll find you use that part of the tire. With factory front camber you may have trouble doing that, but a good race alignment has even more camber all around (and more in front than in back)
The Following User Says Thank You to cjd For This Useful Post:
used RPF1 17x9 +35 or new Rota RT5 17x9 +42 Roadcone Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-12-2014 01:16 AM
17x9.5 +38 question einrejosh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-18-2014 10:48 PM
WTB: 18x9.5/ 18x9/ 17x9/ 17x9.5 Square With or without tires loogs Wheels and Tires 11 12-08-2013 03:40 PM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
17x9 235/45 vs 235/40 tires QUESTION karma003 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 07-21-2013 04:13 PM
