Old 04-27-2015, 12:35 PM   #309
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
Originally Posted by dwx View Post
LOL I feel like I'm going crazy, now they show the STX results with no cars on BFGs. I was also almost positive the RX-8 leading CS now was on different tires in the morning as well and is now showing Bridgestones. He picked up an enormous amount of time between the morning and afternoon.
STX are 1-2 2015 WRXs. Those guys on the Bridgestones are pulling 1.7x 60' times compared to 2.3+ for the BRZ/FR-S. Hard to make up being down .6+ after the first 60'.
Imagine after 200ft.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
The Following User Says Thank You to Simmons For This Useful Post:
justint5387 (04-27-2015)
Old 04-27-2015, 12:46 PM   #310
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
I have a unique-to-Canada question
due to a mix of sponsor obligation and general limitation on participant count, up in the north we're still allowed to use 140TW tires.
Last year i ran on R1Rs and won two sets via contingency, so I'm sitting on quite a bit of rubber...and will probably continue to run the R1R this year (still competitive enough to get another set, or maybe a 2nds place coupon towards toyo tires)
For those than ran the R1Rs in the past, how do you feel they measure up to the new Bridgestones?
Old 04-27-2015, 11:14 PM   #311
justint5387
Drives: 4 wheels
Simmons
[ame="https://www.youtube.com/watch?v=jKLOH8jCUWs"]WRX vs BRZ Launch - YouTube[/ame]
I was staring at tail lights all weekend.
justint5387 is offline   Reply With Quote
Old 04-27-2015, 11:19 PM   #312
justint5387
Drives: 4 wheels
I think the Rival-S worked pretty good. Will see which tires work better at Lincoln.
Old 04-28-2015, 12:21 AM   #313
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Just one month until Spring Nats
It should be interesting to see how the new tires do
G_Ride is offline   Reply With Quote
Old 04-28-2015, 10:59 AM   #314
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
you guys think the khumo v720s will be a 200tw?
-Jack Burton
Old 04-28-2015, 11:12 AM   #315
SeanRTR
C-Street AutoX
SeanRTR's Avatar
So no one has run on Rival-S tires yet?
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
Old 04-28-2015, 11:27 AM   #316
G_Ride
G_Ride's Avatar
I think it will be.
The only people I know that have tried the Rival S are in STX. @justint5387?
Old 04-28-2015, 11:42 AM   #317
justint5387
Drives: 4 wheels
I ran about the same time at Crows Landing test and tune on BFG and Bridgestone. Results probably vary depending on the surface you run on. A lot of results show Bridgestone being faster on asphalt.
Kevin Dietz (BFG) and Nick Bjoin (Bridgestone) were running similar raw times at the pro also.
Old 04-28-2015, 12:00 PM   #318
SVLTE
I have, honestly my opinion is pretty worthless because it was my first autocross ever, but I do have the facts.
My car (3rd place out of 5) is fully prepped for C-street except for OEM dampers. Running on TRD Springs/Sways. 225/45 Rival S on 17x7 K4R's with some 9mm spacers I had machined.
Not sure of the prep on 2nd place Miata.
1st place FR-S was similarly prepped, but Koni's and 245/40 RE71R's on K4R's. Driver is very experienced, well versed in setup, and very smooth.
Again, hard to say much considering it was my first event, but the course was in an off camber lot and very hard on the driver's side front tire. I think the Rival S seemed to look slightly less ragged on the LF shoulder than the RE71R's I saw on other cars, but they were also going faster than I was. Pretty happy with my results for first time out.
I will post video when I get it uploaded.
SVLTE is offline   Reply With Quote
Old 04-28-2015, 12:33 PM   #319
renfield90
The Stig's German cousin
I am planning to run a set at spring nats.
Old 04-28-2015, 12:39 PM   #320
TrqlessWonder
Drives: 2014 FR-S
May be a moot point. Rule is 6 sizes across 4 diameters. It's April 28th, and they're at 5 sizes across 3 diameters. They'll need to add either an 18 or a 14 by COB Thursday, barring SEB intervention.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
The Following User Says Thank You to TrqlessWonder For This Useful Post:
tahdizzle (04-28-2015)
Old 04-28-2015, 02:14 PM   #321
renfield90
Might be worth checking other retailers - Tire Rack is not the sole arbiter of the 4/30 deadline. But it doesn't look good.
You can still run the V720 at local events, but they won't be legal for national competition.
Old 04-28-2015, 03:34 PM   #322
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
Spring nats will be fun!
2superblus is offline   Reply With Quote
Areddi's Autocross Video Thread Areddi Mid-Atlantic 130 05-17-2015 06:19 PM
Anyone DD 200 Treadwear Tires? CraftyObeseCrunchyKitty Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 01-09-2015 11:44 AM
Tire PSI for completely stock autocross? bladesamurai Tracking / Autocross / HPDE / Drifting 16 06-11-2013 10:07 AM
Autocross Tire Pressure on ZII's Areddi Tracking / Autocross / HPDE / Drifting 6 04-12-2013 08:37 PM
KW V3 autocross set-up thread -max- Tracking / Autocross / HPDE / Drifting 97 10-18-2012 08:02 PM
