Old 04-28-2015, 04:31 PM   #323
sittinSideways
sittinSideways's Avatar
Drives: '13 Firestorm FRS
Originally Posted by Kostamojen View Post
Dunlop Direzza ZII Star Specs - Another go-to tire, but pretty stiff for daily driving supposedly. Good in the wet, plenty are available currently.
Great tires and I can vouch on them being pretty grippy in the wet. I daily drive mine and I disagree with them being harsh for daily driving.
sittinSideways is offline   Reply With Quote
Old 04-28-2015, 05:48 PM   #324
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
Originally Posted by justint5387 View Post
I was staring at tail lights all weekend.
Damn.......How long did it take you to make up that difference?
How prepped is the WRX?
How do you think you drove?
Thanks,
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 04-29-2015, 03:07 AM   #325
justint5387
Drives: 4 wheels
Thanks,
Simmons
The WRX seems well prep, it has KW clubsports, full turbo back exhaust, tune, and intake.
I thought I drove ok, my brother drove better but red lit his good right side run. I think if the course was more technical, the WRX launch advantage wouldn't be too significant. But we were well into 3rd gear twice in a 30 secs course
justint5387 is offline   Reply With Quote
Old 04-29-2015, 12:15 PM   #326
Simmons
Simmons's Avatar
Wow,...3rd gear at a Pro Solo
Thanks for the info.
Simmons
Old 04-29-2015, 12:42 PM   #327
TrqlessWonder
Drives: 2014 FR-S
Originally Posted by TrqlessWonder View Post
May be a moot point. Rule is 6 sizes across 4 diameters. It's April 28th, and they're at 5 sizes across 3 diameters. They'll need to add either an 18 or a 14 by COB Thursday, barring SEB intervention.
Nothing like cutting it fine. 6th size is listed. It's an 18.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
The Following User Says Thank You to TrqlessWonder For This Useful Post:
tahdizzle (04-29-2015)
Old 04-29-2015, 01:40 PM   #328
conedodging
conedodging's Avatar
Drives: '14 BRZ
"Estimated Availability: 05/04/15"
"1. Tire availability: Tires are considered available when competitors can take possession through retail channels. Pre-orders are not considered available."
Wonder if the SCCA will be lenient on this or not...
conedodging is offline   Reply With Quote
Old 04-29-2015, 03:49 PM   #329
renfield90
The Stig's German cousin
No. The original rule was vague and ended in a brouhaha that led to the current rule, which is more black/white. Any sort of back tracking now from a tire that is clearly not meeting the rules is a slippery slope.
I've heard the final qualifying size arrives at Tire Rack's warehouse 4/30. If you could order by website/phone and pick them up the same day, that would probably qualify. Otherwise it'll be next year's problem.
Old 04-29-2015, 08:22 PM   #330
TrqlessWonder
Drives: 2014 FR-S
Could be interesting. But, on the estimated availability, what Tire Rack lists and what is real may not be the same.
Case in point - When I track my order for the Bridgestones, it just keeps on telling me later dates. 5/1, 5/7, now 5/23. But the phone call I just got said the 6th or 7th. Tire Rack for me has usually been under-promise, over-deliver. This is actually the first time I've bought tires from them and they weren't on my doorstep in less than 48 hours.
All the same, the SEB is aware, they are looking, they have ready access to Tire Rack folk (with a reputation for honesty) in the know, and they've been talking with them.
-Mike
#24 CS/CSR
Old 04-30-2015, 06:16 PM   #331
renfield90
Tire Rack now stating all the required V720 sizes were available today. Looks like another tire is in play...
Old 04-30-2015, 06:20 PM   #332
Traum
Drives: Honda POS
Not much info on the tire, but the 245/40/17 size says that thread depth is only 4/32"?!
Either that can't be right, or this tire won't meet the SCCA 200TW requirements, ever.
Traum is offline   Reply With Quote
Old 04-30-2015, 08:39 PM   #333
renfield90
Gotta be a typo - the 4 is right next to the 7 on a 10 key pad, and 7/32nds sounds correct (and is the minimum tread depth for solo legality).
Old 04-30-2015, 09:09 PM   #334
Apex_BRZ
Drives: 2013 Subaru BRZ Limited (WRB)
No way that's accurate. Even my R888's had 6/32's new.
Apex_BRZ is offline   Reply With Quote
Old 05-01-2015, 05:57 AM   #335
TrqlessWonder
Drives: 2014 FR-S
V710's and A6/A7 are molded at 4/32"
But yeah, still thinking someone fat-fingered that entry.
-Mike
#24 CS/CSR
Old 05-01-2015, 11:20 AM   #336
renfield90
Yeah, most R comps come at 4/32nds. IIRC Toyo recommends shaving the R888 to 4/32nds if it's going to be a dry weather tire only.
Areddi's Autocross Video Thread Areddi Mid-Atlantic 130 05-17-2015 06:19 PM
Anyone DD 200 Treadwear Tires? CraftyObeseCrunchyKitty Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 01-09-2015 11:44 AM
Tire PSI for completely stock autocross? bladesamurai Tracking / Autocross / HPDE / Drifting 16 06-11-2013 10:07 AM
Autocross Tire Pressure on ZII's Areddi Tracking / Autocross / HPDE / Drifting 6 04-12-2013 08:37 PM
KW V3 autocross set-up thread -max- Tracking / Autocross / HPDE / Drifting 97 10-18-2012 08:02 PM
