Old 04-28-2015, 01:08 PM   #239
johneastvold
Drives: 2014 scion FRS
From the first post in this thread, no don't run stage 2 tune on stock car (on petrol) its only for cars with catless header uel or EL.
Rough guide OTS Map Requirements:
Stage 1- For vehicles equipped with original header. Other exhaust modifications also compatible. Stock airbox (with or without aftermarket drop-in panel filter) also recommend. Premium grade fuel or fuel as specified by tune.
Stage 2- For vehicles equipped with aftermarket cat-less headers. Other exhaust modifications also compatible. Stock airbox (with or without aftermarket drop-in panel filter) also recommend. Premium grade fuel or fuel as specified by tune
91 (USA) octane or better required for 91 octane tunes
93 (USA) octane or better required for 93 octane tunes
Its ok to use a higher octane than specified by the tune but not a good idea to use a lower octane fuel than specified by the tune.
E85 required for tunes labeled E85 (ie fuel with 60 to 90% ethanol content)
Exception for Stock cars running E85 use Stage 2 E85 EL header tune http://www.ft86club.com/forums/showthread.php?t=67310
will there be a power loss or noticable change swithcing to stge 1
johneastvold is offline   Reply With Quote
Old 04-28-2015, 01:14 PM   #240
steve99
Drives: FT86
Stage 2 tunes run more fuel and increased ignition timing than stage 1 tunes as you are supposed to have a catless header which flows better.
Its not recomemded to run stage 2 tunes without catless header, you may get knock or other issues.
suggest you flash stage 1 tune.
Old 04-28-2015, 01:19 PM   #241
johneastvold
ah okay, will flash to stage 1. yeah i smelled strong gas fumes when i first started it up. ill be moving back to cali ina month or so with 91 ethanol gas... so will it have the return of the crickets with that?
Old 04-28-2015, 01:54 PM   #242
Shedd22
BAMF
Shedd22's Avatar
Drives: 2014 SWP BRZ
I'm not sure if this is serious..^
Shedd22 is offline   Reply With Quote
Old 04-28-2015, 04:39 PM   #243
P5yk0t1c
Drives: 2014 FR-S
What if I have a UEL header and a catback exhaust...stock front pipe and over pipe. Is that still Stage 2 tune?
P5yk0t1c is offline   Reply With Quote
Old 04-28-2015, 05:11 PM   #244
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Yes
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 04-28-2015, 05:25 PM   #245
kch
Senior Misanthrope
kch's Avatar
Is the header catted? If so, stage 1. If catless, stage 2 UEL.
Old 04-28-2015, 06:15 PM   #246
tonystewart
Is that so? Catted UEL requires a Stage 1 ??? Are you sure?
Old 04-29-2015, 01:09 AM   #247
Trettiosjuan
Drives: GT86
Yes, on gasoline. On E85 ethanol fuel you can use stage 2 (there is no stage 1 E85).
Trettiosjuan is offline   Reply With Quote
Old 04-29-2015, 10:49 AM   #248
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
Yep. That's accurate
Kronos is offline   Reply With Quote
Old 04-29-2015, 06:24 PM   #249
RFB
RFB's Avatar
Drives: FRS
The Cdn. distributor of OFT advised me that with a catted UEL header, (w/intake, catback), stage 2 is fine.
Tech support at OFT also confirmed via e-mail.
Perhaps stage 1 is meant for stock header.
RFB is offline   Reply With Quote
Old 05-03-2015, 09:53 PM   #250
Njmarkc
Drives: 2015 CWP BRZ Limited
Openflash manager question
When I download data and my bins are listed only the original file is shown with a blue floppy disk icon which seems like it can be altered and my Modified files 1-5 are shaded gray which appears to be locked.
How do I know if I am running stage 1 91 or 93 Oct. It doesn't seem like I can load a stage 1 93 bin. I am D00C by the way.
Thanks
Njmarkc is offline   Reply With Quote
Old 05-03-2015, 10:00 PM   #251
steve99
Drives: FT86
Thanks
out of the box 93 database tunes are loaded, however not all rom types are in the default database.
you will have to download openflash manager software and tune files and possibly new template file see firts post
Old 05-04-2015, 06:14 PM   #252
Rican_D
Rican_D's Avatar
Finally flashed to 93 octane tune. All I have to say is wow! @steve99 thanks for your help. Definitely recommend OFT to any FR-S, 86, BRZ owner.
Rican_D is offline   Reply With Quote
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 07:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 02:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
