Old 04-26-2015, 06:35 PM   #1
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
Help on ST coilover install (ST coils owners)
I just need help on people who also owns st coils.
1st: For the two nuts for the rear coils, do you put them separately? One under and the other one on top? Or you put both on top?
2nd: for the front do you need to put this thing, kind of a plate that came off from the stock that holds the stock spring? It was in between the top hats and the front coilover?
Do i do the same in rear? Because it had that plate also from the stock struts.
3rd: do this look alright or is it to high? That's w/o the plate i'm talking about in the 2nd question.
Thank you for looking and will appteciate your answers!
tintumz22 is offline   Reply With Quote
Old 04-27-2015, 09:31 PM   #2
8R6
8R6's Avatar
Drives: FRS
1- wat?
2- nope. dont need that for the fronts.
- for the rear, theres only one "piece" for the top hats in the rear. you need to use that or there'll be nothing to hold down the spring... it should make sense when you look at it.
3- yes. it sticks up higher than the stock strut.
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
tintumz22 (04-27-2015)
Old 04-27-2015, 09:40 PM   #3
tintumz22
tintumz22's Avatar
Originally Posted by BRGT86 View Post
1- wat?
The nut to lock the rear strut, the 17mm nut. It came with two. You put both to lock the rears when finishing installation?
Did you do a corner balance to your car after install? Or just alignment?
Old 04-28-2015, 11:27 PM   #4
dito
Drives: SWP BRZ
1- wat?
damn, i reused that plate for the front. nothing weird is happening so far. should i take it off?
dito is offline   Reply With Quote
Old 04-29-2015, 11:04 AM   #5
wparsons
wparsons's Avatar
That's the stock spring seat, and is just taking up space now.
flickr
Old 04-29-2015, 05:39 PM   #6
dito
Drives: SWP BRZ
so should i take it off?... lol I'm nub
Old 04-29-2015, 08:33 PM   #7
8R6
8R6's Avatar
Drives: FRS
yes
The Following 2 Users Say Thank You to 8R6 For This Useful Post:
tintumz22 (04-30-2015), wparsons (04-29-2015)
Old 03-28-2016, 04:11 AM   #8
jimmillion
Power Ranger Elite
jimmillion's Avatar
Drives: '13 WRB Sport-tech
Originally Posted by 8R6 View Post
yes
Sorry for the noob question, but would you guys be able to confirm for me that the black metal collars you see in the picture just underneath the top nuts are meant for shipping only? Their not new spring seats that need to be installed are they?
jimmillion is offline   Reply With Quote
Old 03-28-2016, 08:32 AM   #9
wparsons
wparsons's Avatar
Those are the new spring seats, and you want to keep them in place.
flickr
8R6 (03-28-2016)
Old 03-28-2016, 09:04 AM   #10
Tor
Tor's Avatar
Drives: Toyota GT86
1) Tighten down the first nut to the specified specs. Install the second nut to prevent first nut from loosening.
2) The springs are different diameter than stock. Remove the the stock spring seats front AND rear, and replace with what came with the kit.
Tor is offline   Reply With Quote
Old 03-28-2016, 11:36 AM   #11
jimmillion
Power Ranger Elite
jimmillion's Avatar
So I bought mine secondhand and didn't realised until now that they're missing the rear spring seats. Do you think I can get away with using the stock rear seats?
EDIT: nvm did some googling and I definetely need them since it centres the springs. Time to email ST I guess lol.
The Following User Says Thank You to jimmillion For This Useful Post:
wparsons (03-28-2016)
Beatrush Mounts ,BC BR, Bilstein, ISC N1, ST Coils, KW Coils and Stance Coilovers b2autodesigns Brakes, Suspension, Chassis 818 09-10-2017 09:33 AM
Coilover install JerryMichaels7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 02-05-2014 04:31 PM
Need a little advice on coilover install swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-01-2014 11:00 PM
HKS Coilover install gtauto AUSTRALIA 16 04-21-2013 08:37 AM
Anyone in Orang County Area know how to install coils? deedz Southern California 1 09-27-2012 05:49 PM
