Old 06-07-2014, 04:33 PM   #1
ayephoe
ayephoe's Avatar
Drives: 2014 Scion FRS
Clunk/Thump on first and second gear.
So I have had my frs for 2 weeks now and I noticed an unusual clunk that you can hear and feel when you're at idle and throw it into first gear. I noticed it doesn't do it all the time nor when the car is cold.. So I took it into the dealer to have it checked out since I'm still breaking in the motor. I just hit 500 miles and they told me that they have got that complain a lot from many people and that it is just a "characteristic" of the frs. I was told that Toyota knows about the issue and is working towards a fix for that... Couldn't find threads on this.. Anyone else has that? Or heard anything? Sounds fishy to me. I took my car back. The only benefiting thing he told me was since there is no repairs found yet to correct the issue which makes no sense to me...he said if anything happens to the tranny I should be covered since I notified them and took it in..
Thoughts?Name:  ImageUploadedByTapatalk1402173209.882124.jpg
ayephoe is offline   Reply With Quote
Old 06-07-2014, 04:46 PM   #2
Rocket.BRZ
Drives: 2010 WRX (sold) 2013 brz
Switch your fluid out ASAP to pentosin. We have a thread on it. Besides that I recommend you do a search it's a popular topic with lots of threads.
Rocket.BRZ is offline   Reply With Quote
Old 06-07-2014, 04:47 PM   #3
Malt
Drives: 2015 WRX
Its a common sound with the stock fluid and a fluid change will fix it.
Malt is offline   Reply With Quote
Old 06-07-2014, 04:48 PM   #4
Rocket.BRZ
I should also add that many people are having issues with their transmission grinding going from 5th to 6th or 6th to 5th but that usually doesn't appear to you get over 10,000 miles.
Old 06-07-2014, 04:52 PM   #5
Rocket.BRZ
Read these threads
http://www.ft86club.com/forums/showthread.php?t=46208
http://www.ft86club.com/forums/showthread.php?t=16604
http://www.ft86club.com/forums/showthread.php?t=39636
Buy this
http://www.autohausaz.com/search/pro...er=83220309031
Old 06-07-2014, 04:57 PM   #6
ayephoe
ayephoe's Avatar
Awesome! Thanks guys!!
I have also heard that Amsoil is a good choice? I had a bimmer before the frs and that is all I used and I loved it and I read a thread where they said it was good for the tranny and diff..
Old 06-07-2014, 07:11 PM   #7
radroach
Drives: car
Wow seems like nobody read what OP wrote. Recommending oil for the fix? LOL
OP, the thunk is from the intermediate shaft still spinning when you're at a stop. When you put it in gear, it causes the shaft to immediately stop spinning, causing the noise. You can avoid the noise by holding your clutch in a little longer at a light.
Old 06-07-2014, 07:51 PM   #8
ayephoe
ayephoe's Avatar
Lol that makes a whole lot more sense! But it's absolutely normal on these cars??
Imma try that holding the clutch down longer.
Old 06-07-2014, 09:18 PM   #9
radroach
Drives: car
Yeah. Even the manual might say something about it.
Old 06-08-2014, 04:41 AM   #10
Sayte
Drives: 2014 Subaru BRZ
This is exactly it. Even my R/T challenger made the same noise when shifting into first after a stop. Not only a twins thing :P Nothing to worry about. Though, changing your transmission oil is still recommended and good to do in my book!
Sayte is offline   Reply With Quote
Old 06-08-2014, 10:45 AM   #11
GrippinandRippin
Drives: 2014 BRZ Limited SWP
But it also happens at startup... not just after stop
Sent from my SCH-I545 using Tapatalk
GrippinandRippin is offline   Reply With Quote
Old 06-08-2014, 11:06 PM   #12
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
This is normal phenomenon
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 06-08-2014, 11:07 PM   #13
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Try amsoil worked for me
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Suspension clunk/thump going over bumps SloS14 Issues | Warranty | Recalls / TSB 31 11-19-2015 07:05 PM
1st to 2nd Gear Clunk (Searched, but not the same issue as the other ones) shu5892001 Issues | Warranty | Recalls / TSB 26 03-26-2015 03:23 AM
Clunk when going into first gear? huma BRZ First-Gen (2012+) — General Topics 22 07-24-2014 05:49 PM
Occasional drivetrain thump when putting into 1st gear chaotichoax Engine, Exhaust, Transmission 5 10-21-2012 01:30 PM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
