Old 04-28-2015, 04:37 PM   #15
3nl
Drives: 2015 FR-S 6MT
Originally Posted by awhatzable View Post
So it's ok to hear it every time ? I've always tried to avoid making that sound by doing a mini launch on 2nd lol
Don't shift sloppily from first to second and make sure your revs are matched (or if you are going to be imprecise, err on the side of too many RPMs vs too little) and you won't have the slack in the driveline rapidly changing directions back and forth causing clunking noises.
3nl is offline   Reply With Quote
The Following User Says Thank You to 3nl For This Useful Post:
Ultramaroon (04-28-2015)
Old 04-28-2015, 10:44 PM   #16
Granny shifting and not double clutching like you should...
But seriously, there are a few factors that make the 1-2 shift tough for a beginner. Another that hasn't yet been mentioned is the fact that there is still a great deal of reduction which also exacerbates the effect of the driveline backlash. Not as bad as first gear but the engine is still turning a lot for each revolution of the rear wheel.
Koa (04-28-2015)
Old 04-29-2015, 04:04 PM   #17
Vincenttam
WtsTofu
Vincenttam's Avatar
Drives: Ultramarine fr-s
The only sound i hear is just my transmission getting into gear but i think thats just normal.
Vincenttam is offline   Reply With Quote
Old 04-30-2015, 02:14 AM   #18
M12Power
M12Power's Avatar
Drives: 2015 Firestorm Scion FR-S 6MT
With my FR-S, I think there's no clunk when shifting into 2nd gear, but there's usually a clunk when putting it in 1st gear from neutral at a stop.
M12Power is offline   Reply With Quote
Clunk when going into first gear? huma BRZ First-Gen (2012+) — General Topics 22 07-24-2014 05:49 PM
Clunk/Thump on first and second gear. ayephoe Engine, Exhaust, Transmission 12 06-08-2014 11:07 PM
Clunk sound after starting car and releasing clutch subiestyle Issues | Warranty | Recalls / TSB 1 03-14-2014 02:30 AM
Clunk sound with disengaging clutch up driveway BRRRZZZ Issues | Warranty | Recalls / TSB 4 04-22-2013 08:54 AM
How much RPM before letting go of the clutch? pinoyplaya BRZ First-Gen (2012+) — General Topics 40 08-12-2012 06:30 AM
